Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » JPA Temporal annotation doesn't work for EReference features
JPA Temporal annotation doesn't work for EReference features [message #127259] |
Fri, 18 July 2008 13:21  |
When I specify JPA @Temporal annotation on EReference feature I get the
following exception:
org.eclipse.emf.teneo.annotations.parser.AnnotationParserExc eption: The
eclass: HbAnnotatedEReference does not have an efeature for Temporal
Is it correct? The reason I use @Temporal annotation instead of
transient="true" property is that I want to have an attribute persisted
with teneo, but not serialized by XMLResoure. Is any workaround for this
case?
Thanks in advance for any your answers
Alexey Koloskov
Re: JPA Temporal annotation doesn't work for EReference features [message #127271 is a reply to message #127259] |
Fri, 18 July 2008 13:40   |
Hi Alexey,
The Temporal attribute can be used but only on an EAttribute. It specifies that the EAttribute is a
date or time. So I think you would need something else.
The transient attribute can be used to prevent serializing to xml but this attribute is also used by
Teneo.
Ed, is there another EMF attribute which can be used?
btw, I cross-posted to the EMF newsgroup as support for Teneo is given there.
gr. Martin
koloale wrote:
> Hello,
> case?
> Regards,
> Alexey Koloskov
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: JPA Temporal annotation doesn't work for EReference features [message #127353 is a reply to message #127282] |
Mon, 21 July 2008 05:13   |
Sorry, I confused @Transient annotation with @Temporal.
So, I can add this annotation to not persist features that haven't
transient="true" propery set on model.
But now I also need to persist fields marked as transient in Ecore model
with Teneo in DB, in order to solve my problem of serializing some
fileds in XML but not in DB and vice versa. Is there any ways to do
this? One way is to manualy unSet features that I don't want to
serialize in XML. May be there is some annotation that force Teneo to
persist features let pass transient="true" property?
Ed Merks пишет:
> Martin,
> No, only transient things aren't serialized. And things for which
> eIsSet returns false...
> Martin Taal wrote:
>> Hi Alexey,
>> specifies that the EAttribute is a date or time. So I think you would
>> this attribute is also used by Teneo.
>> there.
>> gr. Martin
>> koloale wrote:
>>> Hello,
>>> the following exception:
>>> The eclass: HbAnnotatedEReference does not have an efeature for Temporal
>>> persisted with teneo, but not serialized by XMLResoure. Is any
>>> workaround for this case?
>>> Regards,
>>> Alexey Koloskov
Re: JPA Temporal annotation doesn't work for EReference features [message #127366 is a reply to message #127353] |
Mon, 21 July 2008 05:39  |
Hi Alexey,
There is currently no way of doing this. You can add a bugzilla for this, so I can add an option to
control this.
As a workaround a (very) dirty trick would be to set the Transient to false (in the in-memory
structuralfeature) then let Teneo do the mapping (is done in the datastore.initialize step) and then
programmatically repair the transient value in the structural feature after the datastore.initialize.
gr. Martin
> Ed Merks пишет:
>> Martin,
>> Martin Taal wrote:
>>> Hi Alexey,
>>> given there.
>>> gr. Martin
>>> koloale wrote:
>>>> Hello,
>>>> Temporal
>>>> Regards,
>>>> Alexey Koloskov
The Netherlands
Re: JPA Temporal annotation doesn't work for EReference features [message #620124 is a reply to message #127259] |
Hi Alexey,
Teneo.
gr. Martin
koloale wrote:
> Hello,
> case?
> Regards,
> Alexey Koloskov
The Netherlands
Re: JPA Temporal annotation doesn't work for EReference features [message #620125 is a reply to message #127271] |
Fri, 18 July 2008 16:32  |
Martin,
Martin Taal wrote:
> Hi Alexey,
> there.
> gr. Martin
> koloale wrote:
>> Hello,
>> Regards,
>> Alexey Koloskov
Re: JPA Temporal annotation doesn't work for EReference features [message #620132 is a reply to message #127282] |
Ed Merks пишет:
> Martin,
> Martin Taal wrote:
>> Hi Alexey,
>> there.
>> gr. Martin
>> koloale wrote:
>>> Hello,
>>> Regards,
>>> Alexey Koloskov
Re: JPA Temporal annotation doesn't work for EReference features [message #620134 is a reply to message #127353] |
Hi Alexey,
control this.
gr. Martin
> Ed Merks пишет:
>> Martin,
>> Martin Taal wrote:
>>> Hi Alexey,
>>> given there.
>>> gr. Martin
>>> koloale wrote:
>>>> Hello,
>>>> Temporal
>>>> Regards,
>>>> Alexey Koloskov
The Netherlands
Current Time: Thu Jul 24 21:53:27 EDT 2025
Powered by FUDForum. Page generated in 2.67553 seconds
