Configuring navigation tabs in Infocenter [message #474711] |
Fri, 24 October 2008 11:29  |
I've developed a standalone Infocenter and have been asked if it would be
easy to remove the keyword Index tab and only have the Contents and Search
Results tabs visible. (My initial response was "no," but I thought I
should ask.)
I've not seen any preferences that control which tabs are visible and have
seen no discussions about removing tabs or it mentioned in the
documentation. Has anyone tried this or possibly point me in the right
direction?
Thanks much!
Mike
Re: Configuring navigation tabs in Infocenter [message #474715 is a reply to message #474713] |
Fri, 24 October 2008 14:13  |
Thanks so much, Chris and Lee Anne. I added the following to my
plugin_customization.ini file:
org.eclipse.help.base/indexView=false
And that removed the Index tab. You guys rock!
Chris Goldthorpe wrote:
> There is a customization to allow you to hide the index tab, it is
> org.eclipse.help.base.indexView, which when set to false hides the index
> view. I just looked for this in the documentation and could not find it,
> it seems that this missed getting documented. I will fix that.
Re: Configuring navigation tabs in Infocenter [message #621656 is a reply to message #474711] |
Fri, 24 October 2008 11:57  |
Originally posted by: nospam_kowalskilee.gmail.com
> be easy to remove the keyword Index tab and only have the Contents and
> Search Results tabs visible. (My initial response was "no," but I
> thought I should ask.)
> have seen no discussions about removing tabs or it mentioned in the
> direction?
> Thanks much!
> Mike
Hi Mike
I thought that at one point in time, if none of the doc plug-ins
declared the index extension point and had no index entries, the Index
tab would not be displayed. I can't recall if this is still the case in
3.4. I won't be able to run a test to confirm until later today--but
that is a direction that you can start looking in.
--Lee Anne
Re: Configuring navigation tabs in Infocenter [message #621657 is a reply to message #474712] |
Fri, 24 October 2008 12:20  |
You are correct that at one time the index tab was only shown if there
was no index. The problem with this approach was that the act of
testing to see whether the index existed caused the entire index to be
read due to the way the APIs and internal data structures work. We only
want to read the index data when the user selects the index tab.
>> direction?
>> Thanks much!
>> Mike
> Hi Mike
> --Lee Anne
Thanks Chris! [message #621658 is a reply to message #474713] |
Fri, 24 October 2008 13:37  |
Hi Chris, thanks for the info about the customization. I had forgotten
about that, and is a better way to do it. Gives us the power to turn
on/off the display. :-)
> Lee Anne wrote:
>>> would be easy to remove the keyword Index tab and only have the
>>> Contents and Search Results tabs visible. (My initial response was
>>> "no," but I thought I should ask.)
>>> right direction?
>>> Thanks much!
>>> Mike
>> Hi Mike
>> in 3.4. I won't be able to run a test to confirm until later
>> today--but that is a direction that you can start looking in.
>> --Lee Anne
Re: Configuring navigation tabs in Infocenter [message #621659 is a reply to message #474713] |
FUDForum. Page generated in 0.05063 seconds
