Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » JPOXMappingException: URI <X> does not translate to an eclass
JPOXMappingException: URI <X> does not translate to an eclass [message #128175] Wed, 06 August 2008 14:55 Go to next message
Originally posted by: richard.fritzson.gmail.com
I've been having pretty good success using Teneo to map a large ecore
model (based on OMG's KDM standard). However, one problem I've had to work
around is my inability to use abstract classes. (To get around this I've
converted all my abstract classes to concrete ones but this is no longer a
reasonable tactic.)
If I create an EReference and specify its EType to be an EClass whose
"abstract" property is "true" I get this error from GenerateJDO :
"JPOXMappingException: URI <X> does not translate to an eclass" where <X>
is the name of the abstract EClass.
This happens even when the abstract EClass has non abstract subclasses.
The simplest example of this can be created by taking the library example
and creating an abstract class Person, making it the superclass of Writer
and changing the EType of a library's Writers to Person.
I'm using Eclipse 3.4, jpox-1.1.9, jdo2 2.0 & bcel-5.2
If anyone has a suggestion for how I can address this, I would appreciate
it.
Thanks.
Rich Fritzson
The stack looks like this:
Aug 6, 2008 2:38:35 PM org.eclipse.emf.teneo.TeneoException <init>
SEVERE: Uri: Person does not translate to an eclass
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingException: Uri: Person does
at
org.eclipse.emf.teneo.jpox.mapper.MappingUtil.getImplNameOfE Class(MappingUtil.java:44)
at
org.eclipse.emf.teneo.jpox.mapper.association.OneToManyMappe r.map(OneToManyMapper.java:122)
at
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er.processPersistableMember(EClassFeatureMapper.java:172)
at
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er.map(EClassFeatureMapper.java:97)
at
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator.proce ssClassAnnotation(JPOXMappingGenerator.java:257)
at
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator.gener ate(JPOXMappingGenerator.java:139)
at
org.eclipse.emf.teneo.jpox.mapper.GenerateJDO.createORMapper File(GenerateJDO.java:127)
at
org.eclipse.emf.teneo.jpox.mapper.GenerateJDO.createORMapper File(GenerateJDO.java:92)
at org.eclipse.emf.teneo.jpox.mapper.GenerateJDO.main(GenerateJ DO.java:87)
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #128243 is a reply to message #128175] Thu, 07 August 2008 06:31 Go to previous messageGo to next message
--------------040005010105050904040000
Hi Richard,
Jpox requires each class to have a java implementation. Did you regenerate the source code after
specifying the abstract super class? Is the genmodel loaded from the ecore file or from the xsd?
I did the same as you did and programmatically generating the jdo file works fine. I have attached
the jdo file and the ecore to this post.
Let me know if you see a difference between what I did and you did.
Btw, support for Teneo is given on the emf newsgroup. I have cc-ed the emf newsgroup.
gr. Martin
Richard Fritzson wrote:
> work around is my inability to use abstract classes. (To get around this
> I've converted all my abstract classes to concrete ones but this is no
> longer a reasonable tactic.)
> <X> is the name of the abstract EClass.
> example and creating an abstract class Person, making it the superclass
> of Writer and changing the EType of a library's Writers to Person.
> appreciate it.
> Thanks.
