Editor is not an ITextEditor error [message #621604] |
Tue, 24 November 2009 10:55  |
I'm creating one ecore diagram in latest Ecore tools (Eclipse Modeling Galileo 3.5 + JDK 1.6), however when I right click anywhere on the diagram I get following error:
Message:
Editor is not an ITextEditor or editor inputs not equal mailto:org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramEditor@a32fb5
Exception stack trace:
An exception stack trace is not available.
Session data:
eclipse.buildId=M20090917-0800
java.version=1.6.0_16
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sr_CS
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.modeling.product
I think that this happened when I have deleted one package in a diagram, but I'm not sure.
thx, Milan
Re: Editor is not an ITextEditor error [message #621614 is a reply to message #621604] |
Wed, 25 November 2009 11:45  |
When I want to drag-n-drop a class from from one package in .ecore file shown in Project Explorer to the Ecore diagram, I get this exception:
Error
Wed Nov 25 17:42:44 CET 2009
Unhandled event loop exception
at org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramEditor$D ropTargetListener.getObjectsBeingDropped(EcoreDiagramEditor. java:395)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramDropTargetLi stener.updateTargetRequest(DiagramDropTargetListener.java:19 7)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramDropTargetLi stener.isEnabled(DiagramDropTargetListener.java:213)
at org.eclipse.jface.util.DelegatingDropAdapter.updateCurrentLi stener(DelegatingDropAdapter.java:365)
at org.eclipse.jface.util.DelegatingDropAdapter.dragEnter(Deleg atingDropAdapter.java:128)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java :60)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:7 70)
at org.eclipse.swt.dnd.DropTarget.DragEnter(DropTarget.java:297 )
at org.eclipse.swt.dnd.DropTarget$3.method3(DropTarget.java:243 )
at org.eclipse.swt.internal.ole.win32.COMObject.callback3(COMOb ject.java:92)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:363)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:289)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java :172)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
FUDForum. Page generated in 0.06082 seconds
