| [MWE] Update to 0.8.0 problem [message #621978] |
Sun, 10 January 2010 10:17  |
Hello Everybody!
I was trying to update my installed MWE 0.7.2 to Version 0.8.0M4 using the description given at ekkescorner (http://ekkescorner.wordpress.com/eclipse/update-sites/). However, when I try to update using Eclipse's "Install New Software", I get an error like the following for every item:
Message:
> Artifact not found: osgi.bundle,org.eclipse.emf.mwe.utils.source,0.8.0.v20100109 1919.
Stacktrace:
> java.io.FileNotFoundException: file:/{pathToUnpackedUpdateSite}/emft-mwe-Update-0.8.0M4-N20 1001091919/plugins/org.eclipse.emf.mwe.utils.source_0.8.0.v2 01001091919.jar
> at org.eclipse.equinox.internal.p2.repository.RepositoryStatusH elper.checkFileNotFound(RepositoryStatusHelper.java:289)
> at org.eclipse.equinox.internal.p2.repository.FileReader.checkE xception(FileReader.java:352)
> at org.eclipse.equinox.internal.p2.repository.FileReader.sendRe trieveRequest(FileReader.java:326)
> at org.eclipse.equinox.internal.p2.repository.FileReader.readIn to(FileReader.java:263)
> at org.eclipse.equinox.internal.p2.repository.RepositoryTranspo rt.download(RepositoryTransport.java:71)
> at org.eclipse.equinox.internal.p2.repository.RepositoryTranspo rt.download(RepositoryTransport.java:127)
> at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:468)
> at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:451)
> at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:518)
> at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.getArtifact(MirrorRequest.java:200)
> at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:175)
> at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:159)
> at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:95)
> at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:507)
> at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifacts(SimpleArtifactRepositor y.java:563)
> at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch (DownloadManager.java:109)
> at org.eclipse.equinox.internal.p2.engine.DownloadManager.start (DownloadManager.java:97)
> at org.eclipse.equinox.internal.provisional.p2.engine.phases.Co llect.completePhase(Collect.java:73)
> at org.eclipse.equinox.internal.provisional.p2.engine.Phase.pos tPerform(Phase.java:195)
> at org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:78)
> at org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:44)
> at org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:54)
> at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.performProvisioningPlan(ProvisioningUtil.java :389)
> at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ofileModificationOperation.doExecute(ProfileModificationOper ation.java:61)
> at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningOperation.execute(ProvisioningOperation.java:37)
> at org.eclipse.equinox.internal.provisional.p2.ui.ProvisioningO perationRunner$1.run(ProvisioningOperationRunner.java:94)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Session Data:
> eclipse.buildId=M20090917-0800
> java.version=1.6.0_0
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
> Framework arguments: -product org.eclipse.epp.package.modeling.product
> Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.modeling.product
I tried using the alternative Hudson build with the same results (the error message shown is actually from the Hudson build). Trying to manually extract the file that was not found from an archive in the same directoy with the same name plus ".pack.gz" would also produce an error. The md5 sum of the zipped update site is correct, however.
I'm using Eclipse Modeling Tools, Build-ID: 20090920-1017 on an Ubuntu machine.
Any help as to why this doesn't work and how I can make it work would be very appreciated.
Thanks in advance,
Michèl
| Re: [MWE] Update to 0.8.0 problem [message #621983 is a reply to message #621982] |
Mon, 11 January 2010 07:49   |
Hey Dennis,
thank you for the link to the remote repository. Using it, I was able to update MWE. Odd still, that it doesn't work with the local site.
Anyway, after update, my workflow wouldn't run and instead it apparently won't find the workflow runner.
> Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
> at org.eclipse.emf.mwe.core.WorkflowRunner.<clinit>(WorkflowRunner.java:66)
> Caused by: java.lang.ClassNotFoundException: org.apache.commons.logging.LogFactory
> at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:319)
> at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 )
> at java.lang.ClassLoader.loadClass(ClassLoader.java:264)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:332 )
> ... 1 more
> Could not find the main class: org.eclipse.emf.mwe.core.WorkflowRunner. Program will exit.
Probably I made some error during updating, but I can't look deeper into that, since it was decided to add an ANT workflow to the MWE one (with which I can also solve the problem because of which I wanted to use 0.8.0), so I don't have the time or need anymore to look for the error and will continue using MWE 0.7.2. Sorry for the trouble.
Still, thanks a lot for your fast help!
Michèl
| Re: [MWE] Update to 0.8.0 problem [message #622006 is a reply to message #621983] |
Thu, 14 January 2010 14:05  |
Hi Michel,
just check that your generator project has a resolved plugin dependency
to org.apache.commons.logging and org.eclipse.xtend
Dennis.
Michèl Pohle schrieb:
> Hey Dennis,
> Quote:
>> at
>> ... 1 more
> Best regards,
> Michèl
FUDForum. Page generated in 0.05464 seconds
