Home » Modeling » UML2 » Issues with MagicDraw Models in New EMF Project
Issues with MagicDraw Models in New EMF Project [message #473282] Mon, 25 June 2007 12:03 Go to next message
I am running MagicDraw 12.1 and on the Eclipse Side I have enclosed the
configuration file.
The problem:
I exported a large model from MagicDraw to EMF UML Format. The result
was a directory that had six files, all with the extension ".uml2". Of
the six files. four came from MagicDraw profiles, one is my model and
the last one is the profile that I am using with the model.
I successfully imported the model when creating a new EMF project and I
successfully generated code from it. Pretty neat huh.
The problem is that the model import generated a lot of errors. I
attached the details that were given by the importer.
Are the errors really serious or are they nuisance errors. How do I tell?
Also, has anyone seen this before?
========================== Model Load ==================================
Problems were encountered processing the models
Processed Ecore tag 'Ecore::EPackage::packageName' with value of
'uml' for model element 'uml'.
Processed Ecore tag 'Ecore::EPackage::nsPrefix' with value of 'uml'
Processed Ecore tag 'Ecore::EPackage::nsURI' with value of
'http://www.eclipse.org/uml2/2.0.0/UML' for model element 'uml'.
Processed Ecore tag 'Ecore::EClassifier::instanceClassName' with
value of 'int' for model element 'uml::Integer'.
value of 'boolean' for model element 'uml::Boolean'.
value of 'java.lang.String' for model element 'uml::String'.
value of 'int' for model element 'uml::UnlimitedNatural'.
Processed Ecore tag 'Ecore::EStructuralFeature::isUnsettable' with
value of 'true' for model element 'uml::Comment::body'.
Processed Ecore tag 'Ecore::EStructuralFeature::xmlFeatureKind' with
value of 'Ecore::FeatureKind::Element' for model element
Processed Ecore tag 'Ecore::EStructuralFeature::isTransient' with
value of 'true' for model element 'uml::Relationship::relatedElement'.
value of 'true' for model element 'uml::DirectedRelationship::source'.
value of 'true' for model element 'uml::DirectedRelationship::target'.
value of 'true' for model element 'uml::NamedElement::name'.
value of 'true' for model element 'uml::NamedElement::visibility'.
value of 'true' for model element 'uml::NamedElement::qualifiedName'.
value of 'true' for model element 'uml::NamedElement::namespace'.
value of 'true' for model element 'uml::Namespace::ownedMember'.
value of 'true' for model element 'uml::ElementImport::alias'.
value of 'true' for model element 'uml::Package::ownedType'.
value of 'true' for model element 'uml::Type::package'.
'uml::RedefinableElement::redefinedElement'.
'uml::RedefinableElement::redefinitionContext'.
value of 'true' for model element 'uml::Generalization::isSubstitutable'.
value of 'true' for model element 'uml::Classifier::feature'.
value of 'true' for model element 'uml::Feature::featuringClassifier'.
value of 'true' for model element 'uml::Classifier::inheritedMember'.
value of 'true' for model element 'uml::Classifier::general'.
value of 'true' for model element 'uml::OpaqueExpression::body'.
value of 'true' for model element 'uml::OpaqueExpression::language'.
value of 'true' for model element 'uml::OpaqueExpression::result'.
value of 'true' for model element 'uml::MultiplicityElement::upper'.
value of 'true' for model element 'uml::MultiplicityElement::lower'.
Processed Ecore tag 'Ecore::EOperation::operationName' with value of
'getLower' for model element 'uml::MultiplicityElement::lower'.
'getUpper' for model element 'uml::MultiplicityElement::upper'.
value of 'true' for model element 'uml::ConnectorEnd::definingEnd'.
value of 'true' for model element 'uml::Artifact::fileName'.
value of 'true' for model element 'uml::Transition::redefinitionContext'.
value of 'true' for model element 'uml::Port::required'.
value of 'true' for model element 'uml::Port::provided'.
value of 'true' for model element 'uml::State::isComposite'.
value of 'true' for model element 'uml::State::isOrthogonal'.
value of 'true' for model element 'uml::State::isSimple'.
value of 'true' for model element 'uml::State::isSubmachineState'.
value of 'true' for model element 'uml::State::redefinitionContext'.
value of 'true' for model element 'uml::Region::redefinitionContext'.
value of 'true' for model element 'uml::StructuredClassifier::part'.
value of 'true' for model element 'uml::StructuredClassifier::role'.
value of 'true' for model element 'uml::Connector::kind'.
value of 'true' for model element 'uml::EncapsulatedClassifier::ownedPort'.
value of 'true' for model element 'uml::Class::superClass'.
value of 'true' for model element 'uml::Class::extension'.
value of 'true' for model element 'uml::Extension::metaclass'.
value of 'true' for model element 'uml::Extension::isRequired'.
value of 'true' for model element 'uml::Image::content'.
value of 'true' for model element 'uml::Image::location'.
value of 'true' for model element 'uml::Image::format'.
value of 'true' for model element 'uml::Profile::ownedStereotype'.
'ecore' for model element 'ecore'.
