[TEXO] Problem with ClassCastException in ModelPackage [message #559199] |
Wed, 15 September 2010 19:01  |
I created a code-gen.annotationsmodel from my ecore to change the package path.
The enums will not saved in the correct folder from the annotionsmodel, but the package definition in the generated code ist correct.
In my model if have a Contact class and an enum called ContactType. If I call ModelPackage.INSTANCE I get the following exception:
Caused by: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EEnumImpl cannot be cast to org.eclipse.emf.ecore.EClass
at de.sim.texo.model.common.person.PersonModelPackage.getContactEClass(PersonModelPackage.java:787)
at de.sim.texo.model.common.person.PersonModelPackage.initialize(PersonModelPackage.java:405)
at de.sim.texo.model.common.person.PersonModelPackage.<clinit>(PersonModelPackage.java:376)
... 31 more
The generated code looks like this:
* Returns the {@link EClass} '<em><b>Contact</b></em>'.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @return an instance of the {@link EClass} '<em><b>Contact</b></em>'
* @generated
public EClass getContactEClass() {
return (EClass) getEPackage().getEClassifiers().get(
CONTACT_CLASSIFIER_ID);
I debugged a little bit. This method return the ContactType instead of the Contact.
In my ecore looks like this:
<eClassifiers xsi:type="ecore:EClass" name="Contact">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" lowerBound="1" eType="#//ContactType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="context" lowerBound="1"
eType="#//ContactContextType" defaultValueLiteral="PRIVATE"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELong"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="note" eType="ecore:EClass common.ecore#//Note"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ContactType">
<eLiterals name="EMAIL"/>
<eLiterals name="PHONE" value="1"/>
<eLiterals name="MOBILE" value="2"/>
<eLiterals name="FAX" value="3"/>
<eLiterals name="WWW" value="4"/>
<eLiterals name="MESSENGER" value="5"/>
<eLiterals name="OTHER" value="6"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ContactContextType">
<eLiterals name="PRIVATE"/>
<eLiterals name="BUSINESS" value="1"/>
<eLiterals name="OTHER" value="2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ContactList">
<eStructuralFeatures xsi:type="ecore:EReference" name="contacts" upperBound="-1"
eType="#//Contact"/>
</eClassifiers>
Does anybody know this problem?
Mark
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #559280 is a reply to message #559270] |
Thu, 16 September 2010 05:07   |
Hi Mark,
The annotationsmodel seems to be illegal xml (maybe my copy-paste). Can you enter a bugzilla and attach the files to it?
Then I can add them to the test suite.
gr. Martin
On 09/16/2010 10:47 AM, Mark Hoffmann wrote:
> Hi Martin,
> I looked into it a little bit. You're right the classifier id's are
> wrong. I changed it in the generated code by hand and everything works.
> Regarding the enum problem:
> I have an ecore with enums. I create an annotionsmodel from this ecore.
> I changed the package path, model class package path as well as the
> qualified class names for the classes and enums in the annotionsmodel.
> When I generate the model code, for classes everything is fine. The enum
> java code contains the annotationsmodel package definition. but the
> java-file is generated in the original folder from the standard
> defintion. It should be generated in the folder structure from the
> annotionsmodel.
> Further there are some wrong paths in the generated factory. You will
> see it, when you generate code from this ecore and annotationsmodel.
> I can send you ecore and model so i paste it here:
> ECORE:
> <ecore:EPackage xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
> nsURI="http://test" nsPrefix="test">
> <eClassifiers xsi:type="ecore:EClass" name="Person">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="firstname"
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="lastname"
> <eStructuralFeatures xsi:type="ecore:EReference" name="address"
> lowerBound="1"
> eType="#//Address"/>
> upperBound="-1"
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="Address">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="street"
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="city"
> </eClassifiers>
> </eClassifiers>
> <eLiterals name="PHONE"/>
> <eLiterals name="EMAIL" value="1"/>
> </eClassifiers>
> </ecore:EPackage>
> Annotationsmodel:
> <?xml version="1.0" encoding="ASCII"?>
> <annotationsmodel:AnnotatedModel xmi:version="2.0"
> xmlns:annotationsmodel="http://www.eclipse.org/emf/texo/annotations/model"
> xmlns:modelannotations=" http://www.eclipse.org/emf/texo/modelgenerator/modelannotati ons">
> <annotatedEPackages>
> <ePackage href="test.ecore#/"/>
> <ePackageAnnotations
> xsi:type="modelannotations:EPackageModelGenAnnotation" name="test"
> packagePath="texo.test" modelClassesPackagePath="texo.test"
> qualifiedClassName="test.TestModelPackage"
> simpleClassName="TestModelPackage"
> simpleModelFactoryClassName="TestModelFactory" ecoreFileContent="<?xml
> version="1.0" encoding="UTF-8"?>
> lowerBound="1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> " ecoreFileName="test.ecore"/>
> <annotatedEClassifiers xsi:type="annotationsmodel:AnnotatedEClass">
> <eClass href="test.ecore#//Person"/>
> <eClassAnnotations xsi:type="modelannotations:EClassModelGenAnnotation"
