Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Compare UML models
[EMF Compare] Compare UML models [message #622099] Mon, 08 February 2010 11:46 Go to next message
I am trying to compare two versions of an UML model (with profiles applied) in an standalone environment (to be more precise: from an MWE process in a custom workflow component). The UML package is registered and models are loaded correctly.
I'm comparing like follows:
MatchModel match = MatchService.doContentMatch(v1, v2, options);
DiffModel diff = new GenericDiffEngine().doDiff(match);
ctx.set(outputSlot, diff);
final ComparisonResourceSnapshot snapshot = DiffFactory.eINSTANCE.createComparisonResourceSnapshot();
snapshot.setDate(Calendar.getInstance().getTime());
snapshot.setMatch(match);
snapshot.setDiff(diff);
ModelUtils.save(snapshot, "result.emfdiff");
In the resulting DiffModel I get just two entries:
- One ModelElementChangeLeftTarget with kind==Addition and leftElement=[v1]
- One ModelElementChangeRightTarget with kind==Deletion and leftElement=[v2]
It seems that the result is "the model is added in the one file and deleted in the other". I would expect that the DiffModel contains entries for each real change. What am I doing wrong here?
Next issue: When I try to compare those models with the UI takes forever in the phase "Processing matched roots' contents". Is this a known problem?
Kind regards,
~Karsten
Re: [EMF Compare] Compare UML models [message #622100 is a reply to message #622099] Mon, 08 February 2010 12:09 Go to previous messageGo to next message
When I change
to
MatchService.doMatch(v1, v2, options);
it works. Why does doContentMatch() not give the expected result? What's the difference between both methods?
~Karsten
Re: [EMF Compare] Compare UML models [message #622139 is a reply to message #622100] Mon, 15 February 2010 05:04 Go to previous messageGo to next message
--------------030408050102070500030702
Hi Karsten,
doContentMatch() compares the content of the two given elements, doMatch
() goes up to the resource to compare (it is an equivalent to
doResourceMatch()). If you've got nothing under the two elements you
give the MatchService, I'd understand that you don't get much results.
With this in mind, are the results you get irrelevant or did you in fact
get accurate results considering only the content of v1 and v2 ?
laurent Goubet
Obeo
Karsten Thoms wrote:
> When I change
> to
> ~Karsten
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------030408050102070500030702--
Re: [EMF Compare] Compare UML models [message #622142 is a reply to message #622099] Mon, 15 February 2010 07:36 Go to previous messageGo to next message
Hi Laurent!
Thanks for your reply! We decided now to follow another way, since the results we got from comparing UML models directly did not allow us to evaluate the results easily. What we want to achieve is compare different states of our class model, which has an applied profile. From that we want to derive a change report for our generated interfaces, which is DDL on the backend and an XSD on the frontend. What made life complicate with UML directly is:
- associations
- tagged values (no direct relation to the profiled element)
- derived attributes and relations
We now transform the UML models to EMF models that are tighter bound to what we use in code generation. Comparing these models with EMF compare is far easier to evaluate.
Best wishes,
~Karsten
Re: [EMF Compare] Compare UML models [message #622155 is a reply to message #622142] Tue, 16 February 2010 05:14 Go to previous message
--------------040605090505050005070804
Hi Karsten,
Thanks for the feedback ;). We know that EMF Compare indeed has problems
with UML specificities, yet a comparison engine tightly bound to UML is
not planned yet.
Laurent Goubet
Obeo
> Hi Laurent!
> - associations
> Best wishes,
> ~Karsten
--------------040605090505050005070804--
Previous Topic:[EMF Compare] Compare UML models
Next Topic:[EEF] Properties not displayed
Current Time: Wed Jul 30 23:06:38 EDT 2025
Powered by FUDForum. Page generated in 0.32548 seconds
