Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] correct version for Eclipse 3.2.2 ??
[Teneo] correct version for Eclipse 3.2.2 ?? [message #80053] Tue, 17 April 2007 12:50 Go to next message
Martin,
I co-worked told me that he read somewhere, can't find it now, that 0.8.0
of Teneo requires Eclipse 3.3, and that 0.7.5 should be used with 3.2.
I am currently using Teneo 0.8.0 and Eclipse 3.2.2 with no problems. Is
this supports or should I be using 0.7.5 of Teneo.
Mark.
Re: [Teneo] correct version for Eclipse 3.2.2 ?? [message #80068 is a reply to message #80053] Tue, 17 April 2007 13:10 Go to previous messageGo to next message
Mark,
Teneo does not use specific Eclipse 3.3 features and what I understand is that emf 2.3 is binary
compatible with emf 2.2. So overall it should work. My testcases are however only run in two
configurations:
- Teneo 0.7.5 for emf 2.2 and eclipse 3.2
- Teneo 0.8.0 for emf 2.3 and eclipse 3.3
Note that new features are added to 0.8.0, while for 0.7.5 mainly only bugfixing is done.
So there is no definite answer if 0.8.0 always works fine for 3.2.2 but if you encounter issues with
this configuration then I will try to do my best to answer posts on the newsgroup.
gr. Martin
Mark wrote:
> Martin,
> 0.8.0 of Teneo requires Eclipse 3.3, and that 0.7.5 should be used with
> 3.2.
> Mark.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
teneo download URL for eclipse 3.2 [message #130075 is a reply to message #80068] Thu, 09 October 2008 12:00 Go to previous messageGo to next message
Originally posted by: sramasamy.ifmc.sdps.org
I'm looking for the download link for a version of Teneo that works with
Eclipse 3.2 . Can someone point me to the right URL. Couldn't locate it
on the teneo page on eclipse.org
-sud
Re: teneo download URL for eclipse 3.2 [message #130091 is a reply to message #130075] Fri, 10 October 2008 16:48 Go to previous message
Hi Sudhakar,
I have asked around but not yet got an answer. If I have more information then I will let you know.
gr. Martin
> Thanks
> -sud
The Netherlands
Cell: +31 (0)6 288 48 943
Re: [Teneo] correct version for Eclipse 3.2.2 ?? [message #604791 is a reply to message #80053] Tue, 17 April 2007 13:10 Go to previous message
Mark,
configurations:
gr. Martin
Mark wrote:
> Martin,
> 3.2.
> Mark.
The Netherlands
teneo download URL for eclipse 3.2 [message #620340 is a reply to message #80068] Thu, 09 October 2008 12:00 Go to previous message
-sud
Re: teneo download URL for eclipse 3.2 [message #620341 is a reply to message #130075] Fri, 10 October 2008 16:48 Go to previous message
Hi Sudhakar,
gr. Martin
> Thanks
> -sud
The Netherlands
Previous Topic:Re: emf compare
Next Topic:Code generation from ant or maven
Current Time: Sun Jul 27 13:01:38 EDT 2025
Powered by FUDForum. Page generated in 0.03943 seconds