> Rich Fritzson
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="library.ecore"
Content-Disposition: inline;
filename="library.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="library"
nsURI="http://www.eclipse.org/emf/teneo/samples/emf/sample/Library" nsPrefix="library">
<eClassifiers xsi:type="ecore:EClass" name="Book">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Book"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="kind" value="element"/>
<details key="name" value="title"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pages" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Int" unsettable="true">
<details key="name" value="pages"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="category" unique="false"
lowerBound="1" eType="#//BookCategory" defaultValueLiteral="Mystery" unsettable="true">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@Enumerated(ORDINAL)"/>
</eAnnotations>
<details key="name" value="category"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="author" lowerBound="1"
eType="#//Writer" eOpposite="#//Writer/books">
<details key="name" value="author"/>
</eAnnotations>
<details key="appinfo" value="@JoinColumn(name=&quot;schrijver&quot;)"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BookCategory">
<details key="name" value="BookCategory"/>
</eAnnotations>
<eLiterals name="Mystery"/>
<eLiterals name="ScienceFiction" value="1"/>
<eLiterals name="Biography" value="2"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="BookCategoryObject" instanceClassName="org.eclipse.emf.common.util.Enumerator">
<details key="name" value="BookCategory:Object"/>
<details key="baseType" value="BookCategory"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Library">
<details key="name" value="Library"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" unique="false" lowerBound="1"
<details key="name" value="name"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="writers" upperBound="-1"
eType="#//Person" containment="true">
<details key="name" value="writers"/>
</eAnnotations>
<eAnnotations source="teneo.hibernate">
<details key="appinfo" value=" @Fetch(SUBSELECT)&#xA;@ForeignKey(name=&quot;schrijv ers&quot;) "/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="books" upperBound="-1"
eType="#//Book" containment="true">
<details key="name" value="books"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Writer" eSuperTypes="#//Person">
<details key="name" value="Writer"/>
</eAnnotations>
</eAnnotations>
eType="#//Book" eOpposite="#//Book/author">
