Home » Modeling » UML2 » heavyweight extension in OMG specifications
heavyweight extension in OMG specifications [message #473087] Sun, 03 June 2007 05:12 Go to next message
Are both of the heavyweight and the middleweight extensions that you
illustrated are considered the (first-class extensibility)heavyweight
extension mechanism that specified by the UML specification?
In many articles and papers, it refers to the heavyweight extension that
was defined by the MOF. I opened the MOF specification and I didn't
any mention to heavyweight or first-class extensibility. The only thing
that I found is Extension package, which I didn't understand its usage.
Do you clear this to me?
Are the package import and emerge considered essential steps while
applying the heavyweight extension?
Thanks in advance,
Manar
Re: heavyweight extension in OMG specifications [message #473092 is a reply to message #473087] Mon, 04 June 2007 16:03 Go to previous messageGo to next message
Hi Manar,
The heavyweight and middleweight extension mechanisms are not explicitly
mentioned in the MOF specification however, the notion of using package
merge to define languages is mentioned and forms the bases of heavyweight
and middleweight extensions.
UML itself is built using the package merge concept and extensions can also
be achieved with the same technique.
By the way, the terminology "Middleweight" and "Heavyweight" are terms
coined by Kenn Hussey and are not really official OMG terminology. We try
to be consistent when using them in documentation etc. The document in the
"Improved Documentation" bugzilla uses a slightly different term but will be
updated.
Package import and merge are somewhat key to these kinds of extension
mechanisms.
- James.
"Manar El-Kady" <manar.elkady@gmail.com> wrote in message
news:f3u0mr$q90$1@build.eclipse.org...
> Thanks in advance,
> Manar
Re: heavyweight extension in OMG specifications [message #473094 is a reply to message #473092] Mon, 04 June 2007 23:34 Go to previous messageGo to next message
Actually, I believe the UML and/or MOF specification does use the term
"heavyweight" when referring to extensions built by merging one or more
packages from UML (InfrastructureLibrary) - I certainly didn't invent this
term.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f41r75$780$2@build.eclipse.org...
> Hi Manar,
> also
> the
> be
> updated.
> mechanisms.
> Regards,
> - James.
>> Hi,
>> Thanks in advance,
>> Manar
Re: heavyweight extension in OMG specifications [message #473188 is a reply to message #473094] Tue, 12 June 2007 11:42 Go to previous messageGo to next message
I think the terms "Middleweight" and "Flyweight" are not mentioned in the
spec. Although the use of keywords and package merge are mentioned.
You gotta take credit for something Kenn :)
- James.
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f42lk8$6at$1@build.eclipse.org...
> term.
> Kenn
> > Hi Manar,
heavyweight
> > also
try
> > the
will
> > be
> > updated.
> > mechanisms.
> > Regards,
> > - James.
> >> Hi,
that
> >> Thanks in advance,
> >> Manar
Re: heavyweight extension in OMG specifications [message #473189 is a reply to message #473188] Tue, 12 June 2007 12:17 Go to previous messageGo to next message
Hi James,
Where and how are use of keywords mentioned in the spec? I've had the
concern that keywords are not part of the standard metamodel, and
therefore not portable across UML tools. The UML2 model implements
these as EMF annotations, or XMI extensions.
Although keywords appear to be quite useful, I try to avoid them due to
non-standard representation.
Dave
Re: heavyweight extension in OMG specifications [message #473190 is a reply to message #473189] Tue, 12 June 2007 13:00 Go to previous messageGo to next message
Hi Dave,
Keywords are mentioned in Annex B of the spec.
They do have a non-standard representation and are saved as annotations as
you mentioned. Therefore, if you decide to export your model to XMI, the
annotations will be moved into XMI extensions.
Keywords have limited functionality, they are just a way to visually
distinguish between similar looking items. There is no concept of a
dictionary to share with others, no way to validate the appplication of
keywords etc.
There is support in the API with Element#addKeyword, Element#getKeyword()
Element#removeKeyword().
- James.
"Dave Carlson" <dcarlson@xmlmodeling.com> wrote in message
news:f4mgul$9ck$1@build.eclipse.org...