> name="Person" qualifiedClassName="texo.test.Person"
> simpleClassName="Person" generateCode="true"
> ownerEPackageAnnotation="//@annotatedEPackages.0/@ePackageAnnotations.0 "
> hasManyFeatures="true" hasSuperEClass="false" serializable="false"
> abstract="false"/>
> <annotatedEStructuralFeatures
> xsi:type="annotationsmodel:AnnotatedEAttribute">
> <eAttribute href="test.ecore#//Person/firstname"/>
> <eAttributeAnnotations
> xsi:type="modelannotations:EAttributeModelGenAnnotation"
> name="firstname" getter="getFirstname" type="java.lang.String"
> objectType="java.lang.String" itemType="java.lang.String"
> defaultValue="null" setter="setFirstname"
> validJavaMemberName="firstname" many="false" useList="false"
> reference="false"
> ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.0/@eClassAnno tations.0 "
> boolean="false" primitive="false"/>
> </annotatedEStructuralFeatures>
> <eAttribute href="test.ecore#//Person/lastname"/>
> xsi:type="modelannotations:EAttributeModelGenAnnotation" name="lastname"
> getter="getLastname" type="java.lang.String"
> defaultValue="null" setter="setLastname" validJavaMemberName="lastname"
> many="false" useList="false" reference="false"
> xsi:type="annotationsmodel:AnnotatedEReference">
> <eReference href="test.ecore#//Person/address"/>
> <eReferenceAnnotations
> xsi:type="modelannotations:EReferenceModelGenAnnotation" name="address"
> getter="getAddress" type="test.Address" objectType="test.Address"
> itemType="test.Address" defaultValue="null" setter="setAddress"
> validJavaMemberName="address" many="false" useList="false"
> reference="true"
> generateSafeManyAccess="true"/>
> <eReference href="test.ecore#//Person/contacts"/>
> xsi:type="modelannotations:EReferenceModelGenAnnotation" name="contacts"
> getter="getContacts" type="java.util.List<test.Contact>"
> objectType="java.util.List<test.Contact>" itemType="test.Contact"
> defaultValue="new java.util.ArrayList<test.Contact>()"
> setter="setContacts" validJavaMemberName="contacts" many="true"
> useList="true" reference="true"
> </annotatedEClassifiers>
> <eClass href="test.ecore#//Address"/>
> name="Address" qualifiedClassName="texo.test.Address"
> simpleClassName="Address" generateCode="true"
> hasSuperEClass="false" serializable="false" abstract="false"/>
> <eAttribute href="test.ecore#//Address/street"/>
> xsi:type="modelannotations:EAttributeModelGenAnnotation" name="street"
> getter="getStreet" type="java.lang.String" objectType="java.lang.String"
> itemType="java.lang.String" defaultValue="null" setter="setStreet"
> validJavaMemberName="street" many="false" useList="false"
> reference="false"
> ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.1/@eClassAnno tations.0 "
> <eAttribute href="test.ecore#//Address/city"/>
> xsi:type="modelannotations:EAttributeModelGenAnnotation" name="city"
> getter="getCity" type="java.lang.String" objectType="java.lang.String"
> itemType="java.lang.String" defaultValue="null" setter="setCity"
> validJavaMemberName="city" many="false" useList="false"
> reference="false"
> <eClass href="test.ecore#//Contact"/>
> name="Contact" qualifiedClassName="texo.test.Contact"
> simpleClassName="Contact" generateCode="true"
> <eAttribute href="test.ecore#//Contact/value"/>
> xsi:type="modelannotations:EAttributeModelGenAnnotation" name="value"
> getter="getValue" type="java.lang.String" objectType="java.lang.String"
> itemType="java.lang.String" defaultValue="null" setter="setValue"
> validJavaMemberName="value" many="false" useList="false"
> reference="false"
> ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.2/@eClassAnno tations.0 "
> <eAttribute href="test.ecore#//Contact/type"/>
> xsi:type="modelannotations:EAttributeModelGenAnnotation" name="type"
> getter="getType" type="test.ContactType" objectType="test.ContactType"
> itemType="test.ContactType" defaultValue="test.ContactType.PHONE"
> setter="setType" validJavaMemberName="type" many="false" useList="false"
> reference="false"
> <annotatedEClassifiers xsi:type="annotationsmodel:AnnotatedEEnum">
> <eEnum href="test.ecore#//ContactType"/>
> <eEnumAnnotations xsi:type="modelannotations:EEnumModelGenAnnotation"
> name="ContactType" qualifiedClassName="test.ContactType"
> simpleClassName="ContactType" generateCode="true"
> instanceClassName="texo.test.ContactType"
> objectClassName="test.ContactType" enum="true" dateType="false"
> automaticStringConversion="false" itemType="java.lang.Object"/>
> <annotatedEEnumLiterals>
> <eEnumLiteral href="test.ecore#//ContactType/PHONE"/>
> </annotatedEEnumLiterals>
> <eEnumLiteral href="test.ecore#//ContactType/EMAIL"/>
> </annotatedEPackages>
> </annotationsmodel:AnnotatedModel>
> Regards,
> Mark
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #559313 is a reply to message #559296] |
Thu, 16 September 2010 07:06   |
Hi Mark,
I checked the annotations model and there are some strange in there. For example the Address eclass annotation has this
eattribute:
however, the Person eclass has an ereference annotation for address with this eattribute:
type="test.Address"
This is the reason that there are compile errors in the generated code for the Person, as it refers to a type which does
not get generated. It is best to have a quite empty annotationsmodel (so only annotate what you want to change, the rest
is automatically generated). So to solve this I would remove all the ereference annotations.
