Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] Bug in detecting added attributes?
| Re: [EMF Compare] Bug in detecting added attributes? [message #137369 is a reply to message #137358] |
Tue, 16 June 2009 13:04   |
Hi Laurent,
I guess I just catched another unpleasant bug in the other example of the zip (sorry for doing that just before the big release :-/ )
The emfdiff of the Eachonce/eachonce/model_v?.eachonce models contains two UpdateReferences with LeftTarget = RightTarget.
In other words, they do not describe a difference at all ;-)
However, from the two models I expected a change from null to an object, and from an object to null respectively.
I could add that to the existing bug or raise another one? Or did I miss something in this particular case?
Best regards
Patrick
On 16-06-2009 17:43, laurent Goubet wrote:
> Thanks, i'll try and investigate some more asap as we haven't detected
> such regressions in our tests :(
> Patrick Könemann a écrit :
>> No problem, looking forward to Galileo :-)
>> Sure, here it is: https://bugs.eclipse.org/bugs/show_bug.cgi?id=280449
>> Patrick
>> On 16-06-2009 15:06, laurent Goubet wrote:
>>> Hi Patrick,
>>> Looking at the image, this indeed looks like a bug. As we are currently
>>> working on the release of Galileo, could you raise a bugzilla for this
>>> with the zips and image so that I don't forget this needs fixing?
>>> Laurent Goubet
>>> Obeo
>>>> Cheers,
>>>> short version:
>>>> I think I found a bug in added attribute detection as shown here:
>>>> http://img268.imageshack.us/img268/2386/multiattributechange .png
>>>> (using the latest version from the CVS)
>>>> long(er) version:
>>>> I created a small model for testing the detection of all kinds of
>>>> differences:
>>>> http://imm.dtu.dk/~pk/files/eachonce.zip
>>>> http://imm.dtu.dk/~pk/files/eachonce-runtime.zip
>>>> eachonce.zip is a plugin project with a very simple ecore model
>>>> (including generated code) with just one EClass and some attributes
>>>> and references.
>>>> eachonce-runtime.zip contains example models for the runtime workbench:
>>>> Eachonce/attribute/ - the example above
>>>> Eachonce/eachonce/ - contains all different kinds of differences (14
>>>> in total)
>>>> Eachonce/reference/ - example from
>>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=270439 (fixed)
>>>> Best regards
>>>> Patrick
| Re: [EMF Compare] Bug in detecting added attributes? [message #137448 is a reply to message #137381] |
Thu, 18 June 2009 10:55  |
Hi Laurent,
I added steps for reproduction in the bug description.
Furthermore I found a ClassCastException in the 'Properties' tab is open in the compare view.
I also added this issue to that bug (because I couldn't reproduce it with another example - I tried a simple ecore model).
Patrick
On 17-06-2009 10:12, laurent Goubet wrote:
> Hi Patrick,
> The "*target" references of most DiffElement describe the value that is
> to be copied in either direction by the mergers, not the value actually
> changed (not sure I am really clear here :p). Thus tests on these values
> can yield strange results sometime.
> As you've already raised a bugzilla with both examples, you can add a
> comment and a more detailed description of the actual issue you see and
> how you've detected it ... I need to investigate to see if there is
> actually a bug or if it is intended behavior, yet bug fixing isn't our
> priority now except for blockers/criticals.
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Best regards
>> Patrick
>>>> Patrick
>>>>> Hi Patrick,
>>>>> currently
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Cheers,
>>>>>> short version:
>>>>>> long(er) version:
>>>>>> differences:
>>>>>> and references.
>>>>>> workbench:
>>>>>> in total)
>>>>>> Best regards
>>>>>> Patrick
| Re: [EMF Compare] Bug in detecting added attributes? [message #621028 is a reply to message #137311] |
Tue, 16 June 2009 09:06  |
--------------000703020000010802080405
Hi Patrick,
Laurent Goubet
Obeo
Patrick K
| Re: [EMF Compare] Bug in detecting added attributes? [message #621030 is a reply to message #137346] |
Tue, 16 June 2009 11:43  |
--------------040107030300030609010203
Patrick K
| Re: [EMF Compare] Bug in detecting added attributes? [message #621031 is a reply to message #137358] |
Hi Laurent,
Best regards
Patrick
>> Patrick
>>> Hi Patrick,
>>> Laurent Goubet
>>> Obeo
>>>> Cheers,
>>>> short version:
>>>> long(er) version:
>>>> differences:
>>>> and references.
>>>> in total)
>>>> Best regards
>>>> Patrick
| Re: [EMF Compare] Bug in detecting added attributes? [message #621032 is a reply to message #137369] |
Wed, 17 June 2009 04:12  |
--------------010203050201000400080009
Hi Patrick,
Laurent Goubet
Obeo
Patrick K
| Re: [EMF Compare] Bug in detecting added attributes? [message #621038 is a reply to message #137381] |
Hi Laurent,
Patrick
> Hi Patrick,
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> Best regards
>> Patrick
>>>> Patrick
>>>>> Hi Patrick,
>>>>> currently
>>>>> Laurent Goubet
>>>>> Obeo
>>>>>> Cheers,
>>>>>> short version:
>>>>>> long(er) version:
>>>>>> differences:
>>>>>> and references.
>>>>>> workbench:
>>>>>> in total)
>>>>>> Best regards
>>>>>> Patrick
Current Time: Mon Nov 03 14:25:06 EST 2025
Powered by FUDForum. Page generated in 0.06678 seconds