</eAnnotations>
<details key="value" value="@OneToMany(mappedBy=&quot;author&quot;)"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Person" abstract="true"/>
</ecore:EPackage>
name="mysql_a_o_package.jdo"
filename="mysql_a_o_package.jdo"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPCFET0NU WVBFIGpkbyBT
WVNURU0gImZpbGU6L2phdmF4L2pkby9qZG8uZHRkIj4KCjxqZG8+Cgk8cGFj a2FnZSBuYW1l
PSJvcmcuZWNsaXBzZS5lbWYudGVuZW8uc2FtcGxlcy5lbWYuc2FtcGxlLmxp YnJhcnkuaW1w
bCI+CgkJPGNsYXNzIG5hbWU9Im9yZy5lY2xpcHNlLmVtZi50ZW5lby5zYW1w bGVzLmVtZi5z
YW1wbGUubGlicmFyeS5pbXBsLkJvb2tJbXBsIiByZXF1aXJlcy1leHRlbnQ9 InRydWUiIHBl
cnNpc3RlbmNlLW1vZGlmaWVyPSJwZXJzaXN0ZW5jZS1jYXBhYmxlIiBkZXRh Y2hhYmxlPSJ0
cnVlIiB0YWJsZT0iYm9vayIgaWRlbnRpdHktdHlwZT0iZGF0YXN0b3JlIj4K CQkJPGltcGxl
bWVudHMgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLnRlbmVvLnNhbXBsZXMuZW1m LnNhbXBsZS5s
aWJyYXJ5LkJvb2siLz4KCQkJPGltcGxlbWVudHMgbmFtZT0ib3JnLmVjbGlw c2UuZW1mLnRl
bmVvLnNhbXBsZXMuZW1mLnNhbXBsZS5saWJyYXJ5LlNlcmlhbGl6YWJsZUVP YmplY3QiLz4K
CQkJPGltcGxlbWVudHMgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLmVjb3JlLkVP YmplY3QiLz4K
CQkJPGltcGxlbWVudHMgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLmNvbW1vbi5u b3RpZnkuTm90
aWZpZXIiLz4KCQkJPGltcGxlbWVudHMgbmFtZT0iamF2YS5pby5TZXJpYWxp emFibGUiLz4K
CQkJPGluaGVyaXRhbmNlIHN0cmF0ZWd5PSJuZXctdGFibGUiPgoJCQkJPGRp c2NyaW1pbmF0
b3IgY29sdW1uPSJkdHlwZSIgc3RyYXRlZ3k9InZhbHVlLW1hcCIgdmFsdWU9 IkJvb2siLz4K
CQkJPC9pbmhlcml0YW5jZT4KCQkJPHZlcnNpb24gc3RyYXRlZ3k9InZlcnNp b24tbnVtYmVy
IiBjb2x1bW49ImVfdmVyc2lvbiIvPgoJCQk8ZmllbGQgbmFtZT0idGl0bGUi IHBlcnNpc3Rl
bmNlLW1vZGlmaWVyPSJwZXJzaXN0ZW50IiBudWxsLXZhbHVlPSJleGNlcHRp b24iLz4KCQkJ
PGZpZWxkIG5hbWU9InBhZ2VzIiBwZXJzaXN0ZW5jZS1tb2RpZmllcj0icGVy c2lzdGVudCIg
bnVsbC12YWx1ZT0iZXhjZXB0aW9uIi8+CgkJCTxmaWVsZCBuYW1lPSJwYWdl c0VTZXQiIHBl
cnNpc3RlbmNlLW1vZGlmaWVyPSJwZXJzaXN0ZW50Ii8+CgkJCTxmaWVsZCBu YW1lPSJjYXRl
Z29yeSIgcGVyc2lzdGVuY2UtbW9kaWZpZXI9InBlcnNpc3RlbnQiIG51bGwt dmFsdWU9ImV4
Y2VwdGlvbiIgZW1iZWRkZWQ9InRydWUiLz4KCQkJPGZpZWxkIG5hbWU9ImNh dGVnb3J5RVNl
dCIgcGVyc2lzdGVuY2UtbW9kaWZpZXI9InBlcnNpc3RlbnQiLz4KCQkJPGZp ZWxkIG5hbWU9
ImF1dGhvciIgcGVyc2lzdGVuY2UtbW9kaWZpZXI9InBlcnNpc3RlbnQiIGRl bGV0ZS1hY3Rp
b249InJlc3RyaWN0IiBudWxsLXZhbHVlPSJub25lIj4KCQkJCTxmb3JlaWdu LWtleSBuYW1l
PSJib29rX2F1dGhvciIvPgoJCQkJPGNvbHVtbiBuYW1lPSJzY2hyaWp2ZXIi IGFsbG93cy1u
dWxsPSJ0cnVlIi8+CgkJCQk8ZXh0ZW5zaW9uIHZlbmRvci1uYW1lPSJqcG94 IiBrZXk9Imlt
cGxlbWVudGF0aW9uLWNsYXNzZXMiIHZhbHVlPSJvcmcuZWNsaXBzZS5lbWYu dGVuZW8uc2Ft
cGxlcy5lbWYuc2FtcGxlLmxpYnJhcnkuaW1wbC5Xcml0ZXJJbXBsIi8+CgkJ CTwvZmllbGQ+
