Home » Modeling » UML2 Tools » Parsing InstanceSpecification Classifier
Parsing InstanceSpecification Classifier [message #476335] Tue, 10 March 2009 14:21 Go to next message
I have a little Problem and hope someone can help me.
I want to set the Slots with the definingFeatures of the corresponding
classifier Class when the Classifier is set. I added a little method to
the lookupResolve in the InstanceSpecificationParser of the common
plugin. This works fine. The problem is that when i change the Name with
the parser the Methode overwrite all Slots and their values. I tried
to check if the slotList is empty but the parser gets the element
without the corresponding slots. Any better Point to insert this method?
Re: Parsing InstanceSpecification Classifier [message #476336 is a reply to message #476335] Wed, 11 March 2009 11:10 Go to previous messageGo to next message
Hello Peter,
Your task is very natural. There are several ways to implement it:
1) Initialize Slots on demand:
Add custom action to the context menu of Instance Specification.
How to create custom action to UML2 Tools is described here - http://wiki.eclipse.org/MDT-UML2Tools_FAQ#I_want_to_add_my_c ustom_actions_to_the_UML2Tools_class_diagram._How_can_I_do_i t.3F
2) Listen to InstanceSpecification#classifiers property:
Create a proper NotificationListener and add it to InstanceSpecificationEditPart#addSemanticListeners()
method.
Best wishes,
Tanya.
> to
> with
> method?
Re: Parsing InstanceSpecification Classifier [message #476339 is a reply to message #476336] Thu, 12 March 2009 08:52 Go to previous messageGo to next message
Hi Tanya,
thank you! Now everything works as expected.
Hava a nice day.
Peter
> Hello Peter,
> Add custom action to the context menu of Instance Specification. How to
> InstanceSpecificationEditPart#addSemanticListeners() method.
> Best wishes,
> Tanya.
>> Hi,
>> to
>> with
>> method?
Re: Parsing InstanceSpecification Classifier [message #476366 is a reply to message #476336] Thu, 02 April 2009 11:30 Go to previous messageGo to next message
I also want to set a NotificationListener to the Body of the
OpaqueExpression nested in the Constraint Elements.
Can someone tell me the right way to do this?
Peter
> Hello Peter,
> Best wishes,
> Tanya.
Re: Parsing InstanceSpecification Classifier [message #476368 is a reply to message #476366] Fri, 03 April 2009 08:10 Go to previous messageGo to next message
Hello Peter,
Adding such method to ConstraintEditPart should help:
* @NOT generated
protected void addSemanticListeners() {
super.addSemanticListeners();
Constraint constraint = (Constraint) resolveSemanticElement();
ValueSpecification s = constraint.getSpecification();
if (s != null && s instanceof OpaqueExpression) {
addListenerFilter("SemanticModel_BodyListener", this, s, UMLPackage.eINSTANCE.getOpaqueExpression_Body());
Tanya.
> Thanks
> Peter
Re: Parsing InstanceSpecification Classifier [message #476369 is a reply to message #476368] Fri, 03 April 2009 09:21 Go to previous message
Thank you Tanya!
> Hello Peter,
> * @NOT generated
> Tanya.
>> Hi,
>> Thanks
>> Peter
Re: Parsing InstanceSpecification Classifier [message #623621 is a reply to message #476335] Wed, 11 March 2009 11:10 Go to previous message
Hello Peter,
method.
Best wishes,
Tanya.
> to
> with
> method?
Re: Parsing InstanceSpecification Classifier [message #623624 is a reply to message #476336] Thu, 12 March 2009 08:52 Go to previous message
Hi Tanya,
Hava a nice day.
Peter
> Hello Peter,
> Best wishes,
> Tanya.
>> Hi,
>> to
>> with
>> method?
Re: Parsing InstanceSpecification Classifier [message #623630 is a reply to message #476336] Thu, 02 April 2009 11:30 Go to previous message
Peter
> Hello Peter,
> Best wishes,
> Tanya.
Re: Parsing InstanceSpecification Classifier [message #623632 is a reply to message #476366] Fri, 03 April 2009 08:10 Go to previous message
Hello Peter,
* @NOT generated
Tanya.
> Thanks
> Peter
Re: Parsing InstanceSpecification Classifier [message #623633 is a reply to message #476368] Fri, 03 April 2009 09:21 Go to previous message
Thank you Tanya!
> Hello Peter,
> * @NOT generated
> Tanya.
>> Hi,
>> Thanks
>> Peter
Previous Topic:Template Parameter Binding to UML Classes and Ecore Primitive Types
Next Topic:How do I model the Package description in component diagram?
Current Time: Wed Jul 23 06:12:36 EDT 2025
Powered by FUDForum. Page generated in 0.08568 seconds
