Home » Modeling » UML2 » How to add an interface into to list of providedinterfaces of Port?
How to add an interface into to list of providedinterfaces of Port? [message #473886] Fri, 06 July 2007 15:25 Go to next message
Hi NG
I'm working on a java interface create Eclipse UML model out of the
repository of a uml tool.
Now I stuck in how to add an interface to the list of provided or required
interfaces with java code.
Any help is welcome.
Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473892 is a reply to message #473886] Mon, 09 July 2007 09:32 Go to previous messageGo to next message
Hi Ueli,
You don't mention what you want to add a required or provided interface to?
A component or a port?
To add a provided interface to a component, you can create a Realization
from the component to the interface.
To add a required interface to a component you can create a Usage from the
To create a provided interface to a port you have two options, type the port
by the interface or type it by a classifier that has a realization to the
interface.
To create a required interface to a port you have to type it by a classifier
that has a usage relationship to the interface.
- James.
"ubrawand" <ueli.brawand@bluewin.ch> wrote in message
news:f6m4vf$te7$1@build.eclipse.org...
> Hi NG
> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473897 is a reply to message #473892] Mon, 09 July 2007 15:55 Go to previous messageGo to next message
Hi James
Thanx for your hints. Yes I forgot to specify where I wand to add required
and provided interfaces to.
I use it with ports. If you write "type the port by the interface" does this
mean port.setType(interface), or does it mean something else?
The same for required interface.
~Ueli
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f6tdd3$up7$2@build.eclipse.org...
> Hi Ueli,
> to?
> port
> interface.
> classifier
> - James.
>> Hi NG
>> required
>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473899 is a reply to message #473892] Mon, 09 July 2007 15:58 Go to previous messageGo to next message
Hi again
Where do I find some documentation about API of Eclipse.UML2 explaining such
topics?
~Ueli
> Hi Ueli,
> to?
> port
> interface.
> classifier
> - James.
>> Hi NG
>> required
>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473900 is a reply to message #473897] Mon, 09 July 2007 18:21 Go to previous messageGo to next message
Hi Ueli,
Yes, port.setType(...) is what that means.
- James.
news:f6u3sa$343$1@build.eclipse.org...
> Hi James
> this mean port.setType(interface), or does it mean something else?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473936 is a reply to message #473899] Mon, 09 July 2007 18:21 Go to previous messageGo to next message
news:f6u41q$3fk$1@build.eclipse.org...
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473937 is a reply to message #473899] Mon, 09 July 2007 18:24 Go to previous messageGo to next message
Hi Ueli,
The best documentation on how to use required/provided interfaces or any
aspect of UML is the UML superstructure specification at www.omg.org.
The opensource API is based on the superstructure specification.
-James
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473941 is a reply to message #473899] Tue, 10 July 2007 09:44 Go to previous messageGo to next message
Ueli,
As James, has stated, the UML2 API is, for the most part, a direct
implementation of the UML specification, so referencing the specification
should help. In this case, for example, you'd find the following
descriptions of Port::required and Port::provided:
.. required: Interface References the interfaces specifying the set of
operations and receptions that the classifier expects its environment to
handle. This association is derived as the set of interfaces required by the
type of the port or its supertypes.
.. provided: Interface References the interfaces specifying the set of
operations and receptions that the classifier offers to its environment, and
which it will handle either directly or by forwarding it to a part of its
internal structure. This association is derived from the interfaces realized
by the type of the port or by the type of the port, if the port was typed by
an interface.
Note that text that is similar to this can also be found in the Javadoc for
the corresponding getters, Port#getRequireds() and Port#getProvideds().
Kenn
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #473944 is a reply to message #473899] Tue, 10 July 2007 15:49 Go to previous message
Hi all
Thank you for your help. I think with the superstructure and the UML2 API I
can help myself.
~Ueli
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623306 is a reply to message #473886] Mon, 09 July 2007 09:32 Go to previous message
Hi Ueli,
interface.
- James.
> Hi NG
> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623309 is a reply to message #473892] Mon, 09 July 2007 15:55 Go to previous message
Hi James
~Ueli
> Hi Ueli,
> to?
> port
> interface.
> classifier
> - James.
>> Hi NG
>> required
>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623310 is a reply to message #473892] Mon, 09 July 2007 15:58 Go to previous message
Hi again
topics?
~Ueli
> Hi Ueli,
> to?
> port
> interface.
> classifier
> - James.
>> Hi NG
>> required
>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623311 is a reply to message #473897] Mon, 09 July 2007 18:21 Go to previous message
Hi Ueli,
- James.
> Hi James
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623312 is a reply to message #473899] Mon, 09 July 2007 18:21 Go to previous message
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623313 is a reply to message #473899] Mon, 09 July 2007 18:24 Go to previous message
Hi Ueli,
-James
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623640 is a reply to message #473899] Tue, 10 July 2007 09:44 Go to previous message
Ueli,
an interface.
Kenn
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Re: How to add an interface into to list of providedinterfaces of Port? [message #623643 is a reply to message #473899] Tue, 10 July 2007 15:49 Go to previous message
Hi all
can help myself.
~Ueli
> Hi again
> such topics?
> ~Ueli
>> Hi Ueli,
>> to?
>> the
>> port
>> interface.
>> classifier
>> - James.
>>> Hi NG
>>> required
>>> Regards, Ueli
Previous Topic:how to delete class.attribute(property)
Next Topic:Problems saving model (losing hrefs)
Current Time: Fri Jul 18 04:08:55 EDT 2025
Powered by FUDForum. Page generated in 0.07648 seconds