CgkJPC9jbGFzcz4KCQk8Y2xhc3MgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLnRl bmVvLnNhbXBs
ZXMuZW1mLnNhbXBsZS5saWJyYXJ5LmltcGwuTGlicmFyeUltcGwiIHJlcXVp cmVzLWV4dGVu
dD0idHJ1ZSIgcGVyc2lzdGVuY2UtbW9kaWZpZXI9InBlcnNpc3RlbmNlLWNh cGFibGUiIGRl
dGFjaGFibGU9InRydWUiIHRhYmxlPSJsaWJyYXJ5IiBpZGVudGl0eS10eXBl PSJkYXRhc3Rv
cmUiPgoJCQk8aW1wbGVtZW50cyBuYW1lPSJvcmcuZWNsaXBzZS5lbWYudGVu ZW8uc2FtcGxl
cy5lbWYuc2FtcGxlLmxpYnJhcnkuTGlicmFyeSIvPgoJCQk8aW1wbGVtZW50 cyBuYW1lPSJv
cmcuZWNsaXBzZS5lbWYudGVuZW8uc2FtcGxlcy5lbWYuc2FtcGxlLmxpYnJh cnkuU2VyaWFs
aXphYmxlRU9iamVjdCIvPgoJCQk8aW1wbGVtZW50cyBuYW1lPSJvcmcuZWNs aXBzZS5lbWYu
ZWNvcmUuRU9iamVjdCIvPgoJCQk8aW1wbGVtZW50cyBuYW1lPSJvcmcuZWNs aXBzZS5lbWYu
Y29tbW9uLm5vdGlmeS5Ob3RpZmllciIvPgoJCQk8aW1wbGVtZW50cyBuYW1l PSJqYXZhLmlv
LlNlcmlhbGl6YWJsZSIvPgoJCQk8aW5oZXJpdGFuY2Ugc3RyYXRlZ3k9Im5l dy10YWJsZSI+
CgkJCQk8ZGlzY3JpbWluYXRvciBjb2x1bW49ImR0eXBlIiBzdHJhdGVneT0i dmFsdWUtbWFw
IiB2YWx1ZT0iTGlicmFyeSIvPgoJCQk8L2luaGVyaXRhbmNlPgoJCQk8dmVy c2lvbiBzdHJh
dGVneT0idmVyc2lvbi1udW1iZXIiIGNvbHVtbj0iZV92ZXJzaW9uIi8+CgkJ CTxmaWVsZCBu
YW1lPSJuYW1lIiBwZXJzaXN0ZW5jZS1tb2RpZmllcj0icGVyc2lzdGVudCIg bnVsbC12YWx1
ZT0iZXhjZXB0aW9uIi8+CgkJCTxmaWVsZCBuYW1lPSJ3cml0ZXJzIiBwZXJz aXN0ZW5jZS1t
b2RpZmllcj0icGVyc2lzdGVudCIgZGVsZXRlLWFjdGlvbj0icmVzdHJpY3Qi PgoJCQkJPGNv
bGxlY3Rpb24gZWxlbWVudC10eXBlPSJvcmcuZWNsaXBzZS5lbWYudGVuZW8u c2FtcGxlcy5l
bWYuc2FtcGxlLmxpYnJhcnkuaW1wbC5QZXJzb25JbXBsIiBkZXBlbmRlbnQt ZWxlbWVudD0i
dHJ1ZSI+CgkJCQkJPGV4dGVuc2lvbiB2ZW5kb3ItbmFtZT0ianBveCIga2V5 PSJjYWNoZS1s
YXp5LWxvYWRpbmciIHZhbHVlPSJ0cnVlIi8+CgkJCQk8L2NvbGxlY3Rpb24+ CgkJCQk8ZWxl
bWVudD4KCQkJCQk8Y29sdW1uIG5hbWU9ImxpYnJhcnlfd3JpdGVyc19lX2lk IiBhbGxvd3Mt
bnVsbD0idHJ1ZSIvPgoJCQkJPC9lbGVtZW50PgoJCQkJPG9yZGVyIGNvbHVt bj0iTElCUkFS
WV9XUklURVJTX0lEWCIvPgoJCQkJPGZvcmVpZ24ta2V5IGRlbGV0ZS1hY3Rp b249ImNhc2Nh
ZGUiIHVwZGF0ZS1hY3Rpb249ImNhc2NhZGUiIG5hbWU9ImxpYnJhcnlfd3Jp dGVycyIvPgoJ
CQk8L2ZpZWxkPgoJCQk8ZmllbGQgbmFtZT0iYm9va3MiIHBlcnNpc3RlbmNl LW1vZGlmaWVy
PSJwZXJzaXN0ZW50IiBkZWxldGUtYWN0aW9uPSJyZXN0cmljdCI+CgkJCQk8 Y29sbGVjdGlv
biBlbGVtZW50LXR5cGU9Im9yZy5lY2xpcHNlLmVtZi50ZW5lby5zYW1wbGVz LmVtZi5zYW1w
bGUubGlicmFyeS5pbXBsLkJvb2tJbXBsIiBkZXBlbmRlbnQtZWxlbWVudD0i dHJ1ZSI+CgkJ
CQkJPGV4dGVuc2lvbiB2ZW5kb3ItbmFtZT0ianBveCIga2V5PSJjYWNoZS1s YXp5LWxvYWRp
bmciIHZhbHVlPSJ0cnVlIi8+CgkJCQk8L2NvbGxlY3Rpb24+CgkJCQk8ZWxl bWVudD4KCQkJ
CQk8Y29sdW1uIG5hbWU9ImxpYnJhcnlfYm9va3NfZV9pZCIgYWxsb3dzLW51 bGw9InRydWUi
Lz4KCQkJCTwvZWxlbWVudD4KCQkJCTxvcmRlciBjb2x1bW49IkxJQlJBUllf Qk9PS1NfSURY
Ii8+CgkJCQk8Zm9yZWlnbi1rZXkgZGVsZXRlLWFjdGlvbj0iY2FzY2FkZSIg dXBkYXRlLWFj
dGlvbj0iY2FzY2FkZSIgbmFtZT0ibGlicmFyeV9ib29rcyIvPgoJCQk8L2Zp ZWxkPgoJCTwv
