Home » Modeling » UML2 » using the uml2 code generator
using the uml2 code generator [message #473277] Mon, 25 June 2007 05:05 Go to next message
Originally posted by: rbernard.extreme-modeling-software.com
Is it possible to use the extended emf generator provided by uml2 for
another purpose than generating uml.ecore ?
If yes, what is the procedure to set up such a project ?
Thanks in advance
regards
Romain
Re: using the uml2 code generator [message #473284 is a reply to message #473277] Mon, 25 June 2007 12:09 Go to previous messageGo to next message
Hi Romain,
If I understand this correctly, you will want to have a look at the
UML2EcoreConverter in UMLUtil. That is the heart behind the UML to ecore
conversion process. You can create a subclass and override any of the
caseXXX() to do what you want ( or extend it in any way ).
If there is functionality lacking you might want to raise a bugzilla.
- James.
"Romain BERNARD" <rbernard@extreme-modeling-software.com> wrote in message
news:f5o0g9$ssn$1@build.eclipse.org...
> Thanks in advance
> regards
> Romain
Re: using the uml2 code generator [message #473288 is a reply to message #473284] Mon, 25 June 2007 12:48 Go to previous messageGo to next message
Thank you for your response!
but I was not clear enough, I guess....
What I want to do is generating my own "mydsl.ecore" using the extended uml2
emf generator (not the standard emf one), so I can benefit of extended
functionalities such as "generating derived relations, cache adapter
support, factory methods, invariant prefixes, "pluralized" getters, safe
strings, operation utility classes, resource interfaces, etc."
regards
Romain
"James Bruck" <jbruck@ca.ibm.com> a
Re: using the uml2 code generator [message #473309 is a reply to message #473288] Tue, 26 June 2007 11:12 Go to previous messageGo to next message
Hi Romain,
To extend the uml gen model options (gen features) for things like
"pluralize getters" have a look at org.eclipse.uml2.codegen.ecore.
- James.
news:f5orku$5aq$1@build.eclipse.org...
uml2
> regards
> Romain
Re: using the uml2 code generator [message #473311 is a reply to message #473288] Tue, 26 June 2007 11:21 Go to previous messageGo to next message
Hi, Romain,
Do you just want to generate code from a UML model instead of from an Ecore
model? The OCL component of MDT does exactly that.
When you create your genmodel using the "New EMF Model" wizard, just select
your UML model as the input instead of an Ecore model. The wizard has a
variety of options that pertain to the process of converting the UML to a
suitable Ecore representation for UML2's codegen extensions. You will also
find some UML-specific properties on the root GenModel element of the
genmodel, that determine whether to user cache adapters, operation classes,
etc.
Christian
> uml2 emf generator (not the standard emf one), so I can benefit of
> extended functionalities such as "generating derived relations, cache
> adapter support, factory methods, invariant prefixes, "pluralized"
> getters, safe strings, operation utility classes, resource interfaces,
> etc."
> regards
> Romain
> "James Bruck" <jbruck@ca.ibm.com> a �rit dans le message de news:
> f5opc8$ptt$2@build.eclipse.org...
>> Hi Romain,
>> ecore
>> Cheers,
>> - James.
>> message news:f5o0g9$ssn$1@build.eclipse.org...
>>> Thanks in advance
>>> regards
>>> Romain
Re: using the uml2 code generator [message #473319 is a reply to message #473309] Wed, 27 June 2007 08:12 Go to previous messageGo to next message
Yes ! that's exactly what I mean... Sorry, I should have titled this post
"using the org.eclipse.uml2.codegen.ecore generator"...