To be sure, did you manually change the annotations model?
The reason that the ContactType enum is generated in a separate package is because its annotation has this eattribute set:
so therefore it ends up in the test package and not in the texo.test package.
gr. Martin
On 09/16/2010 12:02 PM, Mark Hoffmann wrote:
> Hi Martin,
> there are two new bugs:
> - 325427 regarding the wron classifier id's
> - 325429 regarding some generation problems
The Netherlands
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #623216 is a reply to message #559236] |
Thu, 16 September 2010 04:47  |
Hi Martin,
I looked into it a little bit. You're right the classifier id's are wrong. I changed it in the generated code by hand and everything works.
I have an ecore with enums. I create an annotionsmodel from this ecore. I changed the package path, model class package path as well as the qualified class names for the classes and enums in the annotionsmodel.
When I generate the model code, for classes everything is fine. The enum java code contains the annotationsmodel package definition. but the java-file is generated in the original folder from the standard defintion. It should be generated in the folder structure from the annotionsmodel.
Further there are some wrong paths in the generated factory. You will see it, when you generate code from this ecore and annotationsmodel.
ECORE:
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstname" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastname" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="address" lowerBound="1"
</eClassifiers>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="street" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="city" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" eType="#//ContactType"/>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
Annotationsmodel:
<annotationsmodel:AnnotatedModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:annotationsmodel="http://www.eclipse.org/emf/texo/annotations/model" xmlns:modelannotations=" http://www.eclipse.org/emf/texo/modelgenerator/modelannotati ons">
<ePackageAnnotations xsi:type="modelannotations:EPackageModelGenAnnotation" name="test" packagePath="texo.test" modelClassesPackagePath="texo.test" qualifiedClassName="test.TestModelPackage" simpleClassName="TestModelPackage" simpleModelFactoryClassName="TestModelFactory" ecoreFileContent="<?xml version="1.0" encoding="UTF-8"?>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
<eClassAnnotations xsi:type="modelannotations:EClassModelGenAnnotation" name="Person" qualifiedClassName="texo.test.Person" simpleClassName="Person" generateCode="true" ownerEPackageAnnotation="//@annotatedEPackages.0/@ePackageAnnotations.0 " hasManyFeatures="true" hasSuperEClass="false" serializable="false" abstract="false"/>
<annotatedEStructuralFeatures xsi:type="annotationsmodel:AnnotatedEAttribute">
<eAttributeAnnotations xsi:type="modelannotations:EAttributeModelGenAnnotation" name="firstname" getter="getFirstname" type="java.lang.String" objectType="java.lang.String" itemType="java.lang.String" defaultValue="null" setter="setFirstname" validJavaMemberName="firstname" many="false" useList="false" reference="false" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.0/@eClassAnno tations.0 " boolean="false" primitive="false"/>
<eAttributeAnnotations xsi:type="modelannotations:EAttributeModelGenAnnotation" name="lastname" getter="getLastname" type="java.lang.String" objectType="java.lang.String" itemType="java.lang.String" defaultValue="null" setter="setLastname" validJavaMemberName="lastname" many="false" useList="false" reference="false" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.0/@eClassAnno tations.0 " boolean="false" primitive="false"/>
<annotatedEStructuralFeatures xsi:type="annotationsmodel:AnnotatedEReference">
<eReferenceAnnotations xsi:type="modelannotations:EReferenceModelGenAnnotation" name="address" getter="getAddress" type="test.Address" objectType="test.Address" itemType="test.Address" defaultValue="null" setter="setAddress" validJavaMemberName="address" many="false" useList="false" reference="true" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.0/@eClassAnno tations.0 " generateSafeManyAccess="true"/>