Y2xhc3M+CgkJPGNsYXNzIG5hbWU9Im9yZy5lY2xpcHNlLmVtZi50ZW5lby5z YW1wbGVzLmVt
Zi5zYW1wbGUubGlicmFyeS5pbXBsLldyaXRlckltcGwiIHJlcXVpcmVzLWV4 dGVudD0idHJ1
ZSIgcGVyc2lzdGVuY2UtbW9kaWZpZXI9InBlcnNpc3RlbmNlLWNhcGFibGUi IGRldGFjaGFi
bGU9InRydWUiIGlkZW50aXR5LXR5cGU9ImRhdGFzdG9yZSI+CgkJCTxpbXBs ZW1lbnRzIG5h
bWU9Im9yZy5lY2xpcHNlLmVtZi50ZW5lby5zYW1wbGVzLmVtZi5zYW1wbGUu bGlicmFyeS5X
cml0ZXIiLz4KCQkJPGluaGVyaXRhbmNlIHN0cmF0ZWd5PSJzdXBlcmNsYXNz LXRhYmxlIj4K
CQkJCTxkaXNjcmltaW5hdG9yIHZhbHVlPSJXcml0ZXIiLz4KCQkJPC9pbmhl cml0YW5jZT4K
CQkJPHZlcnNpb24gc3RyYXRlZ3k9InZlcnNpb24tbnVtYmVyIiBjb2x1bW49 ImVfdmVyc2lv
biIvPgoJCQk8ZmllbGQgbmFtZT0ibmFtZSIgcGVyc2lzdGVuY2UtbW9kaWZp ZXI9InBlcnNp
c3RlbnQiIG51bGwtdmFsdWU9Im5vbmUiLz4KCQkJPGZpZWxkIG5hbWU9ImJv b2tzIiBwZXJz
aXN0ZW5jZS1tb2RpZmllcj0icGVyc2lzdGVudCIgbWFwcGVkLWJ5PSJhdXRo b3IiIGRlbGV0
ZS1hY3Rpb249InJlc3RyaWN0Ij4KCQkJCTxjb2xsZWN0aW9uIGVsZW1lbnQt dHlwZT0ib3Jn
LmVjbGlwc2UuZW1mLnRlbmVvLnNhbXBsZXMuZW1mLnNhbXBsZS5saWJyYXJ5 LmltcGwuQm9v
a0ltcGwiIGRlcGVuZGVudC1lbGVtZW50PSJmYWxzZSI+CgkJCQkJPGV4dGVu c2lvbiB2ZW5k
b3ItbmFtZT0ianBveCIga2V5PSJjYWNoZS1sYXp5LWxvYWRpbmciIHZhbHVl PSJ0cnVlIi8+
CgkJCQk8L2NvbGxlY3Rpb24+CgkJCQk8b3JkZXIgY29sdW1uPSJXUklURVJf Qk9PS1NfSURY
Ii8+CgkJCQk8Zm9yZWlnbi1rZXkgZGVsZXRlLWFjdGlvbj0icmVzdHJpY3Qi IHVwZGF0ZS1h
Y3Rpb249ImNhc2NhZGUiLz4KCQkJPC9maWVsZD4KCQk8L2NsYXNzPgoJCTxj bGFzcyBuYW1l
bC5QZXJzb25JbXBsIiByZXF1aXJlcy1leHRlbnQ9InRydWUiIHBlcnNpc3Rl bmNlLW1vZGlm
aWVyPSJwZXJzaXN0ZW5jZS1jYXBhYmxlIiBkZXRhY2hhYmxlPSJ0cnVlIiB0 YWJsZT0icGVy
c29uIiBpZGVudGl0eS10eXBlPSJkYXRhc3RvcmUiPgoJCQk8aW1wbGVtZW50 cyBuYW1lPSJv
cmcuZWNsaXBzZS5lbWYudGVuZW8uc2FtcGxlcy5lbWYuc2FtcGxlLmxpYnJh cnkuUGVyc29u
Ii8+CgkJCTxpbXBsZW1lbnRzIG5hbWU9Im9yZy5lY2xpcHNlLmVtZi50ZW5l by5zYW1wbGVz
LmVtZi5zYW1wbGUubGlicmFyeS5TZXJpYWxpemFibGVFT2JqZWN0Ii8+CgkJ CTxpbXBsZW1l
bnRzIG5hbWU9Im9yZy5lY2xpcHNlLmVtZi5lY29yZS5FT2JqZWN0Ii8+CgkJ CTxpbXBsZW1l
bnRzIG5hbWU9Im9yZy5lY2xpcHNlLmVtZi5jb21tb24ubm90aWZ5Lk5vdGlm aWVyIi8+CgkJ
CTxpbXBsZW1lbnRzIG5hbWU9ImphdmEuaW8uU2VyaWFsaXphYmxlIi8+CgkJ CTxpbmhlcml0
YW5jZSBzdHJhdGVneT0ibmV3LXRhYmxlIj4KCQkJCTxkaXNjcmltaW5hdG9y IGNvbHVtbj0i
ZHR5cGUiIHN0cmF0ZWd5PSJ2YWx1ZS1tYXAiIHZhbHVlPSJQZXJzb24iLz4K CQkJPC9pbmhl
cml0YW5jZT4KCQkJPHZlcnNpb24gc3RyYXRlZ3k9InZlcnNpb24tbnVtYmVy IiBjb2x1bW49
ImVfdmVyc2lvbiIvPgoJCTwvY2xhc3M+Cgk8L3BhY2thZ2U+CjwvamRvPg==
--------------040005010105050904040000--
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #128287 is a reply to message #128243] Thu, 07 August 2008 10:31 Go to previous messageGo to next message
Hi Martin,
Thanks for the quick response.
