Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EMF Compare Start problem
EMF Compare Start problem [message #530695] |
Fri, 30 April 2010 10:47  |
I'm new to EMF Compare and I tried to execute the example standalone application ( i run it in eclipse), by comparing 2 uml files (i register the additional packages). Unfortunately I get an exception:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object 'org.eclipse.uml2.uml.internal.impl.ClassImpl@117f31e (name: Class3, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)' is not contained in a resource.
When I run it in debug mode, I can see that the exception happens at:
System.out.println(ModelUtils.serialize(match));
When I compare the same uml files non programmatically, I get a normal result with a number of differences.
I can't understand what's wrong for days. Can anyone help me please?
Re: EMF Compare Start problem [message #530967 is a reply to message #530695] |
Mon, 03 May 2010 04:32   |
--------------060606000902010201050701
Hi Bogie,
The "System.out.println(ModelUtils.serialize(match)" line is only there
to give console feedback on what was matched ... and there are clearly
better ways to do so.
As for the actual error ; there are references from one (or both) of
your model(s) to an object that isn't contained in any model ... do you
create EObjects anywhere in your code (to reference them from other
objects, to add them to the model, ...)? I do not understand where the
"mailto:" part comes from in the error message you get, my best bet
would be that you have an EObject which "toString" returns
"mailto:<reference>", and this EObject would be the culprit :
"'mailto:....' is not contained in a resource".
If nothing of this rings a bell, could you attach your sample models and
the code you're running?
Laurent Goubet
Obeo
Bogie wrote:
> mailto:'org.eclipse.uml2.uml.internal.impl.ClassImpl@117f31e (name:
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------060606000902010201050701--
Re: EMF Compare Start problem [message #530999 is a reply to message #530967] |
Mon, 03 May 2010 06:16   |
Thank you for your reply. I don't create EObjects in my code, I just take the models as arguments from the command line. I don't change anything in the code because I wanted to try the basic example in order to start.
The two uml models I use are the following:
model1.uml:
<uml:Package xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_9bQ4ULT8Ed2kfr6ZNjmMHg" name="testModels">
<elementImport xmi:id="_9cHz8LT8Ed2kfr6ZNjmMHg">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Boolea n"/>
</elementImport>
<elementImport xmi:id="_9cHz8bT8Ed2kfr6ZNjmMHg">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</elementImport>
<elementImport xmi:id="_9cHz8rT8Ed2kfr6ZNjmMHg">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Unlimi tedNatural"/>
</elementImport>
<elementImport xmi:id="_9cHz87T8Ed2kfr6ZNjmMHg">
<importedElement xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
</elementImport>
<packagedElement xmi:type="uml:Class" xmi:id="_AsKoYLT9Ed2kfr6ZNjmMHg" name="Class1">
<ownedAttribute xmi:id="_eY790LT-Ed2kfr6ZNjmMHg" name="attribute2" aggregation="composite"/>
<ownedAttribute xmi:id="_fiLd0LT-Ed2kfr6ZNjmMHg" name="attribute1" aggregation="composite"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_AsKoYLT9Ed2kfr6ZNjmMHg" name="Class3"/>
<packagedElement xmi:type="uml:Class" xmi:id="_AsKoYLT9Ed2kfr6ZNjmMHg" name="Class2">
</packagedElement>
<packagedElement xmi:type="uml:Package" xmi:id="_q_x3oLUAEd2kfr6ZNjmMHg" name="package1">
<packagedElement xmi:type="uml:Package" xmi:id="_rd8aULUAEd2kfr6ZNjmMHg" name="package2">
<packagedElement xmi:type="uml:Package" xmi:id="_roAVQLUAEd2kfr6ZNjmMHg" name="package3">
<packagedElement xmi:type="uml:Class" xmi:id="_vStFYLUAEd2kfr6ZNjmMHg" name="Class1">
<ownedAttribute xmi:id="_vStFYbUAEd2kfr6ZNjmMHg" name="attribute2" aggregation="composite"/>
<ownedAttribute xmi:id="_vStFYrUAEd2kfr6ZNjmMHg" name="attribute1" aggregation="composite"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_vStFY7UAEd2kfr6ZNjmMHg" name="Class3"/>
<packagedElement xmi:type="uml:Class" xmi:id="_vStFZLUAEd2kfr6ZNjmMHg" name="Class2">
