Home » Eclipse Projects » JavaServer Faces » projectTaglibDescriptorFactory extension
projectTaglibDescriptorFactory extension [message #621733] Fri, 09 July 2010 17:48 Go to next message
Do you know where I can find example of using extension projectTaglibDescriptorFactory?
I am trying to register custom components taglib.xml.
Thanks ahead
Re: projectTaglibDescriptorFactory extension [message #621839 is a reply to message #621733] Thu, 15 July 2010 18:35 Go to previous message
The description for that extension point says, "internal... not provisional API", so I don't think you are going to find many examples. I can find no references. And I'm not sure how you "register custom components taglib.xml" - isn't adding the file to the project enough? What behaviour are you expecting to get?
It's possible that JSF 2.0 support just hasn't evolved enough yet to support your use case, but I can't say for sure since I don't know what that use case is.
- Ian
Previous Topic:projectTaglibDescriptorFactory extension
Next Topic:Tag attributes CA in XHTML files for non-standard taglibs
Current Time: Sun Jul 27 13:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.03495 seconds