Processed Ecore tag 'Ecore::EPackage::nsPrefix' with value of 'ecore'
'http://www.eclipse.org/emf/2002/Ecore' for model element 'ecore'.
value of 'java.lang.String' for model element 'ecore::EString'.
value of 'true' for model element 'ecore::EAnnotation::source'.
value of 'java.util.Map$Entry' for model element
'ecore::EStringToStringMapEntry'.
value of 'true' for model element 'ecore::EStringToStringMapEntry::key'.
value of 'true' for model element 'ecore::EStringToStringMapEntry::value'.
value of 'true' for model element 'ecore::ENamedElement::name'.
value of 'boolean' for model element 'ecore::EBoolean'.
value of 'true' for model element 'ecore::ETypedElement::lowerBound'.
value of 'int' for model element 'ecore::EInt'.
value of 'true' for model element 'ecore::ETypedElement::many'.
Processed Ecore tag 'Ecore::EStructuralFeature::isVolatile' with
value of 'true' for model element 'ecore::ETypedElement::required'.
value of 'true' for model element 'ecore::EClassifier::instanceClassName'.
value of 'true' for model element 'ecore::EClassifier::instanceClass'.
value of 'java.lang.Class' for model element 'ecore::EJavaClass'.
value of 'true' for model element 'ecore::EClassifier::defaultValue'.
value of 'java.lang.Object' for model element 'ecore::EJavaObject'.
value of 'true' for model element 'ecore::EClassifier::ePackage'.
value of 'true' for model element 'ecore::EPackage::nsURI'.
value of 'true' for model element 'ecore::EPackage::nsPrefix'.
value of 'true' for model element 'ecore::EPackage::eFactoryInstance'.
value of 'true' for model element 'ecore::EFactory::ePackage'.
value of 'true' for model element 'ecore::EClass::abstract'.
value of 'true' for model element 'ecore::EClass::interface'.
value of 'true' for model element 'ecore::EOperation::eContainingClass'.
value of 'true' for model element 'ecore::EParameter::eOperation'.
value of 'true' for model element 'ecore::EClass::eAllAttributes'.
value of 'true' for model element 'ecore::EClass::eAllReferences'.
value of 'true' for model element 'ecore::EReference::container'.
value of 'true' for model element 'ecore::EReference::eReferenceType'.
value of 'true' for model element 'ecore::EClass::eReferences'.
value of 'true' for model element 'ecore::EClass::eAttributes'.
value of 'true' for model element 'ecore::EClass::eAllContainments'.
value of 'true' for model element 'ecore::EClass::eAllOperations'.
value of 'true' for model element 'ecore::EClass::eAllStructuralFeatures'.
value of 'true' for model element 'ecore::EClass::eAllSuperTypes'.
value of 'true' for model element 'ecore::EClass::eIDAttribute'.
'ecore::EStructuralFeature::eContainingClass'.
value of 'true' for model element 'ecore::EPackage::eSuperPackage'.
value of 'true' for model element 'ecore::EStructuralFeature::volatile'.
value of 'true' for model element 'ecore::EStructuralFeature::transient'.
'ecore::EStructuralFeature::defaultValueLiteral'.
value of 'true' for model element 'ecore::EStructuralFeature::defaultValue'.
value of 'true' for model element 'ecore::EStructuralFeature::unsettable'.
value of 'true' for model element 'ecore::EStructuralFeature::derived'.
value of 'true' for model element 'ecore::EAttribute::eAttributeType'.
value of 'true' for model element 'ecore::EEnumLiteral::eEnum'.
value of 'true' for model element 'ecore::EEnumLiteral::instance'.
value of 'org.eclipse.emf.common.util.Enumerator' for model element
'ecore::EEnumerator'.
value of 'true' for model element 'ecore::EEnumLiteral::literal'.
value of 'java.math.BigDecimal' for model element 'ecore::EBigDecimal'.
value of 'java.math.BigInteger' for model element 'ecore::EBigInteger'.
value of 'java.lang.Boolean' for model element 'ecore::EBooleanObject'.
value of 'byte' for model element 'ecore::EByte'.
value of 'byte[]' for model element 'ecore::EByteArray'.
value of 'java.lang.Byte' for model element 'ecore::EByteObject'.
value of 'char' for model element 'ecore::EChar'.
value of 'java.lang.Character' for model element 'ecore::ECharacterObject'.
value of 'java.util.Date' for model element 'ecore::EDate'.
value of 'org.eclipse.emf.common.util.DiagnosticChain' for model element
'ecore::EDiagnosticChain'.
value of 'double' for model element 'ecore::EDouble'.
value of 'java.lang.Double' for model element 'ecore::EDoubleObject'.
value of 'org.eclipse.emf.common.util.EList' for model element
'ecore::EEList'.
value of 'org.eclipse.emf.ecore.util.FeatureMap' for model element
'ecore::EFeatureMap'.
value of 'org.eclipse.emf.ecore.util.FeatureMap$Entry' for model element
'ecore::EFeatureMapEntry'.
value of 'float' for model element 'ecore::EFloat'.
value of 'java.lang.Float' for model element 'ecore::EFloatObject'.
value of 'java.lang.Integer' for model element 'ecore::EIntegerObject'.
value of 'long' for model element 'ecore::ELong'.
value of 'java.lang.Long' for model element 'ecore::ELongObject'.
value of 'java.util.Map' for model element 'ecore::EMap'.
value of 'org.eclipse.emf.ecore.resource.Resource' for model element
'ecore::EResource'.
value of 'org.eclipse.emf.ecore.resource.ResourceSet' for model element
'ecore::EResourceSet'.
value of 'short' for model element 'ecore::EShort'.
value of 'java.lang.Short' for model element 'ecore::EShortObject'.
value of 'org.eclipse.emf.common.util.TreeIterator' for model element
'ecore::ETreeIterator'.
value of 'true' for model element 'uml::Model::viewpoint'.
value of 'true' for model element 'uml::ExtensionEnd::lower'.
