| GenModel Doc in Ecore Diagram Editor [message #139266] |
Mon, 27 July 2009 11:57  |
Originally posted by: formatzeh.gmx.de
I want to know for what this option is good for in the properties view
of the Ecore Diagram Editor? I'm asking because I want to add some
documentation to the metaclasses in my metamodel. I thought that this
options is good for this as the name suggests it. But when I start the
second Eclipse instance with the generated editor I can't see my text in
that field on the elements being instances of the metaclass where I
added the documentation. So for what is it good for?
regards
Gilbert
| Re: GenModel Doc in Ecore Diagram Editor [message #369108 is a reply to message #369100] |
Tue, 28 July 2009 12:06  |
Jacques LESCOT wrote:
> If you wish to customize the message shown in the bottom status bar of
> the generated tree structure editor when you select an attribute in the
> Properties View, you can perform that in the *.genmodel file, through
> the "Property description" field when you have selected a Feature.
Thanks Jacques, this is a beginning :)
| Re: GenModel Doc in Ecore Diagram Editor [message #621260 is a reply to message #139266] |
Mon, 27 July 2009 12:38  |
Gilbert,
I think you need to change Suppress GenModel Annotations to false.
> regards
> Gilbert
| Re: GenModel Doc in Ecore Diagram Editor [message #621262 is a reply to message #139291] |
Mon, 27 July 2009 13:13  |
Ed Merks wrote:
> Gilbert,
Ok I did it. And where do I see the documenting text of the metaclass in
the second eclipse instance containing the generated editor?
| Re: GenModel Doc in Ecore Diagram Editor [message #621272 is a reply to message #139303] |
Tue, 28 July 2009 11:17  |
Gilbert,
That documentation is included in the generated code of your Java model.
For example, if you have created a Metaclass named "Element", if you
look into the generated Element.java class, you should see your text in
the Javadoc associated with that interface.
Jacques
Gilbert Mirenque a écrit :
> Ed Merks wrote:
>> Gilbert,
| Re: GenModel Doc in Ecore Diagram Editor [message #621277 is a reply to message #369100] |
FUDForum. Page generated in 0.16360 seconds
