Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Compare] is it possible for the diff to hold the old values?
[Compare] is it possible for the diff to hold the old values? [message #123844] Thu, 29 May 2008 14:48 Go to next message
Hi all,
I guess I slightly mis-understood what compare would do for me. I'm
wondering if I'm just not using it correctly or there's some parameter
that I could set.
Right now I'm comparing two an old version of an object and a new
version of an object. I'd like to get the diff so that I can build an
object log.
After my compare I get this XML
<diff:ModelInputSnapshot xmi:version="2.0"
xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.1">
<diff left="original.xml" right="altered.xml">
<ownedElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:UpdateAttribute">
<attribute
href="http://model.lab.vsp.com#//Lab/labHeadquarterId"/>
<leftElement href="original.xml#/"/>
<rightElement href="altered.xml#/"/>
</subDiffElements>
<attribute href="http://model.lab.vsp.com#//Lab/labType"/>
</subDiffElements>
<attribute
href="http://model.lab.vsp.com#//Affiliation/affiliationType"/>
<leftElement href="original.xml#//@affiliationList.0"/>
<rightElement href="altered.xml#//@affiliationList.0"/>
</subDiffElements>
<leftParent href="original.xml#//@affiliationList.0"/>
</subDiffElements>
<subDiffElements xsi:type="diff:AddModelElement">
<leftParent href="original.xml#/"/>
<rightElement href="altered.xml#//@contactList.2"/>
</subDiffElements>
</subDiffElements>
</ownedElements>
</diff>
</diff:ModelInputSnapshot>
Let's focus on the updated attribute:
<attribute
</subDiffElements>
I had thought that the diff would display the old VALUE of the
attribute, not just the resource that it's located in. The old resource
will be getting deleted momentarily and replaced with the new one so I
wont have it to refer back to.
This is still somewhat helpful because I can see what was changed, but I
don't have any idea what it used to be. I'd love to see something more
like this:
<attribute
<leftElement href="original.xml#/" value="AAA"/>
<rightElement href="altered.xml#/" value="BBB"/>
</subDiffElements>
Certainly I can see how this request is tricky. In cases where a whole
sub-object was deleted what would be stored? I'm not sure.
Is this something that is even remotely possible, or is this kind of a
diff outside the current scope of the project?
Thanks!
Jason Henriksen
Re: [Compare] is it possible for the diff to hold the old values? [message #124014 is a reply to message #123844] Fri, 30 May 2008 03:28 Go to previous messageGo to next message
Hi jason,
The XML file EMF compare is providing you is in fact an EMF model, and as
such you can load it using the EMF standards code. That said, the diff
model is referencing both the elements of your version 1 and version2
models, which mean, if I take your example, that once loaded using EMF you
can get to your "UpdateAttribute" instance, and then
UpdateAttribute myUpdateDiff =.... // you can browse the diff model and
find back this element using the EMF eAllContents() for instance.
EStructuralFeature updatedFeature = myUpdateDiff.getAttribute();
Object oldValue= myUpdateDiff.getLeftElement().eGet(updatedFeature);
Object newValue= myUpdateDiff.getRightElement().eGet(updatedFeature);
I strongly advise you to use the model loaded thanks to EMF instead of
working on the XML level as the references resolving can be quite tricky is
you do it "by hand".
You'll find an example of a customized diff export in the modeling CVS
(dev.eclipse.org cvsroot=/cvsroot/modeling) called
org.eclipse.emf.compare.example.export.library and the corresponding
documentation in the Eclipse help "Adding new actions to the export menu".
For the next (Ganymede +1) release we'll work on a "self contained diff" you
could apply on other models - which makes it a kind of "patch"
or "changeset", but then it's more about re-applying/undoing changes than
about leveraging the diff.
Cédric
jason henriksen wrote:
> Hi all,
> that I could set.
> object log.
> xmlns:xmi="http://www.omg.org/XMI"
> <attribute
> </subDiffElements>
> </subDiffElements>
> <attribute
> </subDiffElements>
> </subDiffElements>
> </subDiffElements>
> </subDiffElements>
> </ownedElements>
> </diff>
> <attribute
> </subDiffElements>
> like this:
> <attribute
> </subDiffElements>
> Thanks!
