Home » Eclipse Projects » Platform - User Assistance (UA) » Eclipse Help index has mixed languages
Eclipse Help index has mixed languages [message #474790] Fri, 14 November 2008 13:52 Go to next message
We are writing our own docs with the DITA OT and sticking them into an
Eclipse Infocenter. We package our doc plugins with multiple languages in
a single plugin using the 'nl' sub directory scheme described in the
Eclipse documentation (the English docs occupy the root of the plugin, all
other languages are under the nl/ directory).
The issue we are having is when a language other than English, for example
German, is displaying (by setting lang=de in the infocenter URL) and the
index tab is opened, any index term at the tertiary level is displayed in
English instead of German. If I use a plugin that has only German these
tertiary terms display correctly in German. I've determined that in the
case of a multilanguage doc plugin, Eclipse is falling back to the English
TOC entry title for those tertiary terms but I have no idea why it would
do that. Looking at the German index.xml file the <topic title="">
attributes are all in German.
Anfrage
Estrellen
Zusammenarbeit
Collaborating on Demand Request Items
Collaboration
If I add a fourth level in the index I notice that the Main parent titles
stay in German but the children are in English
Anfrage
Estrellen
Zusammenarbeit
Collaboration
Zusammenarbeit
Collaboration
If 'Zusammenarbeit' only has one child, that child displays properly in
German.
Anfrage
Estrellen
Zusammenarbeit
Zusammenarbeit
Here's a relevant piece of the German index.xml file. Is this valid?
<index>
<entry keyword="Anfrage">
<entry keyword="Erstellen">
<topic href="html/createdemands.htm" title="Übermitteln von
Erstanfrageeinträgen"/>
</entry>
<entry keyword="Zusammenarbeit">
<topic href="html/collaboration.htm" title="Zusammenarbeit"/>
<topic href="html/demandcollaboration.htm"
title="Zusammenarbeit bei Erstanfrageeinträgen"/>
</entry>
</index>
Additionally, there are two entries for Anfrage, Estrellen but each entry
points to a different topic. Why are they being grouped in two separate
Anfrage entries?
Anfrage
Estrellen --> points to topic1.htm
Zusammenarbeit
Collaboration
Anfrage
Arefaktaufschlusselung
Estrellen --> points to topic2.htm
Formularbeantwortung
Re: Eclipse Help index has mixed languages [message #474791 is a reply to message #474790] Fri, 14 November 2008 15:54 Go to previous messageGo to next message
Which version of Eclipse are you using? This sounds like something that
was fixed in Eclipse 3.4.1 in IndexAssembler.java.
Re: Eclipse Help index has mixed languages [message #474792 is a reply to message #474791] Fri, 14 November 2008 16:47 Go to previous messageGo to next message
I'm using 3.4. Would I be able to drop the 3.4.1 org.eclipse.help jar
into 3.4 if that is the case?
Re: Eclipse Help index has mixed languages [message #474793 is a reply to message #474792] Fri, 14 November 2008 17:50 Go to previous messageGo to next message
That may work but because of the way P2 loads plugins it's possible that
the new version of the plugin will not get automatically loaded when you
restart Eclipse if you put the new org.eclipse.help jar in the plugins
directory. In any case I would recommend that you first test using
Eclipse 3.4.1 tlo see if it fixes the problem for you.
Re: Eclipse Help index has mixed languages [message #474797 is a reply to message #474793] Mon, 17 November 2008 11:21 Go to previous messageGo to next message
Thank you very much, Chris. The org.eclipse.help jar from 3.4.1 does
indeed fix the problem. I removed the older org.eclipse.help jar and
dropped in the new one and it seems to work fine. Is there anything else
I should be cautious of?
Re: Eclipse Help index has mixed languages [message #474827 is a reply to message #474797] Wed, 19 November 2008 16:58 Go to previous message
If that plugin works for you then it should be safe to use it. There
were not many changes between 3.4 and 3.4.1 and none that would not be
backward compatible.
> else I should be cautious of?
Re: Eclipse Help index has mixed languages [message #621916 is a reply to message #474790] Fri, 14 November 2008 15:54 Go to previous message
Re: Eclipse Help index has mixed languages [message #621918 is a reply to message #474791] Fri, 14 November 2008 16:47 Go to previous message
Re: Eclipse Help index has mixed languages [message #621920 is a reply to message #474792] Fri, 14 November 2008 17:50 Go to previous message
Re: Eclipse Help index has mixed languages [message #621927 is a reply to message #474793] Mon, 17 November 2008 11:21 Go to previous message
Re: Eclipse Help index has mixed languages [message #622211 is a reply to message #474797] Wed, 19 November 2008 16:58 Go to previous message
Previous Topic:Re: Standalone help for RCP product
Next Topic:Re: Welcome page when a feature is installed
Current Time: Wed Jul 23 01:55:09 EDT 2025
Powered by FUDForum. Page generated in 3.16977 seconds
