Home » Archived » Eclipse Communications Framework (ECF) » Possible bug in ECF AppGenericServer
Possible bug in ECF AppGenericServer [message #623592] |
Fri, 30 May 2008 04:45  |
Dear sir I am trying to launch an ECF AppGenericServer, for the last whole
weak by using the command
eclipse.exe -console -application org.eclipse.ecf.provider.AppGenericServer
but it gives me the following error.
No service type for event <javax.jmdns.ServiceEvent>
javax.jmdns.ServiceEvent[so
urce= ---- Services -----
---- Types ----
Type:
8.4.a.4.9.a.e.f.f.f.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.
8.e.f.ip6.arpa.:
8.4.A.4.9.A.E.F.F.F.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8. E.F
ip6.arpa.
Type: _rfb._tcp.local.: _rfb._tcp.local.
Type: _http._tcp.local.: _http._tcp.local.
Type: _afpovertcp._tcp.local.: _afpovertcp._tcp.local.
Type: _services._dns-sd._udp.local.:
l.
Type: _net-assistant._udp.local.: _net-assistant._udp.local.
---- cache ----
record[a,in,fehmarn.local.,3600/3599, address
'132.176.75.108']
record[ptr,in,_services._mdns._udp.local.,3600/3599,_net-ass ista
nt._udp.local.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,8.4.A.4. 9.A.
E.F.F.F.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa .]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_rfb._tc p.lo
cal.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_http._t cp.l
ocal.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_afpover tcp.
_tcp.local.]
record[ptr,in,_services._mdns._udp.local.,3600/3599,_service s._d
ns-sd._udp.local.]
---- Service Collectors ----] name null type
2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. info null and JMDNS service
type
8.4.A.4.9.A.E.F.F.F.3.9.3.0.2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8. E.F.ip6.arpa.
Can you please help me in this regard?
Re: Possible bug in ECF AppGenericServer [message #623593 is a reply to message #623592] |
Fri, 30 May 2008 05:06   |
> whole weak by using the command
> ---- Types ----
> Type:
> 8.e.f.ip6.arpa.:
> ip6.arpa.
> l.
> ---- cache ----
> '132.176.75.108']
> nt._udp.local.]
> cal.]
> ocal.]
> _tcp.local.]
> ns-sd._udp.local.]
> service type
might be related to this bug [1].
Cheers
Markus
[1] https://bugs.eclipse.org/202774
Re: Possible bug in ECF AppGenericServer [message #623594 is a reply to message #623593] |
Fri, 30 May 2008 15:21   |
Syed,
Does this prevent the AppGenericServer from starting, or does it
continue to start and run?
As Markus indicated, this does indeed seem to be a problem with JmDNS
running on ipv6 networks. I will attempt to get the JmDNS folks paying
attention to this bug as possible...but realistically it may take them
some time to address it. Part of the slowdown, I expect, is the
availability of of ipv6 networks for testing/reproing the problem.
Scott
>> ---- Types ----
>> Type:
>> 8.e.f.ip6.arpa.:
>> ip6.arpa.
>> l.
>> ---- cache ----
>> '132.176.75.108']
>> nt._udp.local.]
>> cal.]
>> ocal.]
>> _tcp.local.]
>> ns-sd._udp.local.]
>> service type
> Cheers
> Markus
Re: Possible bug in ECF AppGenericServer [message #623681 is a reply to message #623594] |
Mon, 02 June 2008 04:51  |
Dear ECF Team
As I understand, this is an exception. The AppGenericServer does not run
anymore after this exception comes.
Also it is very very slow to respond
Cheers
Sajid
Scott Lewis wrote:
> Syed,
> Scott
>>> ---- Types ----
>>> Type:
>>> 8.e.f.ip6.arpa.:
>>> ip6.arpa.
>>> l.
>>> ---- cache ----
>>> '132.176.75.108']
>>> nt._udp.local.]
>>> cal.]
>>> ocal.]
>>> _tcp.local.]
>>> ns-sd._udp.local.]
>>> service type
>> Hi,
>> Cheers
>> Markus
Current Time: Sun Jul 27 11:19:57 EDT 2025
Powered by FUDForum. Page generated in 0.04151 seconds