> Jason Henriksen
Re: [Compare] is it possible for the diff to hold the old values? [message #124066 is a reply to message #124014] Fri, 30 May 2008 06:55 Go to previous messageGo to next message
--------------050101070600040804040806
Cédric,
I guess it would be possible to transform a diff model instance into a
ChangeDescription instance... I.e., it would be possible to create a
ChangeDescription that describes how to turn the left instances into the
right instance as well as one to turn the right instance into the left
instance. I'm not sure what it would be used for, but it struck me as
potentially interesting since a change description can be applied to
actually make the changes...
Cédric Brun wrote:
> Hi jason,
> Cheers,
> Cédric
>> Hi all,
>> that I could set.
>> object log.
>> <attribute
>> </subDiffElements>
>> </subDiffElements>
>> <attribute
>> </subDiffElements>
>> </subDiffElements>
>> </subDiffElements>
>> </subDiffElements>
>> </ownedElements>
>> </diff>
>> <attribute
>> </subDiffElements>
>> like this:
>> <attribute
>> </subDiffElements>
>> Thanks!
>> Jason Henriksen
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Cédric,<br>
<br>
the right instance as well as one to turn the right instance into the
left instance.  I'm not sure what it would be used for, but it struck
me as potentially interesting since a change description can be applied
to actually make the changes...<br>
<br>
<br>
Cédric Brun wrote:
<blockquote cite="mid:g1o9ou$eo1$1@build.eclipse.org" type="cite">
<pre wrap="">Hi jason,
Cédric
</pre>
<blockquote type="cite">
<pre wrap="">Hi all,
that I could set.
object log.
&lt;diff:ModelInputSnapshot xmi:version="2.0"
xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xmlns:diff=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/compare/diff/1.1">"http://www.eclipse.org/emf/compare/diff/1.1"</a>&gt;
&lt;diff left="original.xml" right="altered.xml"&gt;
&lt;ownedElements xsi:type="diff:DiffGroup"&gt;
&lt;subDiffElements xsi:type="diff:DiffGroup"&gt;
&lt;subDiffElements xsi:type="diff:UpdateAttribute"&gt;
&lt;attribute
href=<a class="moz-txt-link-rfc2396E" href="http://model.lab.vsp.com#//Lab/labHeadquarterId">"http://model.lab.vsp.com#//Lab/labHeadquarterId"</a>/&gt;
&lt;leftElement href="original.xml#/"/&gt;
&lt;rightElement href="altered.xml#/"/&gt;
&lt;/subDiffElements&gt;
&lt;attribute href=<a class="moz-txt-link-rfc2396E" href="http://model.lab.vsp.com#//Lab/labType">"http://model.lab.vsp.com#//Lab/labType"</a>/&gt;
&lt;attribute
href=<a class="moz-txt-link-rfc2396E" href="http://model.lab.vsp.com#//Affiliation/affiliationType">"http://model.lab.vsp.com#//Affiliation/affiliationType"</a>/&gt;
&lt;leftElement href=<a class="moz-txt-link-rfc2396E" href="mailto:original.xml#//@affiliationList.0">"original.xml#//@affiliationList.0 "</a>/&gt;
&lt;rightElement href=<a class="moz-txt-link-rfc2396E" href="mailto:altered.xml#//@affiliationList.0">"altered.xml#//@affiliationList.0 "</a>/&gt;
&lt;leftParent href=<a class="moz-txt-link-rfc2396E" href="mailto:original.xml#//@affiliationList.0">"original.xml#//@affiliationList.0 "</a>/&gt;
&lt;subDiffElements xsi:type="diff:AddModelElement"&gt;
&lt;leftParent href="original.xml#/"/&gt;
&lt;rightElement href=<a class="moz-txt-link-rfc2396E" href="mailto:altered.xml#//@contactList.2">"altered.xml#//@contactList.2 "</a>/&gt;
&lt;/ownedElements&gt;
&lt;/diff&gt;
&lt;/diff:ModelInputSnapshot&gt;
&lt;attribute
like this:
&lt;attribute
&lt;leftElement href="original.xml#/" value="AAA"/&gt;
&lt;rightElement href="altered.xml#/" value="BBB"/&gt;
Thanks!
