Validating an EMF model programatically [message #535839] |
Tue, 25 May 2010 19:23  |
Hi everyone, I posted this question a couple of days ago in the UML forum but it seems that I should have used the EMF newsgroup instead, so I'm just moving the message.
I was going over the EMF Validation Framework example and I was able to set everything up and add a few extra constraints. Then I run the plugin as an eclipse application, I create the model and then in the editor menu I can select validate to check the constraints and everything works fine.
But I was wondering if it is possible to validate a model programmatically, without using the editor.
// For example, create a few objects:
Book myBook = EXTLibraryFactory.eINSTANCE.createBook();
myBook.setTitle("EMF Validation");
Writer writer = EXTLibraryFactory.eINSTANCE.createWriter();
writer.setName("Hector");
//And then do the validation
I've been searching the web with no luck. Can something like this be done? I would appreciate any hints.
Thanks.
Re: Validating an EMF model programatically [message #536002 is a reply to message #535999] |
Wed, 26 May 2010 11:45  |
I see, after searching for a while on the internet that seems to be the consensus. I'll see if I can find an alternative. Thanks for your help.
Hector
Ed Merks wrote on Wed, 26 May 2010 11:26 | Hector,
Not all the frameworks support running stand alone. I think you'll need
to run this as an Eclipse application.
Hector Chavez wrote:
> Thanks Jonas,
> I tried the that approach but it did not work in my example, I get an
> exception, this is the code I'm using:
> University univ = UniversityFactory.eINSTANCE.createUniversity();
> ValidationDelegateClientSelector.running = true;
> IBatchValidator validator = (IBatchValidator)
> ModelValidationService.getInstance().newValidator(Evaluation Mode.BATCH);
> validator.setIncludeLiveConstraints(true);
> IStatus status = validator.validate(univ);
> ValidationDelegateClientSelector.running = false;
> And the exception:
> Exception in thread "main" java.lang.ExceptionInInitializerError
> at emf.examples.university.validation.adapter.EValidatorAdapter .
> <init>(EValidatorAdapter.java:57)
> at university.tests.Main.main(Main.java:23)
> Caused by: java.lang.NullPointerException
> at org.eclipse.emf.validation.internal.EMFModelValidationPlugin
> .getPluginId(EMFModelValidationPlugin.java:201)
> at org.eclipse.emf.validation.service.ModelValidationService.co
> nfigureConstraints(ModelValidationService.java:144)
> at org.eclipse.emf.validation.service.ModelValidationService.<init
> >(ModelValidationService.java:134)
> at
> org.eclipse.emf.validation.service.ModelValidationService.<clinit
> >(ModelValidationService.java:83)
> ... 2 more
> Jonas wrote on Wed, 26 May 2010 03:16
>> Hi,
>> it should work like this:
>> YourValidationClientSelector.setRunning(true);
>> Mode.BATCH);
>> IStatus status = validator.validate(object);
>> ValidationClientSelector.setRunning(false);
>> Furthermore I would look into the existing handler of the editor...
>> Cheers
>> Jonas
Re: Validating an EMF model programatically [message #622938 is a reply to message #535873] |
Wed, 26 May 2010 11:10  |
Thanks Jonas,
I tried the that approach but it did not work in my example, I get an exception, this is the code I'm using:
IBatchValidator validator = (IBatchValidator) ModelValidationService.getInstance().newValidator(Evaluation Mode.BATCH);
And the exception:
at emf.examples.university.validation.adapter.EValidatorAdapter . <init>(EValidatorAdapter.java:57)
at org.eclipse.emf.validation.internal.EMFModelValidationPlugin .getPluginId(EMFModelValidationPlugin.java:201)
at org.eclipse.emf.validation.service.ModelValidationService.co nfigureConstraints(ModelValidationService.java:144)
at org.eclipse.emf.validation.service.ModelValidationService.<init >(ModelValidationService.java:134)
at org.eclipse.emf.validation.service.ModelValidationService.<clinit >(ModelValidationService.java:83)
... 2 more
> Cheers
> Jonas
Re: Validating an EMF model programatically [message #622939 is a reply to message #622938] |
Hector,
> Thanks Jonas,
> And the exception:
> at
> ... 2 more
>> Hi,
>> Mode.BATCH);
>> Cheers
>> Jonas
Re: Validating an EMF model programatically [message #622940 is a reply to message #535999] |
Hector
> Hector,
> > Thanks Jonas,
> > And the exception:
> > at
> > ... 2 more
> >> Hi,
> >> Mode.BATCH);
> >> Cheers
> >> Jonas
FUDForum. Page generated in 0.20214 seconds