<ownedAttribute xmi:id="_vStFZbUAEd2kfr6ZNjmMHg" name="attribute2" aggregation="composite"/>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</uml:Package>
model2.uml:
<uml:Package xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_ZDkboLT-Ed2kfr6ZNjmMHg" name="testModels">
<packagedElement xmi:type="uml:Package" xmi:id="_gPEHELUAEd2kfr6ZNjmMHg" name="package1">
<packagedElement xmi:type="uml:Package" xmi:id="_ir1EcLUAEd2kfr6ZNjmMHg" name="package2">
<packagedElement xmi:type="uml:Package" xmi:id="_kd9wcLUAEd2kfr6ZNjmMHg" name="package3">
<packagedElement xmi:type="uml:Class" xmi:id="_mU_jgLUAEd2kfr6ZNjmMHg" name="Class3"/>
<packagedElement xmi:type="uml:Class" xmi:id="_mU_jgbUAEd2kfr6ZNjmMHg" name="Class2">
<ownedAttribute xmi:id="_mU_jgrUAEd2kfr6ZNjmMHg" name="attribute2" aggregation="composite"/>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_mU_jg7UAEd2kfr6ZNjmMHg" name="Class1">
<ownedAttribute xmi:id="_mU_jhLUAEd2kfr6ZNjmMHg" name="attribute1" aggregation="composite"/>
<ownedAttribute xmi:id="_mU_jhbUAEd2kfr6ZNjmMHg" name="attribute2" aggregation="composite"/>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
<packagedElement xmi:type="uml:Class" xmi:id="_Z7YNYLT-Ed2kfr6ZNjmMHg" name="Class1">
<ownedAttribute xmi:id="_bM11QLT-Ed2kfr6ZNjmMHg" name="attribute1" aggregation="composite"/>
<ownedAttribute xmi:id="_cYr9ULT-Ed2kfr6ZNjmMHg" name="attribute2" aggregation="composite"/>
</packagedElement>
<elementImport xmi:id="_ZELfoLT-Ed2kfr6ZNjmMHg">
</elementImport>
<elementImport xmi:id="_ZELfobT-Ed2kfr6ZNjmMHg">
</elementImport>
<elementImport xmi:id="_ZELforT-Ed2kfr6ZNjmMHg">
</elementImport>
<elementImport xmi:id="_ZELfo7T-Ed2kfr6ZNjmMHg">
</elementImport>
</packagedElement>
</uml:Package>
The code is:
package standalone.example.launcher;
import java.io.File;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Calendar;
import java.util.Collections;
import java.util.List;
import org.eclipse.emf.compare.diff.metamodel.DiffElement;
import org.eclipse.emf.compare.diff.metamodel.DiffFactory;
import org.eclipse.emf.compare.diff.metamodel.DiffModel;
import org.eclipse.emf.compare.diff.metamodel.ComparisonResourceSna pshot;
import org.eclipse.emf.compare.diff.service.DiffService;
import org.eclipse.emf.compare.match.metamodel.MatchModel;
import org.eclipse.emf.compare.match.service.MatchService;
import org.eclipse.emf.compare.util.ModelUtils;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.compare.diff.merge.service.MergeService;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
* This application will try and launch an headless model comparison.
* @author Cedric Brun <a href="mailto:cedric.brun@obeo.fr">cedric.brun@obeo.fr</a>
public final class ExampleLauncher {
* This class doesn't need to be instantiated.
private ExampleLauncher() {
// prevents instantiation
* Launcher of this application.
* @param args
* Arguments of the launch.
if (args.length == 2 && new File(args[0]).canRead() && new File(args[1]).canRead()) {
// Creates the resourceSets where we'll load the models
final ResourceSet resourceSet1 = new ResourceSetImpl();
final ResourceSet resourceSet2 = new ResourceSetImpl();
// Register additionnal packages here. For UML2 for instance :
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
resourceSet1.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet2.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
try {
System.out.println("Loading resources.\n"); //$NON-NLS-1$
// Loads the two models passed as arguments
final EObject model1 = ModelUtils.load(new File(args[0]), resourceSet1);
final EObject model2 = ModelUtils.load(new File(args[1]), resourceSet2);
// Creates the match then the diff model for those two models
System.out.println("Matching models.\n"); //$NON-NLS-1$
final MatchModel match = MatchService.doMatch(model1, model2, Collections
.<String, Object> emptyMap());
System.out.println("Differencing models.\n"); //$NON-NLS-1$
final DiffModel diff = DiffService.doDiff(match, false);
System.out.println("Merging difference to args[1].\n"); //$NON-NLS-1$
final List<DiffElement> differences = new ArrayList<DiffElement>(diff.getOwnedElements());
// This will merge all references to the right model (second argument).