Jason Henriksen
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050101070600040804040806--
Re: [Compare] is it possible for the diff to hold the old values? [message #124787 is a reply to message #124014] Mon, 02 June 2008 07:37 Go to previous messageGo to next message
Originally posted by: moritz.eysholdt.de
Hi Cédric,
that sounds useful for me, too. Is there already a bug for it where I
can add myself to the CC-list?
regards,
Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #124813 is a reply to message #124066] Mon, 02 June 2008 08:07 Go to previous messageGo to next message
Hi Ed, hi Cédric,
I've just run into a situation where I needed what you described. I'm
about to implement some refactorings for Ecore and my current approach
looks like this:
I'm creating a ChangeDescription model by hand (instead of recording it)
within the RefactoringProcessor. To execute the refactoring I only need
to apply the ChangeDescription.
To have a EMF Compare-based perview within the refactoring wizard, I
generate the needed MatchModel like this:
public static MatchModel createMatchModel(EObject left,
ChangeDescription change) {
change.applyAndReverse();
EObject right = EcoreUtil.copy(left);
URI leftUri = left.eResource().getURI();
URI rightUri = URI.createURI(leftUri + "-tmp."
+ leftUri.fileExtension());
ModelUtils.attachResource(rightUri, right);
try {
return MatchService.doContentMatch(left, right, null);
} catch (InterruptedException e) {
e.printStackTrace();
return null;
After applying the change it copies the model and undoes the change
again. This works for a prototype, but it has some disatvantages:
- The actual model is beeing changed just to generate the preview. It
shouldn't be necessary to touch the model for that.
- I haven't looked into the complexity of the match-model yet, but I've
got the feeling that it might be more efficient to derive it derectly
from the ChangeDescription instead of doing all the comparison again.
- If I create a change by hand, I 'know' what is a 'move' and I don't
need an algorithm to make guesses about it...
suggestions?
regards,
Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #124825 is a reply to message #124813] Mon, 02 June 2008 06:31 Go to previous messageGo to next message
Moritz,
Comments below.
Moritz Eysholdt wrote:
> Hi Ed, hi Cédric,
>> a ChangeDescription instance... I.e., it would be possible to create
>> a ChangeDescription that describes how to turn the left instances
>> into the right instance as well as one to turn the right instance
>> into the left instance. I'm not sure what it would be used for, but
>> it struck me as potentially interesting since a change description
>> can be applied to actually make the changes...
> looks like this:
> it) within the RefactoringProcessor. To execute the refactoring I only
> need to apply the ChangeDescription.
> try {
> return null;
What if you did an EcoreUtil.copyAll on the change description and the
final version and used applyAndReverse on that to get the original?
> I've got the feeling that it might be more efficient to derive it
> derectly from the ChangeDescription instead of doing all the
> comparison again.
I can imagine that's true. So you'd really like something that did
ChangeDescription -> MatchModel. But of course the ChangeDescription
model relies on there being only one instance model's changes being
described while the MatchModel relies on there being two different
instances. Certainly it's easy to use a Copier to end up with two
corresponding identical instances and from there I imagine it ought to
be possible to directly convert between a ChangeDescription and a
MatchModel...
One of the hard problems in comparison is establishing the mapping
between the two instances so given that the underlying Copier uses by
EcoreUtil.copy/copyAll knows that correspondence exactly, at least that
information ought to be reused.
> suggestions?
It sounds like there are some interesting utilities that could be
explored...
> regards,
> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #124837 is a reply to message #124787] Mon, 02 June 2008 06:34 Go to previous messageGo to next message
Cédric,
I guess that would make it work pretty much exactly like a change
description. Perhaps two way mapping between ChangeDescription <->
MatchModel would be quite an interesting problem to solve. With the
release over soon, maybe I'll have some time to help explore that...
> Hi Cédric,
>> diff" you
>> than
> regards,
> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #124913 is a reply to message #124837] Mon, 02 June 2008 08:44 Go to previous messageGo to next message
Hi Ed
You're right when you says the changemodel could be considered for these
changesets, and we would like to provide conversion utility for
changemodel<->diffmodel or changemodel<->matchmodel (once models are copied
and the copier is used to produce the matchmodel).
Moreover the "self contained" changeset model, we want to be able to apply
it on a model who have changed over time, a bit like the "fuzzy" search
mode of a textual patch. Then we'll probably ends up with some kind of
container keeping data to find the new root to apply on + the given
changeset.
