Home » Modeling » UML2 » How do I refer to Types in another uml model?
How do I refer to Types in another uml model? [message #473050] Wed, 30 May 2007 16:37 Go to next message
I have two uml models and corresponding ecore exported files. I would like
to refer the Types in one of these uml models in another uml model. Is it
possible? Also how do I make sure that corresponding ecore files are
referenced as well?
Currently I am creating primitive types whenever I need to refer to such a
type. But they are simply too many of them.
Pradeep
Re: How do I refer to Types in another uml model? [message #473069 is a reply to message #473050] Thu, 31 May 2007 16:07 Go to previous messageGo to next message
Hi Pradeep,
You could do something like what is done with the primitive types libraries
under org.eclipse.uml2.uml.resources\libraries.
If you want to use those, you could select "Load Resource..." from your "UML
Editor" menu, then you use use the types in the libraries.
When you export to ecore, you should get prompted to export those referenced
libraries at that time.
- James.
"Pradeep" <eclipseuser123@yahoo.com> wrote in message
news:f3kn9p$fkv$1@build.eclipse.org...
> referenced as well?
> Thanks
> Pradeep
Re: How do I refer to Types in another uml model? [message #473075 is a reply to message #473069] Fri, 01 June 2007 09:07 Go to previous message
See also the "Introduction to UML2 Profiles" article
( http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html)
on the UML2 documentation page for an explanation of how to reuse types from
type libraries.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f3n9ui$r77$2@build.eclipse.org...
> Hi Pradeep,
> libraries
> "UML
> referenced
> - James.
>> Hi,
>> like
>> referenced as well?
>> a
>> Thanks
>> Pradeep
Re: How do I refer to Types in another uml model? [message #619425 is a reply to message #473050] Thu, 31 May 2007 16:07 Go to previous message
Hi Pradeep,
- James.
> referenced as well?
> Thanks
> Pradeep
Re: How do I refer to Types in another uml model? [message #619438 is a reply to message #473069] Fri, 01 June 2007 09:07 Go to previous message
type libraries.
Kenn
> Hi Pradeep,
> libraries
> "UML
> referenced
> - James.
>> Hi,
>> like
>> referenced as well?
>> a
>> Thanks
>> Pradeep
Previous Topic:OCL Constraints within UML2
Next Topic:OCL Constraints within UML2
Current Time: Sat Jul 26 18:54:11 EDT 2025
Powered by FUDForum. Page generated in 0.04526 seconds