<eReferenceAnnotations xsi:type="modelannotations:EReferenceModelGenAnnotation" name="contacts" getter="getContacts" type="java.util.List<test.Contact>" objectType="java.util.List<test.Contact>" itemType="test.Contact" defaultValue="new java.util.ArrayList<test.Contact>()" setter="setContacts" validJavaMemberName="contacts" many="true" useList="true" reference="true" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.0/@eClassAnno tations.0 " generateSafeManyAccess="true"/>
<eClassAnnotations xsi:type="modelannotations:EClassModelGenAnnotation" name="Address" qualifiedClassName="texo.test.Address" simpleClassName="Address" generateCode="true" ownerEPackageAnnotation="//@annotatedEPackages.0/@ePackageAnnotations.0 " hasSuperEClass="false" serializable="false" abstract="false"/>
<eAttributeAnnotations xsi:type="modelannotations:EAttributeModelGenAnnotation" name="street" getter="getStreet" type="java.lang.String" objectType="java.lang.String" itemType="java.lang.String" defaultValue="null" setter="setStreet" validJavaMemberName="street" many="false" useList="false" reference="false" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.1/@eClassAnno tations.0 " boolean="false" primitive="false"/>
<eAttributeAnnotations xsi:type="modelannotations:EAttributeModelGenAnnotation" name="city" getter="getCity" type="java.lang.String" objectType="java.lang.String" itemType="java.lang.String" defaultValue="null" setter="setCity" validJavaMemberName="city" many="false" useList="false" reference="false" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.1/@eClassAnno tations.0 " boolean="false" primitive="false"/>
<eClassAnnotations xsi:type="modelannotations:EClassModelGenAnnotation" name="Contact" qualifiedClassName="texo.test.Contact" simpleClassName="Contact" generateCode="true" ownerEPackageAnnotation="//@annotatedEPackages.0/@ePackageAnnotations.0 " hasSuperEClass="false" serializable="false" abstract="false"/>
<eAttributeAnnotations xsi:type="modelannotations:EAttributeModelGenAnnotation" name="value" getter="getValue" type="java.lang.String" objectType="java.lang.String" itemType="java.lang.String" defaultValue="null" setter="setValue" validJavaMemberName="value" many="false" useList="false" reference="false" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.2/@eClassAnno tations.0 " boolean="false" primitive="false"/>
<eAttributeAnnotations xsi:type="modelannotations:EAttributeModelGenAnnotation" name="type" getter="getType" type="test.ContactType" objectType="test.ContactType" itemType="test.ContactType" defaultValue="test.ContactType.PHONE" setter="setType" validJavaMemberName="type" many="false" useList="false" reference="false" ownerEClassAnnotation=" //@annotatedEPackages.0/@annotatedEClassifiers.2/@eClassAnno tations.0 " boolean="false" primitive="false"/>
<eEnumAnnotations xsi:type="modelannotations:EEnumModelGenAnnotation" name="ContactType" qualifiedClassName="test.ContactType" simpleClassName="ContactType" generateCode="true" ownerEPackageAnnotation="//@annotatedEPackages.0/@ePackageAnnotations.0 " instanceClassName="texo.test.ContactType" objectClassName="test.ContactType" enum="true" dateType="false" automaticStringConversion="false" itemType="java.lang.Object"/>
Mark
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #623218 is a reply to message #623216] |
Hi Mark,
gr. Martin
> Hi Martin,
> annotionsmodel.
> ECORE:
> lowerBound="1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> Annotationsmodel:
> lowerBound="1"
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> abstract="false"/>
> reference="false"
> reference="true"
> reference="false"
> reference="false"
> reference="false"
> reference="false"
> Regards,
> Mark
The Netherlands
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #623222 is a reply to message #623220] |
Hi Mark,
eattribute:
type="test.Address"
gr. Martin
> Hi Martin,
The Netherlands
Re: [TEXO] Problem with ClassCastException in ModelPackage [message #623225 is a reply to message #559313] |
Thu, 16 September 2010 11:20  |
Hi Martin,
I gave a detailed answer in the bug#325429.
My intention was to get a result like the Base Package attribute in genmodel.
I just want to generate my model not in the package given from ecore. Instead I want to have it in my projects convention.
This means like in the code, generated by the gemodel, to change the references autoamtically.
So if I had the "base package" attribute in the annotionsmodel, I could simply add the base package before the defined package from the ecore. Thats it. You have to do this for eRefrences as well.
Do you know what I mean?
Mark
FUDForum. Page generated in 0.70654 seconds
