Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EEF Can´t display the property view
EEF Can´t display the property view [message #621906] Tue, 15 December 2009 02:17 Go to next message
hi i generated with eef my properties
http://wiki.eclipse.org/EEF_tutorial_:_First_generation
but my propview will not display. i think the problem is the contributor id, but in the tutorial the contributor id of the editor and the plugin.xml is also different.
EEF Generation in EMF treeview editor: MY STEPS
add dependency on my project test.prop.eef
add in this project the extension points of the providers
add in test.prop.eef.diagram the extension points of the tab props
implements in test.prop.eef.editor.myEditor ITabbedProp....
contributorID = "model.properties"
change method getPropertySheetPage()
test.prop.eef.diagram plugin.xml
<!-- Tabbed properties views extension -->
<extension
point="org.eclipse.ui.views.properties.tabbed.propertyContributor ">
<propertyContributor
contributorId="EEFContributorID">
<propertyCategory
category="default">
</propertyCategory>
<propertyCategory
category="extended">
</propertyCategory>
<propertyCategory
category="advanced">
</propertyCategory>
</propertyContributor>
</extension>
<extension
point="org.eclipse.ui.views.properties.tabbed.propertyTabs" >
<propertyTabs
<propertyTab
label="Base"
category="default"
id="Base">
</propertyTab>
</propertyTabs>
</extension>
<extension
point="org.eclipse.ui.views.properties.tabbed.propertySections ">
<propertySections
<propertySection
tab="Base"
class=" org.eclipse.emf.eef.runtime.ui.properties.sections.Propertie sEditionSection "
id="model.model.section.Diagram">
<input
type="model.Diagram">
</input>
</propertySection>
<propertySection
tab="Base"
id="model.model.section.Element">
<input
type="model.Element">
</input>
</propertySection>
<propertySection
tab="Base"
id="model.model.section.Rectangle">
<input
type="model.Rectangle">
</input>
</propertySection>
<propertySection
tab="Base"
id="model.model.section.Ellipse">
<input
type="model.Ellipse">
</input>
</propertySection>
<propertySection
tab="Base"
id="model.model.section.ElementEvents">
<input
type="model.ElementEvents">
</input>
</propertySection>
<propertySection
tab="Base"
id="model.model.section.Line">
<input
type="model.Line">
</input>
</propertySection>
</propertySections>
</extension>
I hope this will help.
Re: EEF Can´t display the property view [message #621913 is a reply to message #621906] Tue, 15 December 2009 08:21 Go to previous messageGo to next message
Hi Thomas,
I think that your contributor ID has to be the same in the editor and in
the plugin.xml.
Nathalie.
> <extension
> <propertyCategory
> category="default">
> </propertyCategory>
> <propertyCategory
> </propertyCategory>
> <propertyCategory
> </propertyCategory>
> </extension>
> <extension
> <propertyTabs
> <propertyTab
> label="Base"
> category="default"
> id="Base">
> </propertyTab>
> </propertyTabs>
> </extension>
> <extension
> <propertySections
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> type="model.Line">
> </input>
> </propertySection>
> </propertySections>
> </extension>
> Thanks
Re: EEF Can´t display the property view [message #621938 is a reply to message #621906] Wed, 16 December 2009 08:12 Go to previous message
My Steps:
create new gmf Project org.eclipse.test.prop
model.ecore
generate genmodel
-> generate All
->Initialize EEF Model
eefgen
->/org.eclipse.test.prop/src (Generation)
->/org.eclipse.test.prop/src-gen (Test-Generation)
gen edition context
-> set basepackage to model
-> description contributorid to org.eclipse.test.prop.model.properties
-> hook gmf specific properties views
gen views repository
->base package model
->GENMODEL
EEF -> Generate EEF Architektur
This was the generation Section
__________________________________________________________
generated model_properties.plugin.xml
<?eclipse version="3.0"?>
<plugin>
<!-- EEF extensions -->
<extension
point="org.eclipse.emf.eef.runtime.PropertiesEditionProvider ">
<PropertiesEditionComponentProvider
providerClass="model.model.providers.ModelPackagePropertiesEditionProvider ">
</PropertiesEditionComponentProvider>
</extension>
<extension
point="org.eclipse.emf.eef.runtime.PropertiesEditionPolicyProvider ">
<PropertiesEditionPolicyProvider
providerClass=" model.model.providers.ModelPackagePropertiesEditionPolicyPro vider ">
</PropertiesEditionPolicyProvider>
</extension>
<extension
contributorId="org.eclipse.test.prop.model.properties">
<propertyCategory
category="default">
</propertyCategory>
<propertyCategory
</propertyCategory>
<propertyCategory
</propertyCategory>
</extension>
<extension
<propertyTabs
<propertyTab
label="Base"
category="default"
id="Base">
</propertyTab>
</propertyTabs>
</extension>
<extension
<propertySections
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
type="model.Line">
</input>
</propertySection>
</propertySections>
</extension>
</plugin>
I add the first two extensions to org.eclipse.test.prop-> plugin.xml
and add a 3rd
<extension
point="org.eclipse.emf.eef.runtime.PropertiesEditionPartProvider ">
<PropertiesEditionPartProvider
providerClass="model.providers.ModelPropertiesEditionPartProvider ">
</PropertiesEditionPartProvider>
</extension>
the other extensions are inserted in org.eclipse.test.prop.diagram -> plugin.xml
i remove the existing 3 prop.tab extension points and add the generated ones. (org.eclipse.ui.vies.propperties.tabbed. ....)
then i move to the project org.eclipse.test.prop.editor
-> implement ITabbedPropertyPage
-> change getPropertySheetPage like in the tutorial
-> change variable
-> set ContribotrId to org.eclipse.test.prop.model.properties
it does compile and run, but it won´t display the property page.
Previous Topic:[Announce] EMFT MWE 0.8.0M4 is available
Next Topic:[CDO] is it what I want ?
Current Time: Wed Jul 30 18:53:14 EDT 2025
Powered by FUDForum. Page generated in 0.03857 seconds
