Home » Archived » Eclipse Communications Framework (ECF) » M5 Update Problem with Eclipse 3.3.2
M5 Update Problem with Eclipse 3.3.2 [message #621818] Mon, 10 March 2008 08:13 Go to next message
Scott Lewis wrote:
> ECF 2.0.0 milestone 5 is now available.
> Note: this build works with both Eclipse 3.3 and 3.4 streams of the
> Eclipse Platform.
I'm using Eclipse 3.3.2 and trying to install ecf 2.0.0M5. But the
Update-Site list's for me not fulfilled dependecy to org.eclipse.ui
(3.4.0). Any hint to solve this problem ?
Greetings
Sebastian
Re: M5 Update Problem with Eclipse 3.3.2 [message #621819 is a reply to message #621818] Mon, 10 March 2008 08:32 Go to previous messageGo to next message
Sebastian,
This tells me that ECF 2.0.0 is targeting Eclipse 3.4 so you'll either
need to switch to using Eclipse 3.4 or you need to find an older version
of ECF that's based on Eclipse 3.3.x.
>> Eclipse Platform.
> Greetings
> Sebastian
Re: M5 Update Problem with Eclipse 3.3.2 [message #621820 is a reply to message #621819] Mon, 10 March 2008 10:08 Go to previous messageGo to next message
That can be the trick. But please don't announce 2.0.0M5 to be compatible
with eclipse 3.3 on your download page anymore in this case.
Thx Sebastian
Re: M5 Update Problem with Eclipse 3.3.2 [message #621821 is a reply to message #621820] Mon, 10 March 2008 10:40 Go to previous messageGo to next message
Sebastian,
That's a very good point1 Hopefully the misinformation on the download
page will be corrected soon.
> compatible with eclipse 3.3 on your download page anymore in this case.
> Thx Sebastian
Re: M5 Update Problem with Eclipse 3.3.2 [message #621822 is a reply to message #621820] Mon, 10 March 2008 15:03 Go to previous messageGo to next message
Hi Sebastian,
Yes, there were some erroneous 3.4 minimum dependencies present in
2.0.0M5b. In truth, 3.3 should work OK.
So these 3.4 dependencies are/will be removed, and a new integration
build (2.0.0M5c) will be done today (3/1/2008). Sorry about the trouble.
Scott
> Thx Sebastian
Re: M5 Update Problem with Eclipse 3.3.2 [message #621823 is a reply to message #621822] Mon, 10 March 2008 15:09 Go to previous messageGo to next message
Created bug to track
https://bugs.eclipse.org/bugs/show_bug.cgi?id=222102
Scott Lewis wrote:
> Hi Sebastian,
> Scott
>> Thx Sebastian
Re: M5 Update Problem with Eclipse 3.3.2 [message #621824 is a reply to message #621823] Mon, 10 March 2008 15:36 Go to previous messageGo to next message
It seems besides ecf you are working on a time-traveling machine ;-) Don't
worry, it confused me only a second.
Thank you for your great work with ecf !
Re: M5 Update Problem with Eclipse 3.3.2 [message #621825 is a reply to message #621824] Mon, 10 March 2008 15:42 Go to previous messageGo to next message
Hi Sebastian,
I wish :). Instead it's a stick '0' key :).
> Don't worry, it confused me only a second.
Thanks.
Scott
Re: M5 Update Problem with Eclipse 3.3.2 [message #621828 is a reply to message #621822] Tue, 11 March 2008 07:32 Go to previous messageGo to next message
Thx, now i installed ecf 2.0.05c successful on eclipse 3.3.2.
But now i could not join a project-specific collaboration session anymore,
because the Communications Menu has completely disappeared from a
project's context-menu.
Re: M5 Update Problem with Eclipse 3.3.2 [message #621829 is a reply to message #621828] Tue, 11 March 2008 11:34 Go to previous messageGo to next message
Hi Sebastian,
For UI simplicity, I removed the project-specific context menu item.
Multiple workspace level collab connections are still supported,
however...and editor context menu has "Share Resource to Collaboration:
<username>" to share resource references.
Scott
> anymore, because the Communications Menu has completely disappeared from
> a project's context-menu.
Re: M5 Update Problem with Eclipse 3.3.2 [message #621830 is a reply to message #621829] Tue, 11 March 2008 12:04 Go to previous message
Thx. Good to know.
Previous Topic:Re: Chat within Eclipse
Next Topic:RESCHEDULE: ECF conference call scheduled for 3/11/2008 moved to 3/13/2008
Current Time: Sat Jul 26 11:33:40 EDT 2025
Powered by FUDForum. Page generated in 0.04736 seconds
