Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Problem with three way merge
[EMF Compare] Problem with three way merge [message #500539] Thu, 26 November 2009 09:40 Go to next message
I'm trying to merge the contents of two instances of the same model using a
three (3) way merge after making a small change to each of the instaces but,
I am finding that the merged model contains only one set of changes, e.g.
the changes between ancestorEmfModel and remoteEmfModel. EMF compare is
removing the changes made in localEmfModel. This is the code that I'm
using:
MatchModel matchModel = MatchService.doContentMatch(localEmfModel,
remoteEmfModel, ancestorEmfModel,
Collections.<String, Object> singletonMap(MatchOptions.OPTION_IGNORE_ID,
true));
DiffModel diffModel = DiffService.doDiff(matchModel, false);
MergeService.merge(new ArrayList<DiffElement>(diffModel.getOwnedElements()),
true);
Is there any way of ensuring that EMF compare does not remove the changes
that took place between ancestorEmfModel and localEmfModel so that after a
merge I end up with both sets of changes?
Jose
Re: [EMF Compare] Problem with three way merge [message #500546 is a reply to message #500539] Thu, 26 November 2009 10:45 Go to previous messageGo to next message
--------------050902020100060901020206
Hi Jose,
Depending on the changes you made, it might be normal that EMF Compare
ignores the change to the local model. For example if you made the exact
same change between the remote and ancestor models, then there is in
fact no difference to be detected, let alone be merged.
Could you describe the exact changes you made in each models?
Laurent Goubet
Obeo
Jose Hernandez wrote:
> using:
> true));
> true);
> Regards,
> Jose
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------050902020100060901020206--
Re: [EMF Compare] Problem with three way merge [message #500554 is a reply to message #500546] Thu, 26 November 2009 11:31 Go to previous messageGo to next message
Hi Laurent,
I added an element to the repository model and removed and element from the
local model. More specifically, the model has a map and a list, I added an
element to the map in the repository model and removed an element from the
list in the local model and then attempted to combine the two. I seem to be
getting a conflicting change in the map but this doesn't make sense since
the the map has only had an element added to it in one of the model
instances and not the other.
If I merge right to left I get this diff model:
<?xml version="1.0" encoding="Cp1252"?>
<diff:DiffModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.1">
<ownedElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:ModelElementChangeLeftTarget">
<rightParent
href=" 31465cc3-d9c8-4c89-a200-07e34d671077.entitlementcalculation# //@ruleList.0/@entitlementCalculationList.1 "/>
<leftElement
href=" 20ad96b8-51fc-4317-af16-a6c428d0965a.entitlementcalculation# //@ruleList.0/@entitlementCalculationList.1/@entitlementList .2 "/>
</subDiffElements>
<rightParent
href=" 20ad96b8-51fc-4317-af16-a6c428d0965a.entitlementcalculation# //@ruleList.0/@entitlementCalculationList.1 "/>
</subDiffElements>
<rightParent
href=" 20ad96b8-51fc-4317-af16-a6c428d0965a.entitlementcalculation# //@ruleList.0 "/>
</subDiffElements>
<subDiffElements xsi:type="diff:ConflictingDiffElement">
remote="true">
<rightParent
href=" 31465cc3-d9c8-4c89-a200-07e34d671077.entitlementcalculation# / "/>
<leftElement
href=" 20ad96b8-51fc-4317-af16-a6c428d0965a.entitlementcalculation# //@decisionSetMap.17 "/>
</subDiffElements>
<leftParent
<rightParent
</subDiffElements>
<rightParent
href=" 20ad96b8-51fc-4317-af16-a6c428d0965a.entitlementcalculation# / "/>
</subDiffElements>
</ownedElements>
<leftRoots
<rightRoots
<ancestorRoots
href=" 423a8e75-1832-43b7-8fd8-b01179fdf2dd.entitlementcalculation# / "/>
</diff:DiffModel>
and if I merge left to right I get this:
remote="true">
<rightParent
href=" 028f88b0-b72a-402e-937b-215a7373aace.entitlementcalculation# / "/>
<leftElement
href=" 9449fc8e-d3e2-4008-8b90-6082f944e572.entitlementcalculation# //@decisionSetMap.17 "/>
</subDiffElements>
<leftParent
<rightParent
</subDiffElements>
<rightParent
href=" 028f88b0-b72a-402e-937b-215a7373aace.entitlementcalculation# //@ruleList.0/@entitlementCalculationList.1 "/>
<leftElement
href=" 9449fc8e-d3e2-4008-8b90-6082f944e572.entitlementcalculation# //@ruleList.0/@entitlementCalculationList.1/@entitlementList .2 "/>
</subDiffElements>
<rightParent
href=" 9449fc8e-d3e2-4008-8b90-6082f944e572.entitlementcalculation# //@ruleList.0/@entitlementCalculationList.1 "/>
</subDiffElements>
<rightParent
href=" 9449fc8e-d3e2-4008-8b90-6082f944e572.entitlementcalculation# //@ruleList.0 "/>
</subDiffElements>
<rightParent
href=" 9449fc8e-d3e2-4008-8b90-6082f944e572.entitlementcalculation# / "/>
</subDiffElements>
</ownedElements>
<leftRoots
<rightRoots
<ancestorRoots
href=" 1843d754-d1c6-4175-97bd-b60b58b8d362.entitlementcalculation# / "/>
</diff:DiffModel>
Jose
"Laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:hem7r8$3j9$1@build.eclipse.org...
