Question About Shared Editors [message #623595] |
Fri, 30 May 2008 16:46  |
I've been experimenting with Eclipse 3.4-RC2 and are looking at the
various features of ECF, I was wondering what the status is with the
Shared Editors, specifically Cola. It seems as if it is in the process
of being merged into DocShare. I'm curious as to what plans you have
regarding Shared Editing moving towards your simultaneous release with
Ganymede. Also it seems RT Shared Editor/Cola can do shared editing
through a collaboration server, while DocShare cannot. However, it
appears RT Shared Editor is no longer in use. Currently, is there a way
to do shared editing through a collaboration server?
Elliott Baron
Re: Question About Shared Editors [message #623596 is a reply to message #623595] |
Fri, 30 May 2008 19:58   |
Hi Elliot,
Elliott Baron wrote:
That's correct. This is the bug that Mustafa Isik is working on WRT
Cola and Docshare integration:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=207530
> Ganymede.
The plan is to get cola integrated into DocShare for Ganymede (basically
with t207530)...that is, having DocShare using cola for conflict
detection/recovery/synchronization.
That is true, although this is only an implementation limitation and not
a fundamental limitation. That is, DocShare messaging is only dependent
upon the ECF datashare API (org.eclipse.ecf.datashare), and the
datashare API *is* supported by the collaboration server/example client
application for Eclipse.
We don't have any user interface (yet) for accessing DocShare from
within the collaboration application. And actually, we *do* plan on
separating the DocShare messaging/synchronization from the UI code in
DocShare as per this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=234142
Actually, my longer term intention is to separate the cola/docshare
synchronization logic from the UI code and produce API for doing
distributed model synchronization. But this can't happen immediately
and won't happen in time for Ganymede...but we do want it to happen
during the 2.0-3.0 development year.
However, it
There is, but it would require some additions to the collab client (to
introduce a new docshare UI) and it would/does require some further
enhancements to Cola (to support n-way messaging instead of just 2-way).
The UI part isn't a huge amount of work, really, but since we're under
a Ganymede-imposed API and feature freeze we can't introduce new UI
until after Ganymede/ECF 2.0.0 release is complete.
But if such an enhancement (creating a UI for collaboration server) is
particularly important to you then please do file an enhancement request
to that effect, and we will attempt to get to it as soon as we can. I
can tell you for sure that Docshare/cola/model synchronization/etc are
all going to be major focuses for the team for ECF 2.1 and beyond.
Further, if you are willing/able to be involved yourself we would be
happy to point you in the right directions right away and coordinate
work to common ends.
Scott
FUDForum. Page generated in 0.06906 seconds
