Home » Archived » Eclipse Communications Framework (ECF) » JmDNS discovery issue
JmDNS discovery issue [message #623577] Mon, 19 May 2008 12:02 Go to next message
In ECF 1.2.0 and prior versions, I would add myself as a service listener
for my type of service, then request service info for it when receiving the
serviceAdded() event.
In ECF 2.0.0, there is no longer an exposed serviceAdded() and the container
makes the request service info call. In fact, it makes a request for every
service which is reported.
Since my network has dozens of different services running, I am seeing the
container going through a lot of unnecessary overhead and causing extra
network traffic.
What is the purpose of resolving services when there are no registered
listeners for that information?
I am seeing the following exception if there is a disconnect done before
resolution of all those services is complete:
java.lang.IllegalStateException: Timer already cancelled.
at java.util.Timer.sched(Timer.java:354)
at java.util.Timer.schedule(Timer.java:222)
at javax.jmdns.JmDNS$ServiceInfoResolver.start(JmDNS.java:2100)
at javax.jmdns.JmDNS.requestServiceInfo(JmDNS.java:452)
at
org.eclipse.ecf.provider.jmdns.container.JMDNSDiscoveryConta iner$3.run(JMDNSDiscoveryContainer.java:326)
at
org.eclipse.ecf.provider.jmdns.container.JMDNSDiscoveryConta iner$1.run(JMDNSDiscoveryContainer.java:117)
at java.lang.Thread.run(Thread.java:595)
So I expect the Runnable doing the resolution request call should be
checking if the service is still connected before issuing it.
Re: JmDNS discovery issue [message #623579 is a reply to message #623577] Mon, 19 May 2008 12:37 Go to previous messageGo to next message
Hi Bill,
> network traffic.
The main reason was simplification of the discovery API. Especially in
moving the API to support other providers (e.g. jSLP, which is now in
there), it became apparent that the zeroconf model of having a two step
resolution process (i.e. get notification of service existence, and then
resolving manually) did not generalize well/easily to other
providers...and it adds a level of complexity in the use of the API as well.
Yes, for the zeroconf provider the cost of this is additional network
traffic.
> at
> at
I have seen this as well. I believe it would qualify as a JmDNS bug, as
the Thread running this code is created/started within JmDNS.
But if you would be kind enough to file an ECF bug on this as well we
will do our best to address it.
Scott
Re: JmDNS discovery issue [message #623580 is a reply to message #623579] Mon, 19 May 2008 12:43 Go to previous messageGo to next message
Since you are going to add a check if the service is connected before doing
the service info request, why can't you check if there is a registered
listener for that service type before doing that call too?
"Scott Lewis" <slewis@composent.com> wrote in message
news:4831ACCE.8020700@composent.com...
> Hi Bill,
>> the serviceAdded() event.
>> container makes the request service info call. In fact, it makes a
>> request for every service which is reported.
>> the container going through a lot of unnecessary overhead and causing
>> extra network traffic.
> well.
> traffic.
>> at
>> at
> But if you would be kind enough to file an ECF bug on this as well we will
> Scott
Re: JmDNS discovery issue [message #623582 is a reply to message #623580] Mon, 19 May 2008 13:19 Go to previous messageGo to next message
Hi Bill,
We could/might, but I don't believe this would really fix the problem,
as it still would be possible to issue the request (connected), then
disconnect, and then have the jmdns thread make the callback and fail as
below.
But I'm willing to make the connect check anyway, to reduce the likelihood.
Scott
>> Hi Bill,
>> well.
>> traffic.
>>> at
>>> at
>> Thanks,
>> Scott
Re: JmDNS discovery issue [message #623584 is a reply to message #623582] Mon, 19 May 2008 13:42 Go to previous messageGo to next message
If I understand your reply, that is not what I was suggesting.
In the old design, I would register as a listener for my service type then
request the service info when I was told the service was added.
Since you don't want that two step process, have the container ask for the
service info on service added only because I had previously registered as a
listener for that service type. No request for service info would be sent
unless there is a registered listener for the result.
This is a return to the old behavior despite the simplified API.
news:4831B692.1080902@composent.com...
> Hi Bill,
>> doing the service info request, why can't you check if there is a
>> registered listener for that service type before doing that call too?
> We could/might, but I don't believe this would really fix the problem, as
> below.
> likelihood.
> Scott
>>> Hi Bill,
>>>> listener for my type of service, then request service info for it when
>>>> receiving the serviceAdded() event.
>>> well.
>>> traffic.
>>>> before resolution of all those services is complete:
>>>> at
>>>> at
>>> Thanks,
>>> Scott
Re: JmDNS discovery issue [message #623585 is a reply to message #623584] Mon, 19 May 2008 14:02 Go to previous messageGo to next message
Hi Bill,
I see. OK, please create a bug and I will modify appropriately.