> Hi Jose,
> Laurent Goubet
> Obeo
>> Hi,
>> a
>> but,
>> using:
>> true));
>> true);
>> a
>> Regards,
>> Jose
Re: [EMF Compare] Problem with three way merge [message #500641 is a reply to message #500554] Fri, 27 November 2009 04:28 Go to previous messageGo to next message
--------------080109020103090907090705
Jose,
You changed the same reference from both local and distant model
differently, thus giving you a conflicting change. That doesn't really
surprise me. What surprises me more is that merging doesn't seem to have
changed any of the models in any way :'(.
Could you provide us with the models you use, or are they confidential?
Anyway, please raise a bug describing the issue on the eclipse bugzilla.
Laurent Goubet
Obeo
> Hi Laurent,
> <rightParent
> <leftElement
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> remote="true">
> <rightParent
> <leftElement
> </subDiffElements>
> <leftParent
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> </ownedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </diff:DiffModel>
> remote="true">
> <rightParent
> <leftElement
> </subDiffElements>
> <leftParent
> <rightParent
> </subDiffElements>
> <rightParent
> <leftElement
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> </ownedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </diff:DiffModel>
> Regards,
> Jose
>> Hi Jose,
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> a
>>> but,
>>> using:
>>> true));
>>> true);
>>> a
>>> Regards,
>>> Jose
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------080109020103090907090705--
Re: [EMF Compare] Problem with three way merge [message #500680 is a reply to message #500641] Fri, 27 November 2009 08:44 Go to previous messageGo to next message
Hi Laurent,
I'll prepare an example project demonstrating the issue and send it to you
as soon as I can.
Jose
news:heo634$480$1@build.eclipse.org...
> Jose,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> the
>> an
>> the
>> be
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> Regards,
>> Jose
>>> Hi Jose,
>>> Laurent Goubet
>>> Obeo
>>>> Hi,
>>>> using
>>>> a
>>>> but,
>>>> e.g.
>>>> is
>>>> using:
>>>> true));
>>>> true);
>>>> changes
>>>> after
>>>> a
>>>> Regards,
>>>> Jose
Re: [EMF Compare] Problem with three way merge [message #500708 is a reply to message #500680] Fri, 27 November 2009 10:48 Go to previous messageGo to next message
Hi Laurent,
Please find a small test case attached. All you need to do is run the
LibraryExample class from eclipse as a Java application.
The test program sends all its output to the console.
Jose
"Jose Hernandez" <jose.hernandez@smartstream-stp.com> wrote in message
news:heol44$5i5$1@build.eclipse.org...
> Hi Laurent,
> as soon as I can.
> Regards,
> Jose
>> Jose,
>> Laurent Goubet
>> Obeo
>>> Hi Laurent,
>>> the
>>> an
>>> the
>>> to
>>> be
>>> since
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> remote="true">
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <leftParent
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> </ownedElements>
>>> <leftRoots
>>> <rightRoots
>>> <ancestorRoots
>>> </diff:DiffModel>
>>> remote="true">
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <leftParent
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> </ownedElements>
>>> <leftRoots
>>> <rightRoots
>>> <ancestorRoots
>>> </diff:DiffModel>
>>> Regards,
>>> Jose
>>>> Hi Jose,
>>>> exact
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi,
>>>>> using
>>>>> a
>>>>> instaces
>>>>> but,
>>>>> e.g.
>>>>> is
>>>>> using:
>>>>> true));
>>>>> true);
>>>>> changes
>>>>> after
>>>>> a
>>>>> Regards,
>>>>> Jose
Re: [EMF Compare] Problem with three way merge [message #500925 is a reply to message #500641] Mon, 30 November 2009 05:25 Go to previous message
Hi Laurent,
Bug raised as per request
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=296442)
Jose
> Jose,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> the
>> an
>> the
>> be
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> Regards,
>> Jose
>>> Hi Jose,
>>> Laurent Goubet
>>> Obeo
>>>> Hi,
>>>> using
>>>> a
>>>> but,
>>>> e.g.
