Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] EEF fails to create all classes
[EEF] EEF fails to create all classes [message #621600] Sat, 21 November 2009 22:26 Go to next message
I am trying to follow the EEF tutorial an generate custom Property Views for a simple ECore Model. I used the latest version of EEF (Nov 17) and an old one (Nov 10). I am not able to generate all classes, only <Model>PropertiesEditionComponent class is generated.
The error log shows few errors like:
java.lang.IllegalArgumentException
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.navigatePro perty(EcoreEvaluationEnvironment.java:178)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.navigatePro perty(EcoreEvaluationEnvironment.java:1)
at org.eclipse.ocl.EvaluationVisitorImpl.visitPropertyCallExp(E valuationVisitorImpl.java:1925)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitPropertyCallExp(AcceleoEvaluationVisitor.ja va:953)
at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.accept(Proper tyCallExpImpl.java:246)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor$ParameterInitExpression.accept(AcceleoEvaluation Visitor.java:1420)
at org.eclipse.ocl.EvaluationVisitorImpl.visitVariable(Evaluati onVisitorImpl.java:1976)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitVariable(Eva luationVisitorDecorator.java:340)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoQueryInvocation(AcceleoEvaluationVis itor.java:653)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 358)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:87 1)
at org.eclipse.acceleo.model.mtl.impl.spec.QueryInvocationSpec. accept(QueryInvocationSpec.java:45)
at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp( EvaluationVisitorImpl.java:161)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitOperationCallExp(AcceleoEvaluationVisitor.j ava:942)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:399)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab stractEvaluationVisitor.java:246)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E valuationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 366)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.evaluateGuards(AcceleoEvaluationVisitor.java:110 3)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.prepareInvocation(AcceleoEvaluationVisitor.java: 1233)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplateInvocation(AcceleoEvaluation Visitor.java:786)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 356)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.ja va:415)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 350)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoBlock(AcceleoEvaluationVisitor.java: 237)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:496)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 347)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoFileBlock(AcceleoEvaluationVisitor.j ava:304)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 353)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoIfBlock(AcceleoEvaluationVisitor.jav a:464)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:769)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 345)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(Query Impl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvalua te(AcceleoEngine.java:266)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate (AcceleoEngine.java:130)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate Template(AcceleoService.java:593)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate (AcceleoService.java:429)
at org.eclipse.emf.eef.codegen.components.SubPropertiesEditionC omponent.doGenerate(SubPropertiesEditionComponent.java:285)
at org.eclipse.emf.eef.codegen.ui.generators.common.GenerateAll .doGenerate(GenerateAll.java:122)
at org.eclipse.emf.eef.codegen.ui.generators.actions.AbstractGe nerateEEFAction$1.run(AbstractGenerateEEFAction.java:103)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
eclipse.buildId=M20090917-0800
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.modeling.product
Any help is greatly appreciated.
Ioan
Re: [EEF] EEF fails to create all classes [message #621601 is a reply to message #621600] Mon, 23 November 2009 02:56 Go to previous message
Hi Ioan,
It seems that Acceleo encounter troubles with you models. Can you
validate the 2 models in the .components file (editionContext and
repository) and ensure that they haven't problem.
Goulwen Le Fur - goulwen.lefur@obeo.fr
> Visitor.java:1420)
> Visitor.java:786)
> Impl.java:152)
> Ioan
Previous Topic:[EMF Compare] Move of an element
Next Topic:[EEF] EEF fails to create all classes
Current Time: Thu Jul 24 23:19:56 EDT 2025
Powered by FUDForum. Page generated in 0.05224 seconds