'getMetaclass' for model element 'uml::Extension::metaclass'.
value of 'true' for model element 'uml::Behavior::context'.
value of 'true' for model element 'uml::Operation::isOrdered'.
value of 'true' for model element 'uml::Operation::isUnique'.
value of 'true' for model element 'uml::Operation::lower'.
value of 'true' for model element 'uml::Operation::upper'.
value of 'true' for model element 'uml::Operation::type'.
'lowerBound' for model element 'uml::Operation::lower'.
'upperBound' for model element 'uml::Operation::upper'.
'getType' for model element 'uml::Operation::type'.
'uml::DeploymentSpecification::deploymentLocation'.
'uml::DeploymentSpecification::executionLocation'.
value of 'true' for model element 'uml::DeploymentTarget::deployedElement'.
'getDeployedElements' for model element
value of 'true' for model element 'uml::Property::default'.
value of 'true' for model element 'uml::Property::isComposite'.
value of 'true' for model element 'uml::Property::opposite'.
'getOpposite' for model element 'uml::Property::opposite'.
value of 'true' for model element 'uml::Parameter::default'.
value of 'true' for model element 'uml::Parameter::effect'.
value of 'true' for model element 'uml::Classifier::attribute'.
'uml::RedefinableTemplateSignature::inheritedParameter'.
'getGenerals' for model element 'uml::Classifier::general'.
'getInheritedMembers' for model element 'uml::Classifier::inheritedMember'.
value of 'true' for model element 'uml::Association::endType'.
'getEndTypes' for model element 'uml::Association::endType'.
value of 'true' for model element 'uml::Package::nestedPackage'.
value of 'true' for model element 'uml::Package::nestingPackage'.
value of 'true' for model element 'uml::Namespace::member'.
value of 'true' for model element 'uml::Namespace::importedMember'.
'getImportedMembers' for model element 'uml::Namespace::importedMember'.
value of 'true' for model element 'uml::Expression::symbol'.
'getQualifiedName' for model element 'uml::NamedElement::qualifiedName'.
value of 'true' for model element 'uml::LiteralString::value'.
value of 'true' for model element 'uml::OpaqueBehavior::body'.
value of 'true' for model element 'uml::OpaqueBehavior::language'.
value of 'true' for model element 'uml::ActivityGroup::subgroup'.
value of 'true' for model element 'uml::ActivityGroup::superGroup'.
value of 'true' for model element 'uml::Activity::structuredNode'.
value of 'true' for model element 'uml::ActivityEdge::inGroup'.
value of 'true' for model element 'uml::ActivityGroup::containedEdge'.
value of 'true' for model element 'uml::ActivityGroup::containedNode'.
value of 'true' for model element 'uml::ActivityNode::inGroup'.
value of 'true' for model element 'uml::Action::output'.
value of 'true' for model element 'uml::Action::input'.
value of 'true' for model element 'uml::Action::context'.
value of 'true' for model element 'uml::OpaqueAction::body'.
value of 'true' for model element 'uml::OpaqueAction::language'.
value of 'true' for model element 'uml::Message::messageKind'.
value of 'true' for model element 'uml::Message::signature'.
value of 'true' for model element 'uml::Component::required'.
value of 'true' for model element 'uml::Component::provided'.
'getRequireds' for model element 'uml::Component::required'.
'getProvideds' for model element 'uml::Component::provided'.
value of 'true' for model element 'uml::ProtocolTransition::referred'.
value of 'true' for model element 'uml::Element::ownedElement'.
value of 'true' for model element 'uml::Element::owner'.
Operation 'uml::Transition::isConsistentWith' should be annotated as
redefinition of operation 'uml::RedefinableElement::isConsistentWith'.
Operation 'uml::State::isRedefinitionContextValid' should be
annotated as redefinition of operation
'uml::RedefinableElement::isRedefinitionContextValid'.
Operation 'uml::State::isConsistentWith' should be annotated as
Operation 'uml::State::containingStateMachine' should be annotated as
redefinition of operation 'uml::Vertex::containingStateMachine'.
Operation 'uml::Region::isRedefinitionContextValid' should be
Operation 'uml::Region::isConsistentWith' should be annotated as
Operation 'uml::StateMachine::isRedefinitionContextValid' should be
Operation 'uml::StateMachine::isConsistentWith' should be annotated
as redefinition of operation 'uml::RedefinableElement::isConsistentWith'.
Operation 'uml::ExtensionEnd::lowerBound' should be annotated as
redefinition of operation 'uml::MultiplicityElement::lowerBound'.
Operation 'uml::Class::inherit' should be annotated as redefinition
of operation 'uml::Classifier::inherit'.