> Hi James,
> Dave
the
Re: heavyweight extension in OMG specifications [message #473191 is a reply to message #473190] Tue, 12 June 2007 13:42 Go to previous messageGo to next message
Thanks, James. Yes, I've used the API support for both setting and
reading keywords. The greatest confusion among modeling users is when
working with RSM/A, where there is a nice Keywords field right on the
Stereotypes tab... So, especially when users have worked with Rose,
they see the Keyword as synonymous with a stereotype (Rose had a very
relaxed idea of stereotypes, where you could just type anything into the
Stereotype field).
So, anyway, my question relates more to to what kind of advice I should
give these users. I generally tell them to avoid using keywords unless,
as you say, they only want to visually distinguish model elements.
I'll check Annex B as a reference that I can pass on to others.
Dave
James Bruck wrote:
> Hi Dave,
> keywords etc.
Re: heavyweight extension in OMG specifications [message #473197 is a reply to message #473191] Wed, 13 June 2007 09:47 Go to previous message
Hi Dave,
Apart from just explaining the differences between keywords and stereotypes
and pointing them to Annex B of the UML superstructure spec.
http://www.omg.org/docs/ptc/06-04-02.pdf or later ( there is a 07-02-05
version), I don't think I would have other advice.
The use of Keywords and Stereotypes in UML 1.4 ( as Rose was using ) and
2.1.1 is significantly different and users have to understand that.
One other resource would be an article that will be published soon called
"Customizing UML: Which technique is right for you?" It will explain the
use of keywords/profiles to customize UML. It is currently in draft form
attached to a bugzilla called "Improved Documentation".
I'm not sure if RSM/A has a help topic on this but perhaps you could suggest
it to them if this is something you would really like to see.
- James.
news:f4mlte$ojq$1@build.eclipse.org...
> Stereotype field).
> Dave
> James Bruck wrote:
> > Hi Dave,
as
the
> > keywords etc.
Re: heavyweight extension in OMG specifications [message #619680 is a reply to message #473087] Mon, 04 June 2007 16:03 Go to previous message
Hi Manar,
updated.
mechanisms.
- James.
> Thanks in advance,
> Manar
Re: heavyweight extension in OMG specifications [message #619682 is a reply to message #473092] Mon, 04 June 2007 23:34 Go to previous message
term.
Kenn
> Hi Manar,
> also
> the
> be
> updated.
> mechanisms.
> Regards,
> - James.
>> Hi,
>> Thanks in advance,
>> Manar
Re: heavyweight extension in OMG specifications [message #621556 is a reply to message #473094] Tue, 12 June 2007 11:42 Go to previous message
- James.
> term.
> Kenn
> > Hi Manar,
heavyweight
> > also
try
> > the
will
> > be
> > updated.
> > mechanisms.
> > Regards,
> > - James.
> >> Hi,
that
> >> Thanks in advance,
> >> Manar
Re: heavyweight extension in OMG specifications [message #621559 is a reply to message #473188] Tue, 12 June 2007 12:17 Go to previous message
Hi James,
Dave
Re: heavyweight extension in OMG specifications [message #621561 is a reply to message #473189] Tue, 12 June 2007 13:00 Go to previous message
Hi Dave,
keywords etc.
- James.
> Hi James,
> Dave
the
Re: heavyweight extension in OMG specifications [message #621564 is a reply to message #473190] Tue, 12 June 2007 13:42 Go to previous message
Stereotype field).
Dave
James Bruck wrote:
> Hi Dave,
> keywords etc.
Re: heavyweight extension in OMG specifications [message #621578 is a reply to message #473191] Wed, 13 June 2007 09:47 Go to previous message
Hi Dave,
- James.
> Stereotype field).
> Dave
> James Bruck wrote:
> > Hi Dave,
as
the
> > keywords etc.
Previous Topic:TOPCASED and tagged values?
Next Topic:Load Model from Enterprise Architect
Current Time: Sat Jul 19 00:13:16 EDT 2025
Powered by FUDForum. Page generated in 0.46831 seconds
