Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo/Hibernate]Check for running DB
[Teneo/Hibernate]Check for running DB [message #127206] Thu, 17 July 2008 10:27 Go to next message
Originally posted by: felixostertag.web.de
Hi again,
short question:
is there any possibility to check if a database is running and if not,
start one?
right now, if there is no DB running, an exception is thrown in the
hbds.initialize() method. but bad enough i can't catch it in a try/catch
block. (i traced the exception down to the buildSessionFactory, but lost
it then).
is there any (easy ;) ) way to check, (starting is no problem) or do i
have to start it always, just in case?
thx
felix
Re: [Teneo/Hibernate]Check for running DB [message #127233 is a reply to message #127206] Thu, 17 July 2008 12:27 Go to previous messageGo to next message
Hi Felix,
No I don't know another method than creating your own sql connection and see if it fails. I am not
sure but it is even possible that it will take a while before it fails (because of timeout settings).
I crossposted to the emf newsgroup, that's where support for Teneo is now given.
gr. Martin
Felix wrote:
> Hi again,
> short question:
> start one?
> it then).
> thx
> felix
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo/Hibernate]Check for running DB [message #127246 is a reply to message #127233] Fri, 18 July 2008 04:56 Go to previous message
thx for your quick answer martin. then i stick with this solution, at
least for testing.
Martin Taal wrote:
> Hi Felix,
given.
> gr. Martin
> Felix wrote:
>> Hi again,
>> short question:
>> start one?
>> it then).
>> thx
>> felix
Re: [Teneo/Hibernate]Check for running DB [message #620121 is a reply to message #127206] Thu, 17 July 2008 12:27 Go to previous message
Hi Felix,
gr. Martin
Felix wrote:
> Hi again,
> short question:
> start one?
> it then).
> thx
> felix
The Netherlands
Re: [Teneo/Hibernate]Check for running DB [message #620122 is a reply to message #127233] Fri, 18 July 2008 04:56 Go to previous message
least for testing.
Martin Taal wrote:
> Hi Felix,
given.
> gr. Martin
> Felix wrote:
>> Hi again,
>> short question:
>> start one?
>> it then).
>> thx
>> felix
Previous Topic:Re: org.eclipse.emf.mwe?
Next Topic:JPA Temporal annotation doesn't work for EReference features
Current Time: Sat Jul 19 02:41:52 EDT 2025
Powered by FUDForum. Page generated in 0.04764 seconds