I did regenerate the source code after changing the ecore model. The
genmodel is loaded from the ecore file.
I've looked over your files and reread your note. Here are the differences
I see which might make a difference.
- Judging by your package.jdo your source code seems to contain a
PersonImpl.java file; mine does not. I get a Person.java file containing
the Interface definition, but not a PersonImpl.java file. (For the Writer
class I get both Writer.java and WriterImpl.java.) I assumed this was
standard for an abstract class, but I don't have much experience with this.
- You also wrote that you programmatically generate your jdo file while
I've been right clicking on the model. If I switch to doing this
programmaticallyl, are there particular options I ought to be passing to
the process?
My ecore model doesn't have the extended metadata that yours has, but it
isn't clear to me that this would make a difference.
I appreciate your help with this.
regards,
Rich
Martin Taal wrote:
> Hi Richard,
newsgroup.
> gr. Martin
>> Hi,
>> appreciate it.
>> Thanks.
>> Rich Fritzson
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #128326 is a reply to message #128287] Thu, 07 August 2008 10:45 Go to previous messageGo to next message
Richard,
Comments below.
> Hi Martin,
> differences I see which might make a difference.
Maybe you marked as it as "isInterface" true so that no Impl is
generated? It's generally better to generate an Impl so that
implementations of derived EClasses can share a common base
implementation class.
> I get a Person.java file containing the Interface definition, but not
> a PersonImpl.java file. (For the Writer class I get both Writer.java
> and WriterImpl.java.) I assumed this was standard for an abstract
> while I've been right clicking on the model. If I switch to doing this
> to the process?
> it isn't clear to me that this would make a difference.
Have a look to see if you've marked your model to make the EClass purely
an interface
> regards,
> Rich
> Martin Taal wrote:
>> Hi Richard,
>> regenerate
>> ecore
>> file works
>> the emf
> newsgroup.
>> gr. Martin
>>> Hi,
>>> ecore model (based on OMG's KDM standard). However, one problem I've
>>> had to work around is my inability to use abstract classes. (To get
>>> around this I've converted all my abstract classes to concrete ones
>>> but this is no longer a reasonable tactic.)
>>> whose "abstract" property is "true" I get this error from
>>> GenerateJDO : "JPOXMappingException: URI <X> does not translate to
>>> an eclass" where <X> is the name of the abstract EClass.
>>> superclass of Writer and changing the EType of a library's Writers
>>> to Person.
>>> appreciate it.
>>> Thanks.
>>> Rich Fritzson
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #128378 is a reply to message #128326] Thu, 07 August 2008 11:26 Go to previous message
Ed Merks wrote:
> Richard,
> an interface
Bingo.
I actually like feeling stupid because it's a sure sign I learned
something. :-)
Now that my simple example works I have alot of editing to do on a much
larger ecore model.
Many thanks for the tip.
Rich
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #620201 is a reply to message #128175] Thu, 07 August 2008 06:31 Go to previous message
Hi Richard,
gr. Martin
> appreciate it.
> Thanks.
> Rich Fritzson
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #620204 is a reply to message #128243] Thu, 07 August 2008 10:31 Go to previous message
Hi Martin,
the process?
regards,
Rich
Martin Taal wrote:
> Hi Richard,
newsgroup.
> gr. Martin
>> Hi,
>> appreciate it.
>> Thanks.
>> Rich Fritzson
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #620207 is a reply to message #128287] Thu, 07 August 2008 10:45 Go to previous message
Richard,
Comments below.
> Hi Martin,
> to the process?
an interface
> regards,
> Rich
> Martin Taal wrote:
>> Hi Richard,
>> regenerate
>> ecore
>> file works
>> the emf
> newsgroup.
>> gr. Martin
>>> Hi,
>>> to Person.
>>> appreciate it.
>>> Thanks.
>>> Rich Fritzson
Re: JPOXMappingException: URI <X> does not translate to an eclass [message #620211 is a reply to message #128326] Thu, 07 August 2008 11:26 Go to previous message
Ed Merks wrote:
> Richard,
> an interface
Bingo.
something. :-)
larger ecore model.
Rich
Previous Topic:common XML framework
Next Topic:Re: EMF Refactoring Plugin
Current Time: Sun Jul 27 09:58:05 EDT 2025
Powered by FUDForum. Page generated in 0.04791 seconds
