Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] Forms vs. property editing
[EEF] Forms vs. property editing [message #513703] Wed, 10 February 2010 16:43 Go to next message
It seems that while the property sheets do live EMF command invocation -- i.e. changes that affect other fields are immediately propagated, the forms based editor (accessed by double-clicking) only invokes these commands when the form is dismissed. Is this expected behavior?
thanks,
Miles
Re: [EEF] Forms vs. property editing [message #513846 is a reply to message #513703] Thu, 11 February 2010 08:30 Go to previous messageGo to next message
--------------020905060006070906020907
Miles Parker a écrit :
Yes, to be clear, the property view use the *Form generated widgets (
eclipse form ) with direct EMF commands, then "Wizards" editor uses
*Impl generated widgets ( swt ) with a composed command .
> thanks,
> Miles
name="stephane_bouchet.vcf"
filename="stephane_bouchet.vcf"
YmVnaW46dmNhcmQNCmZuO3F1b3RlZC1wcmludGFibGU6U3Q9QzM9QTlwaGFu ZSBCb3VjaGV0
DQpuO3F1b3RlZC1wcmludGFibGU6Qm91Y2hldDtTdD1DMz1BOXBoYW5lDQpv cmc6T2Jlbw0K
YWRyOjs7Ozs7O0ZyYW5jZQ0KZW1haWw7aW50ZXJuZXQ6c3RlcGhhbmUuYm91 Y2hldEBvYmVv
LmZyDQp4LW1vemlsbGEtaHRtbDpGQUxTRQ0KdXJsOmh0dHA6Ly93d3cub2Jl by5mcg0KdmVy
c2lvbjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020905060006070906020907--
Re: [EEF] Forms vs. property editing [message #513955 is a reply to message #513846] Thu, 11 February 2010 14:04 Go to previous messageGo to next message
Stephane Bouchet wrote on Thu, 11 February 2010 08:30
Any ideas about what the best way to change this behavior would be? Probably just to re implement the on double-click behavior to open a form instead..?
Re: [EEF] Forms vs. property editing [message #514119 is a reply to message #513955] Fri, 12 February 2010 03:50 Go to previous messageGo to next message
--------------090800080500090608060709
hi Miles,
comments below :
>> > Hi,
>> invocation > -- i.e. changes that affect other fields are immediately
>> propagated, the > forms based editor (accessed by double-clicking)
>> only invokes these > commands when the form is dismissed. Is this
>> expected behavior?
> form instead..?
i don't understand what you want to do.... do you want to open a view on
double click ? in this case, yes, you have to modify the open policy
(take a look in
org.eclipse.emf.eef.runtime.ui.notify.OpenWizardOnDoubleClic k ) .
We are planning to document either theis kind of uses we can do with
EEF, too :
http://www.eclipse.org/modeling/emft/eef/videos/eef-rcp-appl ication.htm
--------------090800080500090608060709--
Re: [EEF] Forms vs. property editing [message #514217 is a reply to message #514119] Fri, 12 February 2010 16:00 Go to previous messageGo to next message
Stephane Bouchet wrote on Fri, 12 February 2010 03:50
> form instead..?
(take a look in
Yeah, I just wanted to modify that behavior so that it was properly dealing with undo and other commands within the double-clicked window as well. Shouldn't that be the default behavior or is their some reason that it can't / shouldn't be?
EEF, too :
Great, that's what I wanted to find out. Do you have this is an example project somewhere? (I didn't see it on Wiki.)
I guess this is also in response to my separate thread on Maseter-Detail, etc... I see here that you have different views for Master and Detail. What I'd like to do -- and what I think would be really nicely doable with your current model is to support the definition of these within a form.
BTW, I think that this is a great tool that has even more potential. If you add a bit more to it, you'd have E4. Very Happy (E4 guys, I'm just kidding..)
Re: [EEF] Forms vs. property editing [message #514218 is a reply to message #514217] Fri, 12 February 2010 16:01 Go to previous messageGo to next message
Oh, can you give me just a hint for how to get those nice top tabs? Smile
Re: [EEF] Forms vs. property editing [message #514482 is a reply to message #514217] Mon, 15 February 2010 04:38 Go to previous messageGo to next message
Hi Miles,
First, thanks for all your very encouraging feedback :)
>> ( >> eclipse form ) with direct EMF commands, then "Wizards" editor
>> uses >> *Impl generated widgets ( swt ) with a composed command .
>> be? > Probably just to re implement the on double-click behavior to
>> open a > form instead..?
>> on double click ? in this case, yes, you have to modify the open policy
>> (take a look in
Ok, If I understand what you want, you have to use the
PropertiesEditionComponents in "live mode". So I think you have
to create a "LivePropertiesEditionWizard" very similar to the
"PropertiesEditionWizard" but which use a PropertiesEditionViewer in
live mode. I hope this can help !
> Quote:
>> EEF, too :
>> ication.htm
For the "Tarot" demo, I've just committed the source on the CVS. It is
here :
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.eef/tests/org.eclipse.emf.samples.eef.tarot/?ro ot=Modeling_Project
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.eef/tests/org.eclipse.emf.samples.eef.tarot.edi t/?root=Modeling_Project
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.eef/tests/org.eclipse.emf.samples.eef.tarot.edi tor/?root=Modeling_Project
> you add a bit more to it, you'd have E4. :d (E4 guys, I'm just kidding..)
Thx a lot Mike, as Stephane propose let me buy you a beer at the next
Econ if you come ;)
Goulwen Le Fur - goulwen.lefur@beo.fr
Re: [EEF] Forms vs. property editing [message #622122 is a reply to message #513846] Thu, 11 February 2010 14:04 Go to previous messageGo to next message
> > Hi,
Re: [EEF] Forms vs. property editing [message #622126 is a reply to message #622122] Fri, 12 February 2010 08:32 Go to previous messageGo to next message
hi Miles,
comments below :
>> > Hi,
>> expected behavior?
> form instead..?
(take a look in
EEF, too :
Re: [EEF] Forms vs. property editing [message #622131 is a reply to message #622126] Fri, 12 February 2010 16:00 Go to previous messageGo to next message
> > form instead..?
> (take a look in
> EEF, too :
BTW, I think that this is a great tool that has even more potential. If you add a bit more to it, you'd have E4. :d (E4 guys, I'm just kidding..)
Re: [EEF] Forms vs. property editing [message #622144 is a reply to message #622131] Mon, 15 February 2010 09:32 Go to previous message
Hi Miles,
>> (take a look in
> Quote:
>> EEF, too :
>> ication.htm
here :
Econ if you come ;)
Previous Topic:Name DiffElement
Next Topic:EcoreTools cannot be installed on Eclipse 3.6 M4
Current Time: Fri Jul 18 23:55:42 EDT 2025
Powered by FUDForum. Page generated in 0.09861 seconds