Operation 'uml::BehavioralFeature::isDistinguishableFrom' should be
'uml::NamedElement::isDistinguishableFrom'.
Operation 'uml::DataType::inherit' should be annotated as
redefinition of operation 'uml::Classifier::inherit'.
Operation 'uml::Operation::isConsistentWith' should be annotated as
Operation 'uml::Property::isConsistentWith' should be annotated as
Operation 'uml::Property::isCompatibleWith' should be annotated as
redefinition of operation 'uml::ParameterableElement::isCompatibleWith'.
Operation 'uml::RedefinableTemplateSignature::isConsistentWith'
should be annotated as redefinition of operation
Operation 'uml::Classifier::conformsTo' should be annotated as
redefinition of operation 'uml::Type::conformsTo'.
Operation 'uml::Classifier::isTemplate' should be annotated as
redefinition of operation 'uml::TemplateableElement::isTemplate'.
Operation 'uml::Package::mustBeOwned' should be annotated as
redefinition of operation 'uml::Element::mustBeOwned'.
Operation 'uml::StringExpression::stringValue' should be annotated as
redefinition of operation 'uml::ValueSpecification::stringValue'.
Operation 'uml::ValueSpecification::isCompatibleWith' should be
Operation 'uml::LiteralInteger::isComputable' should be annotated as
redefinition of operation 'uml::ValueSpecification::isComputable'.
Operation 'uml::LiteralInteger::integerValue' should be annotated as
redefinition of operation 'uml::ValueSpecification::integerValue'.
Operation 'uml::LiteralString::isComputable' should be annotated as
Operation 'uml::LiteralString::stringValue' should be annotated as
Operation 'uml::LiteralBoolean::isComputable' should be annotated as
Operation 'uml::LiteralBoolean::booleanValue' should be annotated as
redefinition of operation 'uml::ValueSpecification::booleanValue'.
Operation 'uml::LiteralNull::isComputable' should be annotated as
Operation 'uml::LiteralNull::isNull' should be annotated as
redefinition of operation 'uml::ValueSpecification::isNull'.
Operation 'uml::LiteralUnlimitedNatural::isComputable' should be
Operation 'uml::LiteralUnlimitedNatural::unlimitedValue' should be
'uml::ValueSpecification::unlimitedValue'.
Feature 'uml::PackageableElement::visibility' should be annotated as
redefinition of feature 'uml::NamedElement::visibility'.
Feature 'uml::Transition::redefinitionContext' should be annotated as
redefinition of feature 'uml::RedefinableElement::redefinitionContext'.
Feature 'uml::State::redefinitionContext' should be annotated as
Feature 'uml::Region::redefinitionContext' should be annotated as
Feature 'uml::Class::isAbstract' should be annotated as redefinition
of feature 'uml::Classifier::isAbstract'.
Feature 'uml::Class::ownedAttribute' should be annotated as
redefinition of feature 'uml::StructuredClassifier::ownedAttribute'.
Feature 'uml::Class::superClass' should be annotated as redefinition
of feature 'uml::Classifier::general'.
Feature 'uml::Extension::ownedEnd' should be annotated as
redefinition of feature 'uml::Association::ownedEnd'.
Feature 'uml::ExtensionEnd::type' should be annotated as redefinition
of feature 'uml::TypedElement::type'.
Feature 'uml::ExtensionEnd::lower' should be annotated as
redefinition of feature 'uml::MultiplicityElement::lower'.
Feature 'uml::Operation::ownedParameter' should be annotated as
redefinition of feature 'uml::BehavioralFeature::ownedParameter'.
Feature 'uml::Operation::raisedException' should be annotated as
redefinition of feature 'uml::BehavioralFeature::raisedException'.
Feature 'uml::Operation::templateParameter' should be annotated as
redefinition of feature 'uml::ParameterableElement::templateParameter'.
Feature 'uml::OperationTemplateParameter::parameteredElement' should
be annotated as redefinition of feature
'uml::TemplateParameter::parameteredElement'.
Feature 'uml::Property::isReadOnly' should be annotated as
redefinition of feature 'uml::StructuralFeature::isReadOnly'.
Feature 'uml::ConnectableElement::templateParameter' should be
Feature
'uml::ConnectableElementTemplateParameter::parameteredElemen t' should be
Feature 'uml::Classifier::ownedTemplateSignature' should be annotated
'uml::TemplateableElement::ownedTemplateSignature'.
Feature 'uml::Classifier::templateParameter' should be annotated as
Feature 'uml::ClassifierTemplateParameter::parameteredElement' should
Feature 'uml::StructuredActivityNode::activity' should be annotated
as redefinition of feature 'uml::ActivityNode::activity'.
as redefinition of feature 'uml::ActivityGroup::inActivity'.
Feature 'uml::SequenceNode::executableNode' should be annotated as
redefinition of feature 'uml::StructuredActivityNode::node'.
Feature 'uml::OccurrenceSpecification::covered' should be annotated
as redefinition of feature 'uml::InteractionFragment::covered'.
Feature 'uml::StateInvariant::covered' should be annotated as
Feature 'uml::ExecutionOccurrenceSpecification::event' should be
annotated as redefinition of feature 'uml::OccurrenceSpecification::event'.
