Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [MWE] ClassNotFoundException: org.eclipse.core.runtime.Assert
[MWE] ClassNotFoundException: org.eclipse.core.runtime.Assert [message #622009] Fri, 15 January 2010 03:58 Go to next message
Hi I created a new XPand project with example files recently in Eclipse 3.5. I found out that to run this example project I have to fix bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=283942 manually. I did this.
However now I get the following error:
java.lang.ClassNotFoundException: org.eclipse.core.runtime.Assert
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:319)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:264)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:332 )
and I can't find out which archive contains this class. Can someone please help me?
Thank you
Klemens
Re: [MWE] ClassNotFoundException: org.eclipse.core.runtime.Assert [message #622011 is a reply to message #622009] Fri, 15 January 2010 13:20 Go to previous messageGo to next message
Klemens,
It's in org.eclipse.equinox.common.
> at java.security.AccessController.doPrivileged(Native Method)
> please help me?
> Thank you
> Klemens
Re: [MWE] ClassNotFoundException: org.eclipse.core.runtime.Assert [message #622012 is a reply to message #622009] Sat, 16 January 2010 02:22 Go to previous message
This solved the problem.
Thank you Ed.
Previous Topic:[MWE] ClassNotFoundException: org.eclipse.core.runtime.Assert
Next Topic:[EEF] Documentation?
Current Time: Sat Jul 19 01:05:26 EDT 2025
Powered by FUDForum. Page generated in 0.03039 seconds
