[EMF Compare] Comparing Strings [message #622021] |
Tue, 19 January 2010 11:24  |
Hi.
I'm using Xtext and am trying to compare 2 files to check if the serialization behaves as supposed to. If I remove or add model elements, everything works fine and the changes are recognized. But changes in attributes that hold Strings seem not to be compared. So if I edit the content of an attribute that is of kind String, these changes are not computed. Do you have any hint for this kind of problem?
Roland
Re: [EMF Compare] Comparing Strings [message #622024 is a reply to message #622021] |
Wed, 20 January 2010 06:48  |
--------------010502010701050103000600
Hi Roland,
That would look like a bug ... But it is unlikely. The name of an EClass
is itself an EAttribute of type String, and a changed name is properly
detected as a difference by EMF Compare.
Can you be more precise as to how you trigger this issue?
Laurent Goubet
Obeo
Roland S. wrote:
> Hi.
> Thanks, Roland
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010502010701050103000600--
FUDForum. Page generated in 0.05239 seconds