Feature 'uml::CreateLinkAction::endData' should be annotated as
redefinition of feature 'uml::LinkAction::endData'.
Feature 'uml::DestroyLinkAction::endData' should be annotated as
Feature 'uml::SendObjectAction::request' should be annotated as
redefinition of feature 'uml::InvocationAction::argument'.
Feature 'uml::DurationInterval::min' should be annotated as
redefinition of feature 'uml::Interval::min'.
Feature 'uml::DurationInterval::max' should be annotated as
redefinition of feature 'uml::Interval::max'.
Feature 'uml::IntervalConstraint::specification' should be annotated
as redefinition of feature 'uml::Constraint::specification'.
Feature 'uml::TimeConstraint::specification' should be annotated as
redefinition of feature 'uml::IntervalConstraint::specification'.
Feature 'uml::TimeInterval::max' should be annotated as redefinition
Feature 'uml::TimeInterval::min' should be annotated as redefinition
Feature 'uml::DurationConstraint::specification' should be annotated
as redefinition of feature 'uml::IntervalConstraint::specification'.
Feature 'uml::DirectedRelationship::source' should be annotated as
subset of feature 'uml::Relationship::relatedElement'.
Feature 'uml::DirectedRelationship::target' should be annotated as
Feature 'uml::Dependency::client' should be annotated as subset of
feature 'uml::DirectedRelationship::source'.
Feature 'uml::TemplateParameter::signature' should be annotated as
subset of feature 'uml::Element::owner'.
Feature 'uml::TemplateSignature::ownedParameter' should be annotated
as subset of feature 'uml::Element::ownedElement'.
as subset of feature 'uml::TemplateSignature::parameter'.
Feature 'uml::TemplateSignature::template' should be annotated as
Feature 'uml::TemplateableElement::ownedTemplateSignature' should be
annotated as subset of feature 'uml::Element::ownedElement'.
Feature 'uml::TemplateableElement::templateBinding' should be
Feature 'uml::TemplateBinding::boundElement' should be annotated as
subset of feature 'uml::DirectedRelationship::source'.
Feature 'uml::TemplateBinding::signature' should be annotated as
subset of feature 'uml::DirectedRelationship::target'.
Feature 'uml::TemplateBinding::parameterSubstitution' should be
Feature 'uml::TemplateParameterSubstitution::templateBinding' should
be annotated as subset of feature 'uml::Element::owner'.
Feature 'uml::TemplateParameterSubstitution::ownedActual' should be
annotated as subset of feature 'uml::TemplateParameterSubstitution::actual'.
Feature 'uml::TemplateParameter::ownedParameteredElement' should be
annotated as subset of feature 'uml::TemplateParameter::parameteredElement'.
Feature 'uml::ParameterableElement::owningTemplateParameter' should
Feature 'uml::TemplateParameter::ownedDefault' should be annotated as
subset of feature 'uml::TemplateParameter::default'.
Feature 'uml::Dependency::supplier' should be annotated as subset of
Feature 'uml::NamedElement::namespace' should be annotated as subset
Feature 'uml::Namespace::ownedMember' should be annotated as subset
of feature 'uml::Namespace::member'.
Feature 'uml::Namespace::elementImport' should be annotated as subset
Feature 'uml::ElementImport::importingNamespace' should be annotated
as subset of feature 'uml::DirectedRelationship::source'.
Feature 'uml::ElementImport::importedElement' should be annotated as
Feature 'uml::Namespace::packageImport' should be annotated as subset
Feature 'uml::PackageImport::importingNamespace' should be annotated
Feature 'uml::PackageImport::importedPackage' should be annotated as
Feature 'uml::Package::packageMerge' should be annotated as subset of
Feature 'uml::PackageMerge::receivingPackage' should be annotated as
Feature 'uml::PackageMerge::mergedPackage' should be annotated as
Feature 'uml::Package::packagedElement' should be annotated as subset
of feature 'uml::Namespace::ownedMember'.
Feature 'uml::Package::ownedType' should be annotated as subset of
feature 'uml::Package::packagedElement'.
Feature 'uml::Type::package' should be annotated as subset of feature
Feature 'uml::Classifier::generalization' should be annotated as
Feature 'uml::Generalization::specific' should be annotated as subset
Feature 'uml::Generalization::general' should be annotated as subset
Feature 'uml::Classifier::feature' should be annotated as subset of
Feature 'uml::Classifier::inheritedMember' should be annotated as
subset of feature 'uml::Namespace::member'.
Feature 'uml::Classifier::redefinedClassifier' should be annotated as
subset of feature 'uml::RedefinableElement::redefinedElement'.
Feature 'uml::Classifier::substitution' should be annotated as subset
of feature 'uml::NamedElement::clientDependency'.
Feature 'uml::Substitution::substitutingClassifier' should be
annotated as subset of feature 'uml::Dependency::client'.
Feature 'uml::Abstraction::mapping' should be annotated as subset of
Feature 'uml::MultiplicityElement::upperValue' should be annotated as
Feature 'uml::MultiplicityElement::lowerValue' should be annotated as
Feature 'uml::DeploymentTarget::deployment' should be annotated as
subset of feature 'uml::NamedElement::clientDependency'.