MergeService.merge(differences, true);
// Prints the results
try {
System.out.println("MatchModel :\n"); //$NON-NLS-1$
System.out.println("DiffModel :\n"); //$NON-NLS-1$
System.out.println(ModelUtils.serialize(diff));
} catch (final IOException e) {
e.printStackTrace();
// Serializes the result as "result.emfdiff" in the directory this class has been called from.
System.out.println("saving emfdiff as \"result.emfdiff\""); //$NON-NLS-1$
final ComparisonResourceSnapshot snapshot = DiffFactory.eINSTANCE
.createComparisonResourceSnapshot();
snapshot.setDate(Calendar.getInstance().getTime());
snapshot.setMatch(match);
snapshot.setDiff(diff);
ModelUtils.save(snapshot, "result.emfdiff"); //$NON-NLS-1$
// shouldn't be thrown
} catch (final InterruptedException e) {
} else {
System.out.println("usage : ExampleLauncher <Model1> <Model2>"); //$NON-NLS-1$
Another thing is that when I comment the line that gives me the error, System.out.println(ModelUtils.serialize(match));
I still get the same error but on:
Re: EMF Compare Start problem [message #531009 is a reply to message #530999] |
Mon, 03 May 2010 07:25   |
--------------040303020105070809050005
Bogie,
I can't really see where the problem would come from ; though I can say
you're not registering everything UML needs in ordder to use it
standalone. You can find everything needed here :
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
Looking at your model, you need to register
"UMLResource.LIBRARIES_PATHMAP" at the very least. That is ... _if_
you're indeed using this Java class as a standalone application.
Registering these should help with your comparison.
These lines aren't needed when you compare the two files in Eclipse as
the UML plugin in this case does every needed step itself.
Laurent Goubet
Obeo
Bogie wrote:
> to start. The two uml models I use are the following:
> model1.uml:
> </elementImport>
> </elementImport>
> </elementImport>
> </elementImport>
> name="Class1">
> </packagedElement>
> name="Class3"/>
> name="Class2">
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </uml:Package>
> model2.uml:
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> name="Class1">
> </packagedElement>
> </elementImport>
> </elementImport>
> </elementImport>
> </elementImport>
> name="Class3"/>
> name="Class2">
> </packagedElement>
> </uml:Package>
> The code is:
> * * @author Cedric Brun <a
> href="mailto:mailto:cedric.brun@obeo.fr">mailto:cedric.brun@obeo.fr</a>
> * * @param args
> public static void main(String[] args) {
> try {
> models
> model2, Collections
> //$NON-NLS-1$
> (second argument).
> try {
> } else {
--------------040303020105070809050005--
Re: EMF Compare Start problem [message #531156 is a reply to message #531009] |
Mon, 03 May 2010 18:43   |
Thanks for your help. I'm running the application in eclipse, not as a standalone one.
It's the following code:
* @param args
// Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(UMLResource.FILE_EXTENSION,
//UMLResource.Factory.INSTANCE);
// resourceSet1.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
// resourceSet2.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
try {
try {
//System.out.println(ModelUtils.serialize(match));
} else {
As I've understood from your previous message, I commented the lines that register additional packages, since the UML plugin in eclipse handles everything. When running this code I get the following exception:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://www.eclipse.org/uml2/2.1.0/UML' not found. ( file:///C:/Users/Bogie/workspace/StandaloneExample/model/mod el1.uml, 2, 180)
which happens at line:
But, on the other hand maybe I've understood wrong?
Bogie
Re: EMF Compare Start problem [message #531306 is a reply to message #531156] |
Tue, 04 May 2010 09:48   |
--------------050200080003020608030006
Hi Bogie,
Well the problem is that I see a "main()" in there ... and I believe
you're launching your class (within Eclipse) through "run as -> Java
application" ... and this is exactly how you launch a standalone app
from within Eclipse :). If I hit the spot as to how you launch your code
(and the exception you get when commenting out the UML package
registration nearly proves it), then you will need to do everything
that's outlined on the UML wiki page I gave you the link before. Namely,
uncomment the UML package registration, and add the registrations of the
URIMaps.
Laurent Goubet
Obeo
Bogie wrote:
> standalone one. It's the following code:
> * * @param args
> try {
> models
> model2, Collections
> //$NON-NLS-1$
> (second argument).
> try {
> } else {
> 180)
> Bogie
--------------050200080003020608030006--
Re: EMF Compare Start problem [message #531525 is a reply to message #531306] |
Wed, 05 May 2010 06:43   |
Thank you very much for clearing up some things for me. I registered the packages and defined the uri maps, but I still get the same exception.
