Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Child comparison problem(EMF Compare incorrectly compares same-name children of different parents)
Child comparison problem [message #534562] |
Wed, 19 May 2010 10:31  |
I will be glad for any advice on how to overcome the problem I've encountered when using EMF compare on my model. The essence of the problem is the following:
Let's say I have a model with two objects at root: A and B. Both have a child named C (same name, but different content). When I compare the two copies of the model there are obviously no differences. But as soon as I make a change to one model, say add a new object D to a root, I get not just one difference (D has been added), but three (B.C removed, B.C added, D added).
What I have at the moment is a custom MatchEngine with overridden methods isSimilar(...), findMostSimilar(...) etc. I'd like to know what must be implemented to fix this issue?
Vitaly
[Updated on: Wed, 19 May 2010 10:31] by Moderator
Re: Child comparison problem [message #534728 is a reply to message #534562] |
Thu, 20 May 2010 03:24   |
--------------010702090606010302060400
Hi Vitaly,
The "isSimilar()" method you overrode in your custom match engine is
what's causing problems here. Namely, if "isSimilar()" returns false for
your objects "B.C" for any reason, you will get two diffs : "B.C has
been removed" and "B.C has been added".
You'll have to double check your implementation of isSimilar to find why
you're returning false when the two parameters are your "C" objects.
Laurent Goubet
Obeo
Vitaly Savickas wrote:
> Hello,
> added, D added).
> Regards,
> Vitaly
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010702090606010302060400--
Re: Child comparison problem [message #535057 is a reply to message #534931] |
Fri, 21 May 2010 04:04   |
Hi Vitaly,
If you want to ignore this ID attribute you should pass the corresponding
options (for intrinsic or XMI ID's:
Map options = new HashMap();
options.put(MatchOptions.OPTION_IGNORE_XMI_ID, Boolean.TRUE);
options.put(MatchOptions.OPTION_IGNORE_ID, Boolean.TRUE);
As a sidenote I fixed a regression about the root elements matching this
week, it would be safer for you to use the RC1 (or the CVS HEAD).
Cédric
> Vitaly Savickas wrote on Thu, 20 May 2010 06:09
>> Thanks Laurent.
>> Yes, I understand that isSimilar(...) must be responsible for that, but
>> this is also the reason I am confused about this problem: when I debugged
>> the whole compare process of two models isSimilar(...) was always true.
>> I've also noticed that it didn't even get called on the B.C. I have a
>> slight guess that it makes an assumption on the list of objects matched
>> by their names and after C has matched it is never looked at again, but
>> I'm not familiar with the algorithm so sorry if I'm wrong. Any ideas on
>> why is it behaving this way?
>> Vitaly
> I've investigated it further and revealed that isSimilar(...) is ignored
> for B.C because of this bit of code in the mapLists(...) method of
> GenericMatchEngine:
> final StringBuilder obj1Key = new StringBuilder();
> obj1Key.append(NameSimilarity.findName(obj1));
> obj1Key.append(obj1.hashCode());
> EObject obj2 = matchedByID.get(obj1Key.toString());
> if (notFoundList1.contains(obj1) && notFoundList2.contains(obj2) &&
> isSimilar(obj1, obj2)) { ...
> in which matchedByID returns me the same A.C for B.C. Those two are
> obviously not the same and the condition doesn't hold. This happens
> because the matchedByID map is constructed on the object IDs, and my model
> treats the names as IDs. It is incorrect in a sense that there are two C
> objects of the same ID, but we have no problems with this for now. So can
> anyone please suggest is there a way to match it not just by IDs? Can this
> mechanism be overridden?
> Vitaly
Re: Child comparison problem [message #622919 is a reply to message #622918] |
Hi Vitaly,
Cédric
>> Thanks Laurent.
>> Vitaly
> GenericMatchEngine:
> Vitaly
Current Time: Wed Jul 23 13:31:46 EDT 2025
Powered by FUDForum. Page generated in 0.08600 seconds