Feature 'uml::Deployment::location' should be annotated as subset of
Feature 'uml::Deployment::deployedArtifact' should be annotated as
subset of feature 'uml::Dependency::supplier'.
Feature 'uml::Deployment::configuration' should be annotated as
Feature 'uml::Artifact::nestedArtifact' should be annotated as subset
Feature 'uml::Artifact::manifestation' should be annotated as subset
Feature 'uml::Manifestation::utilizedElement' should be annotated as
Feature 'uml::Artifact::ownedOperation' should be annotated as subset
of feature 'uml::Classifier::feature'.
Feature 'uml::BehavioralFeature::ownedParameter' should be annotated
as subset of feature 'uml::Namespace::ownedMember'.
Feature 'uml::BehavioredClassifier::ownedBehavior' should be
annotated as subset of feature 'uml::Namespace::ownedMember'.
Feature 'uml::BehavioredClassifier::classifierBehavior' should be
annotated as subset of feature 'uml::BehavioredClassifier::ownedBehavior'.
Feature 'uml::BehavioredClassifier::interfaceRealization' should be
annotated as subset of feature 'uml::NamedElement::clientDependency'.
Feature 'uml::InterfaceRealization::implementingClassifier' should be
Feature 'uml::InterfaceRealization::contract' should be annotated as
Feature 'uml::Interface::ownedAttribute' should be annotated as
subset of feature 'uml::Classifier::attribute'.
Feature 'uml::Interface::ownedOperation' should be annotated as
subset of feature 'uml::Classifier::feature'.
Feature 'uml::Operation::interface' should be annotated as subset of
Feature 'uml::Interface::nestedClassifier' should be annotated as
Feature 'uml::Interface::redefinedInterface' should be annotated as
Feature 'uml::Interface::ownedReception' should be annotated as
Feature 'uml::Signal::ownedAttribute' should be annotated as subset
Feature 'uml::Interface::protocol' should be annotated as subset of
Feature 'uml::StateMachine::region' should be annotated as subset of
Feature 'uml::Region::stateMachine' should be annotated as subset of
feature 'uml::NamedElement::namespace'.
Feature 'uml::Region::subvertex' should be annotated as subset of
Feature 'uml::Vertex::container' should be annotated as subset of
Feature 'uml::Transition::container' should be annotated as subset of
Feature 'uml::Region::transition' should be annotated as subset of
Feature 'uml::Transition::redefinedTransition' should be annotated as
Feature 'uml::Transition::guard' should be annotated as subset of
feature 'uml::Namespace::ownedRule'.
Feature 'uml::Constraint::specification' should be annotated as
Feature 'uml::Constraint::context' should be annotated as subset of
Feature 'uml::Namespace::ownedRule' should be annotated as subset of
Feature 'uml::Transition::effect' should be annotated as subset of
Feature 'uml::Port::redefinedPort' should be annotated as subset of
Feature 'uml::Region::state' should be annotated as subset of feature
Feature 'uml::State::region' should be annotated as subset of feature
Feature 'uml::State::connection' should be annotated as subset of
Feature 'uml::ConnectionPointReference::state' should be annotated as
subset of feature 'uml::NamedElement::namespace'.
Feature 'uml::Pseudostate::stateMachine' should be annotated as
Feature 'uml::StateMachine::connectionPoint' should be annotated as
Feature 'uml::Pseudostate::state' should be annotated as subset of
Feature 'uml::State::connectionPoint' should be annotated as subset
Feature 'uml::State::redefinedState' should be annotated as subset of
Feature 'uml::State::stateInvariant' should be annotated as subset of
Feature 'uml::State::entry' should be annotated as subset of feature
Feature 'uml::State::exit' should be annotated as subset of feature
Feature 'uml::State::doActivity' should be annotated as subset of
Feature 'uml::Region::extendedRegion' should be annotated as subset
Feature 'uml::StateMachine::extendedStateMachine' should be annotated
as subset of feature 'uml::RedefinableElement::redefinedElement'.
Feature 'uml::ProtocolStateMachine::conformance' should be annotated
Feature 'uml::ProtocolConformance::specificMachine' should be
annotated as subset of feature 'uml::DirectedRelationship::source'.
Feature 'uml::ProtocolConformance::generalMachine' should be
annotated as subset of feature 'uml::DirectedRelationship::target'.
Feature 'uml::BehavioredClassifier::ownedTrigger' should be annotated
Feature 'uml::StructuredClassifier::ownedAttribute' should be
annotated as subset of feature 'uml::StructuredClassifier::role'.
annotated as subset of feature 'uml::Classifier::attribute'.
Feature 'uml::StructuredClassifier::role' should be annotated as
Feature 'uml::StructuredClassifier::ownedConnector' should be
annotated as subset of feature 'uml::Classifier::feature'.
Feature 'uml::Connector::redefinedConnector' should be annotated as
Feature 'uml::Connector::end' should be annotated as subset of
Feature 'uml::EncapsulatedClassifier::ownedPort' should be annotated
as subset of feature 'uml::StructuredClassifier::ownedAttribute'.
Feature 'uml::Class::nestedClassifier' should be annotated as subset
Feature 'uml::Class::ownedAttribute' should be annotated as subset of
Feature 'uml::Property::class' should be annotated as subset of
feature 'uml::Feature::featuringClassifier'.
