Home » Modeling » UML2 Tools » epsilon.common.dt.tool extension for UMLCreateShortcutAction
epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475940] Tue, 25 November 2008 02:27 Go to next message
Can anyone please tell me how I could invoke from an EWL file the
org.eclipse.uml2.diagram.clazz.part.UMLCreateShortcutAction command?
This class is defined as an org.eclipse.core.commands.AbstractHandler
and defines a public method:
public Object execute(ExecutionEvent event) throws ExecutionException { ...
I don't know how to construct an
org.eclipse.core.commands.ExecutionEvent from the IGraphicalEditPart
'self' variable of the wizard.
Suggestions?
-- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475941 is a reply to message #475940] Tue, 25 November 2008 04:43 Go to previous messageGo to next message
Hi Nicolas,
Which version of the UML2Tools are you using? In my 0.8.0,
UMLCreateShortcutAction implements IObjectActionDelegate and doesn't
seem to be defining an execute(ExecutionEvent event) method.
Dimitris
> Suggestions?
> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475944 is a reply to message #475941] Tue, 25 November 2008 10:01 Go to previous messageGo to next message
Hi Dimitrios,
I'm using the 3.5 M3 version of Eclipse, EMF/UML/UML2Tools.
The UML2Tools APIs changed from 3.4 to 3.5M3 but Epsilon compiles &
seems to run OK.
The only changes I had to make were:
org.eclipse.epsilon.dt.exeed.modelink.ModeLinkEditor.activat eEditor(IEditorPart)
=> changed from protected to public
org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog
=> this just doesn't work as intended.
i.e., I when I click on the Add.. button, I have a simple TitleDialog
but nothing else to select a namespace / *.ewl file.
When I click on the Edit... button, I get the same title dialog.
No capability to edit the namespace/*.ewl file.
-- Nicolas.
Dimitrios Kolovos wrote:
> Hi Nicolas,
> Cheers,
> Dimitris
>> Suggestions?
>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475945 is a reply to message #475944] Tue, 25 November 2008 10:48 Go to previous messageGo to next message
Hi Nicolas,
Thanks for the feedback!
It may be something that has been fixed/broken in 3.5. I'll have to
setup 3.5 myself in order to investigate more (which may take a couple
of days). Could you please file a bug so that we can keep track of this?
In the mean time, you could use EWL by contributing an extension to the
org.eclipse.epsilon.ewl.emf.wizards extension point and starting a new
runtime workbench.
Dimitrios
> Hi Dimitrios,
> seems to run OK.
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitris
>>> Suggestions?
>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475950 is a reply to message #475945] Tue, 25 November 2008 15:36 Go to previous messageGo to next message
I've solved the problem with a patch to the UMLCreateShortcutAction that
exposes the reusable functionality for creating the shortcut as a static
method that we can invoke from an Epsilon wizard.
See bug 256496
-- Nicolas.
> Hi Nicolas,
> runtime workbench.
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> seems to run OK.
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitris
>>>> org.eclipse.core.commands.AbstractHandler and defines a public method:
>>>> Suggestions?
>>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475951 is a reply to message #475950] Tue, 25 November 2008 16:08 Go to previous message
For details how to do this, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256500
-- Nicolas.
> See bug 256496
> -- Nicolas.
>> Hi Nicolas,
>> the org.eclipse.epsilon.ewl.emf.wizards extension point and starting a
>> new runtime workbench.
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> seems to run OK.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitris
>>>>> IGraphicalEditPart 'self' variable of the wizard.
>>>>> Suggestions?
>>>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623277 is a reply to message #475940] Tue, 25 November 2008 04:43 Go to previous message
Hi Nicolas,
Dimitris
> Suggestions?
> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623280 is a reply to message #475941] Tue, 25 November 2008 10:01 Go to previous message
Hi Dimitrios,
seems to run OK.
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitris
>> Suggestions?
>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623281 is a reply to message #475944] Tue, 25 November 2008 10:48 Go to previous message
Hi Nicolas,
runtime workbench.
Dimitrios
> Hi Dimitrios,
> seems to run OK.
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitris
>>> Suggestions?
>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623287 is a reply to message #475945] Tue, 25 November 2008 15:36 Go to previous message
See bug 256496
-- Nicolas.
> Hi Nicolas,
> runtime workbench.
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> seems to run OK.
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitris
>>>> Suggestions?
>>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623289 is a reply to message #475950] Tue, 25 November 2008 16:08 Go to previous message
-- Nicolas.
> See bug 256496
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> seems to run OK.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitris
>>>>> Suggestions?
>>>>> -- Nicolas.
Previous Topic:epsilon.common.dt.tool extension for UMLCreateShortcutAction
Next Topic:Re: Problems with creating simple UML2 class diagram
Current Time: Wed Jul 23 17:35:27 EDT 2025
Powered by FUDForum. Page generated in 0.04015 seconds
