Home » Eclipse Projects » Platform - User Assistance (UA) » Generating a ToC at run-time
Generating a ToC at run-time [message #475694] Mon, 20 July 2009 12:26 Go to next message
I am displaying a set of external HTML help files from a local filesystem
within
the Eclipse help system as follows:
docDir = getDocDirPreference();
href = "file:" + docDir + "/myhelp.html";
PlatformUI.getWorkbench().getHelpSystem().displayHelpResourc e(href);
The location of the directory containing the external help files is
configurable at run-time and this may affect the precise set of help files
available so I am unable to provide a static Table of Contents file when I
build my plug-in.
If I generated a ToC programatically at run-time, how could I add this to
the help system? Is there an API for this?
Peter Saunders
Re: Generating a ToC at run-time [message #475695 is a reply to message #475694] Mon, 20 July 2009 13:20 Go to previous messageGo to next message
Yes, there is an API, see the tocProvider element in the extension point
org.eclipse.help.toc - see
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/reference/extension-points/org_eclipse_help_toc.html
You will probably also want to use the org.eclipse.help.contentProducer
extension point to read the content.
Peter Saunders wrote:
> Hi
> filesystem within
> files available so I am unable to provide a static Table of Contents
> file when I build my plug-in.
> to the help system? Is there an API for this?
> Thanks
> Peter Saunders
Re: Generating a ToC at run-time [message #475699 is a reply to message #475695] Tue, 21 July 2009 06:03 Go to previous messageGo to next message
The AbstractTocProvider class looks useful. Thanks for the pointer.
I tried this earlier but the getInputStream() method in my
IHelpContentProducer implementation was never called. Perhaps it is only
called when the plug-in provides corresponding ToC entries.
Peter Saunders
Re: Generating a ToC at run-time [message #475701 is a reply to message #475695] Tue, 21 July 2009 10:18 Go to previous messageGo to next message
I've tried implementing a tocProvider based on the example code at:
http://www.eclipse.org/eclipse/platform-ua/documents/provide rs_api.html
but this code does not build for Galileo without modification. When I add
the
missing methods, the "Hello World" ToC contribution does not appear.
I've also looked at the adapting code from the RoboHelp ToC contributor at:
http://tinyurl.com/mws4cn
but that doesn't build for Galileo either.
I note that other developers have also struggled with this. Does anyone
have
an example for Galileo based on the AbstractTocProvider class?
Peter Saunders
Re: Generating a ToC at run-time [message #479420 is a reply to message #475701] Mon, 10 August 2009 19:31 Go to previous message
> have
> Peter Saunders
There is an attachment to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=272850 which is a plug-in
which generates a toc.
Re: Generating a ToC at run-time [message #623441 is a reply to message #475694] Mon, 20 July 2009 13:20 Go to previous message
> Hi
> filesystem within
> Thanks
> Peter Saunders
Re: Generating a ToC at run-time [message #623443 is a reply to message #475695] Tue, 21 July 2009 06:03 Go to previous message
Peter Saunders
Re: Generating a ToC at run-time [message #623444 is a reply to message #475695] Tue, 21 July 2009 10:18 Go to previous message
the
have
Peter Saunders
Re: Generating a ToC at run-time [message #623455 is a reply to message #475701] Mon, 10 August 2009 19:31 Go to previous message
> have
> Peter Saunders
Previous Topic:Is it possible to replace a forms title with StyledText?
Next Topic:Some index terms using path to href instead of title
Current Time: Sun Aug 31 04:19:03 EDT 2025
Powered by FUDForum. Page generated in 0.04421 seconds