>>>> is
>>>> using:
>>>> true));
>>>> true);
>>>> changes
>>>> after
>>>> a
>>>> Regards,
>>>> Jose
Re: [EMF Compare] Problem with three way merge [message #621619 is a reply to message #500539] Thu, 26 November 2009 10:45 Go to previous message
Hi Jose,
Laurent Goubet
Obeo
> using:
> true));
> true);
> Regards,
> Jose
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
Re: [EMF Compare] Problem with three way merge [message #621620 is a reply to message #500546] Thu, 26 November 2009 11:31 Go to previous message
Hi Laurent,
<rightParent
<leftElement
</subDiffElements>
<rightParent
</subDiffElements>
<rightParent
</subDiffElements>
remote="true">
<rightParent
<leftElement
</subDiffElements>
<leftParent
<rightParent
</subDiffElements>
<rightParent
</subDiffElements>
</ownedElements>
<leftRoots
<rightRoots
<ancestorRoots
</diff:DiffModel>
remote="true">
<rightParent
<leftElement
</subDiffElements>
<leftParent
<rightParent
</subDiffElements>
<rightParent
<leftElement
</subDiffElements>
<rightParent
</subDiffElements>
<rightParent
</subDiffElements>
<rightParent
</subDiffElements>
</ownedElements>
<leftRoots
<rightRoots
<ancestorRoots
</diff:DiffModel>
Jose
> Hi Jose,
> Laurent Goubet
> Obeo
>> Hi,
>> a
>> but,
>> using:
>> true));
>> true);
>> a
>> Regards,
>> Jose
Re: [EMF Compare] Problem with three way merge [message #621623 is a reply to message #500554] Fri, 27 November 2009 04:28 Go to previous message
Jose,
Laurent Goubet
Obeo
> Hi Laurent,
> <rightParent
> <leftElement
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> remote="true">
> <rightParent
> <leftElement
> </subDiffElements>
> <leftParent
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> </ownedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </diff:DiffModel>
> remote="true">
> <rightParent
> <leftElement
> </subDiffElements>
> <leftParent
> <rightParent
> </subDiffElements>
> <rightParent
> <leftElement
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> </subDiffElements>
> </ownedElements>
> <leftRoots
> <rightRoots
> <ancestorRoots
> </diff:DiffModel>
> Regards,
> Jose
>> Hi Jose,
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> a
>>> but,
>>> using:
>>> true));
>>> true);
>>> a
>>> Regards,
>>> Jose
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
Re: [EMF Compare] Problem with three way merge [message #621851 is a reply to message #500641] Fri, 27 November 2009 08:44 Go to previous message
Hi Laurent,
as soon as I can.
Jose
> Jose,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> the
>> an
>> the
>> be
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> Regards,
>> Jose
>>> Hi Jose,
>>> Laurent Goubet
>>> Obeo
>>>> Hi,
>>>> using
>>>> a
>>>> but,
>>>> e.g.
>>>> is
>>>> using:
>>>> true));
>>>> true);
>>>> changes
>>>> after
>>>> a
>>>> Regards,
>>>> Jose
Re: [EMF Compare] Problem with three way merge [message #621855 is a reply to message #500680] Fri, 27 November 2009 10:48 Go to previous message
Hi Laurent,
Jose
> Hi Laurent,
> as soon as I can.
> Regards,
> Jose
>> Jose,
>> Laurent Goubet
>> Obeo
>>> Hi Laurent,
>>> the
>>> an
>>> the
>>> to
>>> be
>>> since
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> remote="true">
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <leftParent
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> </ownedElements>
>>> <leftRoots
>>> <rightRoots
>>> <ancestorRoots
>>> </diff:DiffModel>
>>> remote="true">
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <leftParent
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> <leftElement
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> <rightParent
>>> </subDiffElements>
>>> </ownedElements>
>>> <leftRoots
>>> <rightRoots
>>> <ancestorRoots
>>> </diff:DiffModel>
>>> Regards,
>>> Jose
>>>> Hi Jose,
>>>> exact
>>>> Laurent Goubet
>>>> Obeo
>>>>> Hi,
>>>>> using
>>>>> a
>>>>> instaces
>>>>> but,
>>>>> e.g.
>>>>> is
>>>>> using:
>>>>> true));
>>>>> true);
>>>>> changes
>>>>> after
>>>>> a
>>>>> Regards,
>>>>> Jose
Re: [EMF Compare] Problem with three way merge [message #621863 is a reply to message #500641] Mon, 30 November 2009 05:25 Go to previous message
Hi Laurent,
Jose
> Jose,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> the
>> an
>> the
>> be
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> remote="true">
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <leftParent
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> <leftElement
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> <rightParent
>> </subDiffElements>
>> </ownedElements>
>> <leftRoots
>> <rightRoots
>> <ancestorRoots
>> </diff:DiffModel>
>> Regards,
>> Jose
>>> Hi Jose,
>>> Laurent Goubet
>>> Obeo
>>>> Hi,
>>>> using
>>>> a
>>>> but,
>>>> e.g.
>>>> is
>>>> using:
>>>> true));
>>>> true);
>>>> changes
>>>> after
>>>> a
>>>> Regards,
>>>> Jose
Previous Topic:[EMF Compare] Multiple matches
Next Topic:Forward Cross References (Posted to wrong group. Answer in EMF forum)
Current Time: Wed Jul 23 22:55:46 EDT 2025
Powered by FUDForum. Page generated in 0.40103 seconds
