Home » Modeling » UML2 Tools » XMI Import
XMI Import [message #474563] Tue, 08 July 2008 05:20 Go to next message
IŽve a Problem with my XMI import. The following code snipped shows, how
my Import should work:
public static Resource loadXMI(String extension, String path){
//Initialize the UMLMetaModel package
UMLPackageImpl.init();
//create resource set and resource
ResourceSet resourceSet = new ResourceSetImpl();
//Register XML resource factory
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(extension,
new XMIResourceFactoryImpl());
//Create a resource
Resource resource = resourceSet.createResource(URI.createFileURI(path));
//Load the resource
try{
resource.load(null);
}catch (IOException e) {
e.printStackTrace();
return resource;
This import routine works with the following XMI-file:
<?xml version="1.0" encoding="ASCII"?>
<uml:Package xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" name="familyTreePackage">
<packagedElement xsi:type="uml:Class" name="Individual"
isAbstract="true">
<ownedAttribute name="vorname" visibility="private"/>
<ownedAttribute name="nachname"/>
<ownedOperation name="getName"/>
</packagedElement>
<packagedElement xsi:type="uml:Class" name="Male"/>
</uml:Package>
BUT when I try to import another XMI-File (which comes out of my
UML-tool), a exception is thrown:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with
uri 'null' not found.
(file:/D:/Strobel_Michael/Java/workspace_diploma/export.xmi, 3, 17)
at
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:81)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:189)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
at xmi.Import.loadAmeosXMI(Import.java:32)
at xmi.StartXmiImport.main(StartXmiImport.java:17)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'null' not found.
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1247)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1336)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:970)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:953)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:684)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
... 5 more
The XMI-File looks like this:
<?xml version="1.0" encoding= "ISO-8859-1"?>
<XMI xmi.version="1.1" xmlns:UML='org.omg.xmi.namespace.UML'>
<XMI.header>
<XMI.metamodel xmi.name="UML" xmi.version="1.4"/>
</XMI.header>
<XMI.content>
<UML:Model>
<UML:Namespace.ownedElement>
<UML:Class
xmi.id='UID_5098CBE8-3903-4530-A0BA-20B99298C6CD'
xmi.uuid='UID_5098CBE8-3903-4530-A0BA-20B99298C6CD'
name='Klasse2'
visibility='public'
isAbstract='false'
isRoot='true'
isLeaf='true'
isActive='false'
<UML:Classifier.feature>
<UML:Attribute
xmi.id='UID_3D5DA53B-9677-4fc6-929B-77AF1A481E6C'
xmi.uuid='UID_3D5DA53B-9677-4fc6-929B-77AF1A481E6C'
name='Attr2'
visibility='private'
comment=''
ownerScope='instance'
<UML:StructuralFeature.multiplicity>
<UML:Multiplicity>
<UML:Multiplicity.range>
<UML:MultiplicityRange lower='1'
upper='1'/>
</UML:Multiplicity.range>
</UML:Multiplicity>
</UML:StructuralFeature.multiplicity>
</UML:Attribute>
</UML:Classifier.feature>
</UML:Class>
<UML:Class
xmi.id='UID_A85A853F-7BA6-4f75-BC97-B2E197E7162B'
xmi.uuid='UID_A85A853F-7BA6-4f75-BC97-B2E197E7162B'
name='Klasse1'
visibility='public'
isAbstract='false'
isRoot='true'
isLeaf='true'
isActive='false'
<UML:Attribute
xmi.id='UID_E475B9C9-E9A5-4af4-A3B3-E4966B60FE8E'
xmi.uuid='UID_E475B9C9-E9A5-4af4-A3B3-E4966B60FE8E'
name='Attr1'
comment=''
<UML:Multiplicity>
upper='1'/>
</UML:Multiplicity>
</UML:Attribute>
</UML:Class>
<UML:Class
xmi.id='ID_DUMMY_CLASS'
name='Container_class_for_objects_and_actors'
visibility='public'
isRoot='true'
isLeaf='true'
isActive='true'
</UML:Namespace.ownedElement>
</UML:Model>
</XMI.content>
</XMI>
Sorry for the huge amount of code....! :)
Can anybody please help me??
Michael
Re: XMI Import [message #474564 is a reply to message #474563] Tue, 08 July 2008 08:20 Go to previous message
Michael,
Comments below.
Michael wrote:
> how my Import should work:
> //Create a resource
> Resource resource =
> //Load the resource
> try{
> } return resource;
> isAbstract="true">
> </packagedElement>
> </uml:Package>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 5 more
> <XMI.header>
> </XMI.header>
You're not going to be able to read UML 1.4 instances nor can EMF
consume XMI 1.x in general.
> <XMI.content>
> <UML:Model>
> <UML:Class
> name='Klasse2'
> visibility='public'
> isAbstract='false'
> isRoot='true'
> isLeaf='true'
> isActive='false'
> <UML:Attribute
> name='Attr2'
> comment=''
> <UML:Multiplicity>
> lower='1' upper='1'/>
> </UML:Multiplicity>
> </UML:Attribute>
> </UML:Class>
> <UML:Class
> name='Klasse1'
> visibility='public'
> isAbstract='false'
> isRoot='true'
> isLeaf='true'
> isActive='false'
> <UML:Attribute
> name='Attr1'
> comment=''
> <UML:Multiplicity>
> </UML:Multiplicity>
> </UML:Attribute>
> </UML:Class>
> <UML:Class xmi.id='ID_DUMMY_CLASS'
> visibility='public'
> isRoot='true' isLeaf='true'
> isActive='true'
> </UML:Model>
> </XMI.content>
> </XMI>
You'll only generally be able to read XMI 2.0 serializations and even
then, the serialization must conform some existing Ecore model, i.e, for
UML it better be some version of UML 2.x...
> Regards Michael
Re: XMI Import [message #620476 is a reply to message #474563] Tue, 08 July 2008 08:20 Go to previous message
Michael,
Comments below.
Michael wrote:
> //Create a resource
> Resource resource =
> //Load the resource
> try{
> } return resource;
> isAbstract="true">
> </packagedElement>
> </uml:Package>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> ... 5 more
> <XMI.header>
> </XMI.header>
> <XMI.content>
> <UML:Model>
> <UML:Class
> name='Klasse2'
> visibility='public'
> isAbstract='false'
> isRoot='true'
> isLeaf='true'
> isActive='false'
> <UML:Attribute
> name='Attr2'
> comment=''
> <UML:Multiplicity>
> </UML:Multiplicity>
> </UML:Attribute>
> </UML:Class>
> <UML:Class
> name='Klasse1'
> visibility='public'
> isAbstract='false'
> isRoot='true'
> isLeaf='true'
> isActive='false'
> <UML:Attribute
> name='Attr1'
> comment=''
> <UML:Multiplicity>
> </UML:Multiplicity>
> </UML:Attribute>
> </UML:Class>
> visibility='public'
> isActive='true'
> </UML:Model>
> </XMI.content>
> </XMI>
> Regards Michael
Previous Topic:XMI Import
Next Topic:Re: Unable to wrap long names... and other n00b questions :)
Current Time: Wed Jul 23 23:29:05 EDT 2025
Powered by FUDForum. Page generated in 0.04586 seconds