Feature 'uml::Class::ownedOperation' should be annotated as subset of
Feature 'uml::Operation::class' should be annotated as subset of
Feature 'uml::Class::ownedReception' should be annotated as subset of
Feature 'uml::Profile::ownedStereotype' should be annotated as subset
of feature 'uml::Package::packagedElement'.
Feature 'uml::Profile::metaclassReference' should be annotated as
subset of feature 'uml::Namespace::elementImport'.
Feature 'uml::Profile::metamodelReference' should be annotated as
subset of feature 'uml::Namespace::packageImport'.
Feature 'uml::Behavior::redefinedBehavior' should be annotated as
Feature 'uml::Behavior::ownedParameter' should be annotated as subset
Feature 'uml::Behavior::context' should be annotated as subset of
Feature 'uml::Behavior::ownedParameterSet' should be annotated as
Feature 'uml::ParameterSet::condition' should be annotated as subset
Feature 'uml::BehavioralFeature::ownedParameterSet' should be
Feature 'uml::Operation::precondition' should be annotated as subset
of feature 'uml::Namespace::ownedRule'.
Feature 'uml::Operation::postcondition' should be annotated as subset
Feature 'uml::Operation::redefinedOperation' should be annotated as
Feature 'uml::Operation::datatype' should be annotated as subset of
Feature 'uml::DataType::ownedOperation' should be annotated as subset
Feature 'uml::DataType::ownedAttribute' should be annotated as subset
Feature 'uml::Property::datatype' should be annotated as subset of
Feature 'uml::Operation::bodyCondition' should be annotated as subse
Re: Issues with MagicDraw Models in New EMF Project [message #473287 is a reply to message #473282] Mon, 25 June 2007 12:32 Go to previous messageGo to next message
Hi David,
Those are just informational messages. They appear to be normal. There
should be a converter option to not report information like that. Try
tweaking the options.
Also, you could try to run "Validate" on the uml model before converting.
That might give you some additional peace of mind.
The main thing is getting functional EMF generated code out the other end
and that seemed to have worked for you.
- James.
"David Glaser" <dglaser@glaserreserach.net> wrote in message
news:f5op19$p1d$1@build.eclipse.org...
> configuration file.
> The problem:
> 'ecore::EEList'.
> 'ecore::EResource'.
> Feature
> Feature 'um
Re: Issues with MagicDraw Models in New EMF Project [message #473649 is a reply to message #473282] Wed, 04 July 2007 14:46 Go to previous message
David,
These messages are appearing because the importer is attempting to process
the UML metamodel itself. I'm not sure why this would be happening (does it
happen if you use the latest 2.1 release?), but as long as you can exclude
the resulting Ecore representation from the list of models you save, you can
ignore the messages. Here's a bit of detail on what the messages mean:
- The messages related to processing of tags are just informational, telling
you that tagged values were processed during the import.
- The messages related to annotating operations/features as redefinitions
are warnings, indicating that a model contains operation/properties that
redefine other operations/properties in an extended model but they haven't
been processed as such (and hence the generated code won't be tailored based
on these redefinition); to do so, select 'Process' for the 'Redefining
Operations/Properties' option in the importer.
- The messages related to annotating features as subsets are warnings,
indicating that a model contains properties that subset other properties in
an extended model but they haven't been processed as such (and hence the
generated code won't be tailored based on these subsets); to do so, select
'Process' for the 'Subetting Properties' option in the importer.
- The messages about making derived features transient and volatile are
informational - derived features are almost always transient and volatile
(and often read-only).
- The messages about discarding duplicate operations and features are
warnings, indicating that operations/features in an extending model have
been dicarded (end hence code to override the behavior of the
methods/accessors in the specialized class won't be generated); to process
such operations/features, select 'Process' for the 'Duplicate
Operations/Features' option in the importer.
- The messages about re-ordering superclasses are just informational (the
superclasses are re-ordered based on the number of features they have so
that the one with the largest number of features becomes the base class).
Kenn
>configuration file.
> The problem:
> I exported a large model from MagicDraw to EMF UML Format. The result was
> a directory that had six files, all with the extension ".uml2". Of the
> six files. four came from MagicDraw profiles, one is my model and the last
> Processed Ecore tag 'Ecore::EPackage::packageName' with value of 'uml'
> Processed Ecore tag 'Ecore::EPackage::nsPrefix' with value of 'uml' for
> Processed Ecore tag 'Ecore::EClassifier::instanceClassName' with value
> Processed Ecore tag 'Ecore::EStructuralFeature::isUnsettable' with value
> Processed Ecore tag 'Ecore::EStructuralFeature::isTransient' with value
> of 'true' for model element 'uml::RedefinableElement::redefinedElement'.
> Processed Ecore tag 'Ecore::EPackage::packageName' with value of 'ecore'
> Processed Ecore tag 'Ecore::EStructuralFeature::isVolatile' with value
> of 'true' for model element 'ecore::EStructuralFeature::eContainingClass'.
> of 'org.eclipse.emf.common.util.EList' for model element 'ecore::EEList'.
> 'ecore::EResource'.
