Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] merge problem
[EMF Compare] merge problem [message #134579] Tue, 31 March 2009 11:42 Go to next message
I'd like to use the Merge service of the EMF compare project.
I can load ecore models from resources and I can create Match and
DiffModels ( using the Match and DiffService ), but when I get the
diffModel and I'd like to merge one of the parent model with the diff I
get the following exception:
java.util.ConcurrentModificationException
at
org.eclipse.emf.common.util.AbstractEList$EIterator.checkMod Count(AbstractEList.java:762)
at
org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(A bstractEList.java:716)
at
org.eclipse.emf.common.util.AbstractEList$EIterator.next(Abs tractEList.java:696)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:132)
at ...
Here is my code:
File file1 = getFileByFileName("v1.ecore");
File file2 = getFileByFileName("v2.ecore");
ResourceSet set = new ResourceSetImpl();
EObject root1 = ModelUtils.load(file1, set);
EObject root2 = ModelUtils.load(file2, set);
MatchModel matchModel = MatchService.doMatch(root1, root2, null);
DiffModel diffModel = DiffService.doDiff(matchModel);
MergeService.merge(diffModel.getOwnedElements(), true);
What should I have to do?
Fermo
Re: [EMF Compare] merge problem [message #134597 is a reply to message #134579] Wed, 01 April 2009 03:59 Go to previous messageGo to next message
--------------090300080904050307050002
Hi fermo,
There is a known possibility of ConcurrentModificationExceptions to be
thrown with the MergeService. To quote the Javadoc of
MergeService#merge(List<DiffElement>, boolean) :
@throws ConcurrentModificationException
Could be thrown if the list you give is directly a
reference from the meta model such as
{@link DiffModel#getOwnedElements()} or {@link
DiffElement#getSubDiffElements()}. Copy the
list before merging it.
and looking at your code, this is exactly what you're doing. You can
work around it by replacing
for
MergeService.merge(new
ArrayList<DiffElement>(diffModel.getOwnedElements()), true);
I do not copy the list in the merge code because of history reasons ...
this might be changeable now.
Laurent Goubet
Obeo
fermo a
Re: [EMF Compare] merge problem [message #134612 is a reply to message #134597] Wed, 01 April 2009 05:43 Go to previous message
Hi Laurent
Thank you very much for you help!
Fermo
Re: [EMF Compare] merge problem [message #620773 is a reply to message #134579] Wed, 01 April 2009 03:59 Go to previous message
Hi fermo,
for
Laurent Goubet
Obeo
fermo a
Re: [EMF Compare] merge problem [message #620774 is a reply to message #134597] Wed, 01 April 2009 05:43 Go to previous message
Hi Laurent
Fermo
Previous Topic:[EMF Compare] merge problem
Next Topic:EEF Toolchain
Current Time: Fri Nov 07 14:52:47 EST 2025
Powered by FUDForum. Page generated in 0.12345 seconds