BTW, what apps/services are you registering/unregistering that end up
returning null from JMDNS ServiceEvent.getInfo() (i.e. and showing the
NPE from Re: NullPointerException in AbstractDiscoveryContainerAdapter)?
I've been testing with iTunes, trying to test out a fix, but it doesn't
seem to invoke serviceRemoved (on exit or deactivation).
Scott
>> Hi Bill,
>> below.
>> likelihood.
>> Scott
>>>> Hi Bill,
>>>> well.
>>>> traffic.
>>>>> at
>>>>> at
>>>> Thanks,
>>>> Scott
Re: JmDNS discovery issue [message #623586 is a reply to message #623585] Mon, 19 May 2008 14:24 Go to previous messageGo to next message
Could be that you are just not waiting long enough for the timeout
processing when services just silently drop off the network? I seem to
recall a timeout interval of something like 20-30 minutes.
My plugin is part of a custom P2P implementation where the user is given UI
to connect/disconnect.
I can reproduce the problem even when there are no peers on the network just
by connecting then disconnecting.
You probably should be able to reproduce by using JBuilder 2008 on the same
LAN.
http://cc.codegear.com/free/jbuilder
The P2P feature is available in the Turbo version.
news:4831C099.1000907@composent.com...
> Hi Bill,
>> then request the service info when I was told the service was added.
>> the service info on service added only because I had previously
>> registered as a listener for that service type. No request for service
>> info would be sent unless there is a registered listener for the result.
> returning null from JMDNS ServiceEvent.getInfo() (i.e. and showing the NPE
> from Re: NullPointerException in AbstractDiscoveryContainerAdapter)? I've
> been testing with iTunes, trying to test out a fix, but it doesn't seem to
> Scott
>>> Hi Bill,
>>> below.
>>> likelihood.
>>> Scott
>>>>> Hi Bill,
>>>>>> when receiving the serviceAdded() event.
>>>>>> seeing the container going through a lot of unnecessary overhead and
>>>>>> causing extra network traffic.
>>>>>> registered listeners for that information?
>>>>> in moving the API to support other providers (e.g. jSLP, which is now
>>>>> in there), it became apparent that the zeroconf model of having a two
>>>>> step resolution process (i.e. get notification of service existence,
>>>>> and then resolving manually) did not generalize well/easily to other
>>>>> well.
>>>>> traffic.
>>>>>> at
>>>>>> at
>>>>> as the Thread running this code is created/started within JmDNS.
>>>>> Thanks,
>>>>> Scott
Re: JmDNS discovery issue [message #623587 is a reply to message #623586] Mon, 19 May 2008 16:56 Go to previous messageGo to next message
Hi Bill,
I was doing something wrong. I'm now seeing the removes from iTunes
come through just fine.
Scott
> LAN.
>> Hi Bill,
>> Thanks,
>> Scott
>>>> Hi Bill,
>>>> below.
>>>> likelihood.
>>>> Scott
>>>>>> Hi Bill,
>>>>>> well.
>>>>>> traffic.
>>>>>>> at
>>>>>>> at
>>>>>> Thanks,
>>>>>> Scott
Re: JmDNS discovery issue [message #623588 is a reply to message #623587] Mon, 19 May 2008 17:00 Go to previous message
I pulled in your source changes for the bugs you asked me to enter and they
worked fine -- thanks!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232835
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232842
news:4831E973.3080901@composent.com...
> Hi Bill,
> I was doing something wrong. I'm now seeing the removes from iTunes come
> through just fine.
> Scott
>> UI to connect/disconnect.
>> just by connecting then disconnecting.
>> same LAN.
>>> Hi Bill,
>>>> result.
>>> Thanks,
>>> Scott
>>>>> Hi Bill,
>>>>> as below.
>>>>> likelihood.
>>>>> Scott
>>>>>>> Hi Bill,
>>>>>>>> and causing extra network traffic.
>>>>>>> now in there), it became apparent that the zeroconf model of having
>>>>>>> a two step resolution process (i.e. get notification of service
>>>>>>> existence, and then resolving manually) did not generalize
>>>>>>> well/easily to other providers...and it adds a level of complexity
>>>>>>> network traffic.
>>>>>>>> at
>>>>>>>> at
>>>>>>>> be checking if the service is still connected before issuing it.
>>>>>>> bug, as the Thread running this code is created/started within
>>>>>>> JmDNS.
>>>>>>> we will do our best to address it.
>>>>>>> Thanks,
>>>>>>> Scott
Previous Topic:NullPointerException in AbstractDiscoveryContainerAdapter
Next Topic:Other OSGi contained and HelloWorld
Current Time: Sat Jul 26 20:01:32 EDT 2025
Powered by FUDForum. Page generated in 0.05217 seconds