This is my code snippet :
Map<URI, URI> uriMap1 = resourceSet1.getURIConverter().getURIMap();
URI uri = URI.createURI(" jar:file:/C:/eclipse/plugins/org.eclipse.uml2.uml.resources_ 2.2.0.v200805131030.jar!/ ");
uriMap1.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap1.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
uriMap1.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
Map<URI, URI> uriMap2 = resourceSet2.getURIConverter().getURIMap();
uriMap2.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap2.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
uriMap2.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
In debug mode, when I come to the line that causes the exception (ModelUtils.save(snapshot, "result.emfdiff") , I get the message:
The jar of this class file belongs to the class 'Plug-in Dependencies' which does not allow modifications to source attachments on its entries.
public class org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl....
So, the problem I have is maybe due to the plug-in dependencies, since org.eclipse.emf.ecore.xmi is not in my required plug-ins list, because I can't add it?
I added this plug-in to the java search but nothing changes (plug-in view and then right click add to java search).
Re: EMF Compare Start problem [message #531549 is a reply to message #531525] |
Wed, 05 May 2010 07:52   |
--------------080406030304020301070109
Hi Bogie,
I am at a loss here as to what's happening with your models. Could you
raise a bugzilla with the error message you get, the models your trying
to compare, and the code you're using to this end?
Laurent Goubet
Obeo
Bogie wrote:
> exception. This is my code snippet :
> (ModelUtils.save(snapshot, "result.emfdiff");), I get the message: The
> can't add it?
--------------080406030304020301070109--
Re: EMF Compare Start problem [message #532802 is a reply to message #532120] |
Tue, 11 May 2010 05:33  |
--------------070105040102080307030509
Thanks, my RSS feed hadn't been updated and I didn't look directly on
the bugzilla (I kinda got used to being fed by thunderbird :p).
We'll try and look at this asap.
Laurent Goubet
Obeo
Bogie wrote:
> Here it is:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=311710
--------------070105040102080307030509--
Re: EMF Compare Start problem [message #622545 is a reply to message #530967] |
model1.uml:
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</uml:Package>
model2.uml:
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</packagedElement>
</elementImport>
</elementImport>
</elementImport>
</elementImport>
</packagedElement>
</uml:Package>
The code is:
* @author Cedric Brun <a href="mailto:mailto:cedric.brun@obeo.fr">mailto:cedric.brun@obeo.fr</a>
* @param args
try {
try {
} else {
Re: EMF Compare Start problem [message #622546 is a reply to message #622545] |
Bogie,
Laurent Goubet
Obeo
Bogie wrote:
> model1.uml:
> </elementImport>
> </elementImport>
> </elementImport>
> </elementImport>
> name="Class1">
> </packagedElement>
> name="Class3"/>
> name="Class2">
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </uml:Package>
> model2.uml:
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> name="Class1">
> </packagedElement>
> </elementImport>
> </elementImport>
> </elementImport>
> </elementImport>
> name="Class3"/>
> name="Class2">
> </packagedElement>
> </uml:Package>
> The code is:
> * * @param args
> try {
> models
> model2, Collections
> //$NON-NLS-1$
> (second argument).
> try {
> } else {
Re: EMF Compare Start problem [message #622550 is a reply to message #531009] |
* @param args
try {
try {
} else {
Bogie
Re: EMF Compare Start problem [message #622552 is a reply to message #622550] |
Hi Bogie,
URIMaps.
Laurent Goubet
Obeo
Bogie wrote:
> * * @param args
> try {
> models
> model2, Collections
> //$NON-NLS-1$
> (second argument).
> try {
> } else {
> 180)
> Bogie
Re: EMF Compare Start problem [message #622819 is a reply to message #531306] |
Wed, 05 May 2010 06:44  |
In debug mode, when I come to the line that causes the exception (ModelUtils.save(snapshot, "result.emfdiff");), I get the message:
Re: EMF Compare Start problem [message #622820 is a reply to message #622819] |
Hi Bogie,
Laurent Goubet
Obeo
Bogie wrote:
> can't add it?
Re: EMF Compare Start problem [message #622831 is a reply to message #622824] |
Thu, 06 May 2010 04:28  |
--------------010403080700000804010907
Humm ... could you copy the bugzilla URL here? I can't seem to find it.
Bogie wrote:
> I've submitted the code to Bugzilla.
--------------010403080700000804010907--
Re: EMF Compare Start problem [message #622874 is a reply to message #622851] |
Laurent Goubet
Obeo
Bogie wrote:
> Here it is:
Current Time: Thu Jul 24 17:57:23 EDT 2025
Powered by FUDForum. Page generated in 0.12953 seconds
