Home » Eclipse Projects » Platform - User Assistance (UA) » Launching a project from universal welcome
Launching a project from universal welcome [message #475116] Fri, 20 February 2009 15:20 Go to next message
Is there a way to do this? I want to include some samples in the universal
welcome and when a user clicks on the sample, it will open up the
workbench, with the project loaded into the workspace.
Re: Launching a project from universal welcome [message #475117 is a reply to message #475116] Fri, 20 February 2009 17:10 Go to previous messageGo to next message
Yes, it is possible to do this, that is how the samples page of
universal intro works. If you use a url starting with
http://org.eclipse.ui.intro/runAction it will be special cased and
launch the Action class specified. Here's one of the hrefs used in the
samples page.
http://org.eclipse.ui.intro/runAction?pluginId=org.eclipse.p de.ui&class=org.eclipse.pde.internal.ui.samples.ShowSamp leAction&id=org.eclipse.sdk.samples.propertysheet
> universal welcome and when a user clicks on the sample, it will open up
> the workbench, with the project loaded into the workspace.
Re: Launching a project from universal welcome [message #475120 is a reply to message #475117] Mon, 23 February 2009 20:04 Go to previous message
Thanks, I have hacking away as to how to do this, and got it to work by
modifying the plugin.xml file for org.eclipse.sdk.samples plugin and
adding my project to the list of available projects. I then add my
archived project to the samples folder of that plugin. My project shows up
in the list of available samples along with the default Eclipse ones when
using this link:
http://org.eclipse.ui.intro/runAction?pluginId=org.eclipse.p de.ui&amp ;class=org.eclipse.pde.internal.ui.samples.ShowSampleAction& amp;amp;id=org.eclipse.sdk.samples.InsuranceApp
My question is, how would I go about doing this without hacking the
default eclipse samples plugin? I know I need to write my own implementor,
but where would I start? Are there any samples floating around? I tried
just creating a new ShowSampleAction class, which was just a copy of the
original class but pointing to my samples plugin instead, but I get a lot
of "Discouraged Access" errors when try it this way. Any code samples out
there would be appreciated. I don't even need a complicated wizard. If a
user clicks on the link in the welcome screen, then all I need is it to
open in the workspace.
> samples page.
Re: Launching a project from universal welcome [message #623231 is a reply to message #475116] Fri, 20 February 2009 17:10 Go to previous message
samples page.
Re: Launching a project from universal welcome [message #623234 is a reply to message #475117] Mon, 23 February 2009 20:04 Go to previous message
using this link:
> samples page.
Previous Topic:How to configure the index tab
Next Topic:Context help included in search scope?
Current Time: Wed Jul 23 12:14:15 EDT 2025
Powered by FUDForum. Page generated in 0.08893 seconds
