Multiplicities and names in an Association [message #474696] |
Mon, 21 July 2008 10:40  |
Hello friends!
IŽm using UML2Tools and I didnŽt find where I should set some properties
of an association. This properties are:
-association name;
-association source;
-association multiplicity in the source;
-association target name;
-association multiplicity in the target;
Indeed, the UML2Tools let me set the association name, the source and
target names of an association, but theirs multiplicity I can just set on
of them.
Where should I set this properties?!
P.S.: It would be a great ideia if these properties could be changed as
the parameters in a method, like in a pop up window.
Thanks a lot,
Raphael
Re: Multiplicities and names in an Association [message #474928 is a reply to message #474696] |
Wed, 23 July 2008 13:16  |
Hi Raphael,
You can edit name, multiplicity, visibility and modifiers of an AssociationEnd
in the diagram editor. To do that:
-Select label for source or target name of an association.
-Press F2 to edit it.
-edited string will be parsed as Property did (UML 2.1, 7.3.44, Property):
<property> ::= [<visibility>] [‘/’] <name> [‘:’ <prop-type>] [‘[‘ <multiplicity>
‘]’] [‘=’ <default>][‘{‘ <prop-modifier > [‘,’ <prop-modifier >]* ’}’]
It means, if you print 'year [1..3]', an association end will get name 'year',
its lower value will be '1' and its upper value will be '3'.
Unfortunately, it's not possible now to see and edit other properties of
AssociationEnds in the diagram editor (bugzilla #174003 Impossible to edit
Association link source/destination properties in diagram editor). But you
can always use domain model editor(*.uml file) to do that.
Best wishes,
Tanya.
> Hello friends!
> properties of an association. This properties are:
> -association name;
> on of them.
> as the parameters in a method, like in a pop up window.
> Thanks a lot,
> Raphael
Re: Multiplicities and names in an Association [message #621732 is a reply to message #474696] |
Hi Raphael,
Best wishes,
Tanya.
> Hello friends!
> -association name;
> on of them.
> Thanks a lot,
> Raphael
FUDForum. Page generated in 0.04012 seconds