> Operation 'uml::State::isRedefinitionContextValid' should be annotated
> Operation 'uml::Region::isRedefinitionContextValid' should be annotated
> Operation 'uml::StateMachine::isConsistentWith' should be annotated as
> Operation 'uml::Class::inherit' should be annotated as redefinition of
> Operation 'uml::DataType::inherit' should be annotated as redefinition
> Operation 'uml::RedefinableTemplateSignature::isConsistentWith' should
> Operation 'uml::LiteralNull::isNull' should be annotated as redefinition
> Feature 'uml::Class::isAbstract' should be annotated as redefinition of
> Feature 'uml::Class::ownedAttribute' should be annotated as redefinition
> Feature 'uml::Class::superClass' should be annotated as redefinition of
> Feature 'uml::Extension::ownedEnd' should be annotated as redefinition
> Feature 'uml::ExtensionEnd::type' should be annotated as redefinition of
> Feature 'uml::ExtensionEnd::lower' should be annotated as redefinition
> Feature 'uml::OperationTemplateParameter::parameteredElement' should be
> Feature 'uml::Property::isReadOnly' should be annotated as redefinition
> Feature 'uml::ConnectableElement::templateParameter' should be annotated
> as redefinition of feature 'uml::ParameterableElement::templateParameter'.
> Feature 'uml::ConnectableElementTemplateParameter::parameteredElemen t'
> should be annotated as redefinition of feature
> Feature 'uml::Classifier::ownedTemplateSignature' should be annotated as
> Feature 'uml::ClassifierTemplateParameter::parameteredElement' should be
> Feature 'uml::StructuredActivityNode::activity' should be annotated as
> Feature 'uml::OccurrenceSpecification::covered' should be annotated as
> Feature 'uml::DurationInterval::min' should be annotated as redefinition
> Feature 'uml::DurationInterval::max' should be annotated as redefinition
> Feature 'uml::IntervalConstraint::specification' should be annotated as
> Feature 'uml::TimeInterval::max' should be annotated as redefinition of
> Feature 'uml::TimeInterval::min' should be annotated as redefinition of
> Feature 'uml::DurationConstraint::specification' should be annotated as
> Feature 'uml::TemplateSignature::ownedParameter' should be annotated as
> Feature 'uml::TemplateSignature::template' should be annotated as subset
> Feature 'uml::TemplateableElement::templateBinding' should be annotated
> Feature 'uml::TemplateBinding::signature' should be annotated as subset
> Feature 'uml::TemplateParameterSubstitution::templateBinding' should be
> Feature 'uml::ParameterableElement::owningTemplateParameter' should be
> Feature 'uml::NamedElement::namespace' should be annotated as subset of
> Feature 'uml::Namespace::ownedMember' should be annotated as subset of
> Feature 'uml::Namespace::elementImport' should be annotated as subset of
> Feature 'uml::ElementImport::importingNamespace' should be annotated as
> Feature 'uml::Namespace::packageImport' should be annotated as subset of
> Feature 'uml::PackageImport::importingNamespace' should be annotated as
> Feature 'uml::PackageMerge::mergedPackage' should be annotated as subset
> Feature 'uml::Package::packagedElement' should be annotated as subset of
> Feature 'uml::Classifier::generalization' should be annotated as subset
> Feature 'uml::Generalization::specific' should be annotated as subset of
> Feature 'uml::Generalization::general' should be annotated as subset of
> Feature 'uml::Classifier::inheritedMember' should be annotated as subset
> Feature 'uml::Classifier::substitution' should be annotated as subset of
> Feature 'uml::Substitution::substitutingClassifier' should be annotated
> Feature 'uml::Deployment::configuration' should be annotated as subset
> Feature 'uml::Artifact::nestedArtifact' should be annotated as subset of
> Feature 'uml::Artifact::manifestation' should be annotated as subset of
> Feature 'uml::Artifact::ownedOperation' should be annotated as subset of
> Feature 'uml::BehavioralFeature::ownedParameter' should be annotated as
> Feature 'uml::BehavioredClassifier::ownedBehavior' should be annotated
> Feature 'uml::Interface::ownedAttribute' should be annotated as subset
> Feature 'uml::Interface::ownedOperation' should be annotated as subset
> Feature 'uml::Interface::nestedClassifier' should be annotated as subset
> Feature 'uml::Interface::ownedReception' should be annotated as subset
> Feature 'uml::Signal::ownedAttribute' should be annotated as subset of
> Feature 'uml::Constraint::specification' should be annotated as subset
> Feature 'uml::Pseudostate::stateMachine' should be annotated as subset
> Feature 'uml::State::connectionPoint' should be annotated as subset of
Re: Issues with MagicDraw Models in New EMF Project [message #622562 is a reply to message #473282] Mon, 25 June 2007 12:32 Go to previous message
Hi David,
- James.
> configuration file.
> The problem:
> 'ecore::EEList'.
> 'ecore::EResource'.
> Feature
> Feature 'um
Re: Issues with MagicDraw Models in New EMF Project [message #622721 is a reply to message #473282] Wed, 04 July 2007 14:46 Go to previous message
David,
Kenn
>configuration file.
> The problem:
> 'ecore::EResource'.
Previous Topic:how to remove an activity from a package
Next Topic:question about package merge
Current Time: Wed Jul 23 12:41:29 EDT 2025
Powered by FUDForum. Page generated in 0.11528 seconds