And the only way I found to use it was to make my own .genmodel by hands
(copy & paste the content of uml2.genmodel in another file (mydsl.genmodel),
removing all except the root package, renaming and linking to mydsl.ecore
file. It worked, but :
- I was wondering if there were a better way to initialize my genmodel
- I have no predefined ideas about the meaning of certain number of
genAnnotations (genmodel) and eAnnotations (ecore model) that will influence
the generation, like :
<genAnnotations
source=" http://www.eclipse.org/emf/2002/GenModel/importer/org.eclips e.uml2.uml.ecore.importer">
<details key="DUPLICATE_FEATURES" value="PROCESS"/>
<details key="DUPLICATE_FEATURE_INHERITANCE" value="PROCESS"/>
<details key="REDEFINING_PROPERTIES" value="PROCESS"/>
<details key="DUPLICATE_OPERATIONS" value="PROCESS"/>
<details key="DERIVED_FEATURES" value="PROCESS"/>
<details key="SUBSETTING_PROPERTIES" value="PROCESS"/>
<details key="ECORE_TAGGED_VALUES" value="PROCESS"/>
<details key="REDEFINING_OPERATIONS" value="PROCESS"/>
<details key="ANNOTATION_DETAILS" value="PROCESS"/>
<details key="SUPER_CLASS_ORDER" value="PROCESS"/>
<details key="UNION_PROPERTIES" value="PROCESS"/>
<details key="DUPLICATE_OPERATION_INHERITANCE" value="PROCESS"/>
</genAnnotations>
or
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="element"/>
</eAnnotations>
The others are easier to undestand :
<eAnnotations source="union"/>
<eAnnotations source="subsets" references="#//Element/ownedElement"/>
<eAnnotations source="duplicates">
<contents xsi:type="ecore:EOperation" name="mustBeOwned" ordered="false"
lowerBound="1" eType="#//Boolean">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value="The query mustBeOwned()
indicates whether elements of this type must have an owner.&#xD;&#xA;result
= false"/>
</eAnnotations>
<eAnnotations source="redefines"
references="#//Element/mustBeOwned"/>
</contents>
</eAnnotations>
I did not find specific information about how to set up properly my
..genmodel file, all the different types of Annotations, and I was asking if
there was any documentation that could help me... If not, I will have a look
at the source code of the org.eclipse.uml2.codegen.ecore generator...
Romain
Re: using the uml2 code generator [message #473326 is a reply to message #473319] Wed, 27 June 2007 09:47 Go to previous messageGo to next message
Hi Romain,
Unfortunately, there is no documentation listing the resulting annotations
and the exact effect these options have. Some of them might be self
explanatory by virtue of their names but they should be documented fully.
Several documents are being worked on as we speak and this is the topic of
one of them.
For now, having a look at the source code is the best way to figure these
out. I will post a document as soon as it becomes available.
Good luck,
- James.
news:f5tk8i$2bl$1@build.eclipse.org...
(mydsl.genmodel),
influence
> <genAnnotations
ml.ecore.importer">
> </genAnnotations>
> or
> <eAnnotations
> </eAnnotations>
ordered="false"
> = false"/>
> </eAnnotations>
> </contents>
> </eAnnotations>
if
look
> Cheers,
> Romain
Re: using the uml2 code generator [message #473331 is a reply to message #473326] Wed, 27 June 2007 10:21 Go to previous message
Thank you James !
Re: using the uml2 code generator [message #622559 is a reply to message #473277] Mon, 25 June 2007 12:09 Go to previous message
Hi Romain,
- James.
> Thanks in advance
> regards
> Romain
Re: using the uml2 code generator [message #622563 is a reply to message #473284] Mon, 25 June 2007 12:48 Go to previous message
regards
Romain
Re: using the uml2 code generator [message #622574 is a reply to message #473288] Tue, 26 June 2007 11:12 Go to previous message
Hi Romain,
- James.
uml2
> regards
> Romain
Re: using the uml2 code generator [message #622575 is a reply to message #473288] Tue, 26 June 2007 11:21 Go to previous message
Hi, Romain,
etc.
Christian
> etc."
> regards
> Romain
>> Hi Romain,
>> ecore
>> Cheers,
>> - James.
>>> Thanks in advance
>>> regards
>>> Romain
Re: using the uml2 code generator [message #622582 is a reply to message #473309] Wed, 27 June 2007 08:12 Go to previous message
<genAnnotations
</genAnnotations>
or
</eAnnotations>
= false"/>
</eAnnotations>
</contents>
</eAnnotations>
Romain
Re: using the uml2 code generator [message #622586 is a reply to message #473319] Wed, 27 June 2007 09:47 Go to previous message
Hi Romain,
one of them.
Good luck,
- James.
(mydsl.genmodel),
influence
> <genAnnotations
ml.ecore.importer">
> </genAnnotations>
> or
> <eAnnotations
> </eAnnotations>
ordered="false"
> = false"/>
> </eAnnotations>
> </contents>
> </eAnnotations>
if
look
> Cheers,
> Romain
Re: using the uml2 code generator [message #622591 is a reply to message #473326] Wed, 27 June 2007 10:21 Go to previous message
Thank you James !
Previous Topic:Model import and referencing
Next Topic:org.eclipse.emf.ecore.xmi.IllegalValueException
Current Time: Wed Jul 23 12:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.12746 seconds