That's indeed interesting areas to explore :)
I'll trigger a bug to track all the evolution about this subject.
Cédric
Ed Merks wrote:
> Cédric,
>> Hi Cédric,
>>> diff" you
>>> than
>> regards,
>> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #124948 is a reply to message #124825] Mon, 02 June 2008 13:13 Go to previous message
Hi Ed,
thanks for your quick answer.
thanks for the hint, now
public static EObject copyAndApply(EObject obj, ChangeDescription change) {
EcoreUtil.Copier cop = new Copier();
EObject r = cop.copy(obj);
ChangeDescription c = (ChangeDescription) cop.copy(change);
cop.copyReferences();
c.apply();
return r;
public static MatchModel createMatchModel2(EObject left,
EObject right = copyAndApply(left, change);
try {
return null;
works for me.
regards,
Moritz
>> comparison again.
> MatchModel...
>> suggestions?
> explored...
>> regards,
>> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #619093 is a reply to message #123844] Fri, 30 May 2008 03:28 Go to previous message
Hi jason,
Cédric
> Hi all,
> that I could set.
> object log.
> <attribute
> </subDiffElements>
> </subDiffElements>
> <attribute
> </subDiffElements>
> </subDiffElements>
> </subDiffElements>
> </subDiffElements>
> </ownedElements>
> </diff>
> <attribute
> </subDiffElements>
> like this:
> <attribute
> </subDiffElements>
> Thanks!
> Jason Henriksen
Re: [Compare] is it possible for the diff to hold the old values? [message #619097 is a reply to message #124014] Fri, 30 May 2008 06:55 Go to previous message
Cédric,
Cédric Brun wrote:
> Hi jason,
> Cheers,
> Cédric
>> Hi all,
>> that I could set.
>> object log.
>> <attribute
>> </subDiffElements>
>> </subDiffElements>
>> <attribute
>> </subDiffElements>
>> </subDiffElements>
>> </subDiffElements>
>> </subDiffElements>
>> </ownedElements>
>> </diff>
>> <attribute
>> </subDiffElements>
>> like this:
>> <attribute
>> </subDiffElements>
>> Thanks!
>> Jason Henriksen
<html>
<head>
</head>
Cédric,<br>
<br>
<br>
<br>
Cédric
</pre>
that I could set.
object log.
&lt;attribute
&lt;attribute
&lt;/diff&gt;
&lt;attribute
like this:
&lt;attribute
Thanks!
Jason Henriksen
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: [Compare] is it possible for the diff to hold the old values? [message #619135 is a reply to message #124014] Mon, 02 June 2008 07:37 Go to previous message
Hi Cédric,
regards,
Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #619137 is a reply to message #124066] Mon, 02 June 2008 08:07 Go to previous message
Hi Ed, hi Cédric,
looks like this:
try {
return null;
suggestions?
regards,
Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #619138 is a reply to message #124813] Mon, 02 June 2008 06:31 Go to previous message
Moritz,
Comments below.
> Hi Ed, hi Cédric,
> looks like this:
> try {
> return null;
> comparison again.
MatchModel...
> suggestions?
explored...
> regards,
> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #619139 is a reply to message #124787] Mon, 02 June 2008 06:34 Go to previous message
Cédric,
> Hi Cédric,
>> diff" you
>> than
> regards,
> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #619145 is a reply to message #124837] Mon, 02 June 2008 08:44 Go to previous message
Hi Ed
changeset.
Cédric
Ed Merks wrote:
> Cédric,
>> Hi Cédric,
>>> diff" you
>>> than
>> regards,
>> Moritz
Re: [Compare] is it possible for the diff to hold the old values? [message #619148 is a reply to message #124825] Mon, 02 June 2008 13:13 Go to previous message
Hi Ed,
c.apply();
return r;
try {
return null;
works for me.
regards,
Moritz
>> comparison again.
> MatchModel...
>> suggestions?
> explored...
>> regards,
>> Moritz
Previous Topic:[Teneo] Switch to DB2 and not getting identity columns
Next Topic:[Teneo] ClassCastException from hibernate trying to persist a new EMap entry with containement=true.
Current Time: Sun Jul 27 07:56:01 EDT 2025
Powered by FUDForum. Page generated in 0.09397 seconds
