Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Does EMF Compare really need to know about IFile and so on?
[EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123020] Tue, 27 May 2008 13:54 Go to next message
Hi All,
I'm using EMF inside of a server to process XML (SOAP messages) From an
eclipse point of view I'm running headless, but really I'm up inside
of a servlet container using XML that comes in from a network connection.
The minor annoyance (I hesitate to call it a problem) is that EMF
Compare is requiring me to add the jars to hold IFile and IResource and
all this. It seems like EMF compare shouldn't have those kinds of
dependencies. I'm not using it inside eclipse at all, so I don't really
want all the eclipse meta-file-system stuff sitting around inside my
servlet container.
What are your thoughts on that? Are those classes just used for
convenience or is this indicative of a deeper need that I don't
understand yet?
Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123032 is a reply to message #123020] Tue, 27 May 2008 15:15 Go to previous messageGo to next message
--------------040701050007030404000502
Guys,
I notice this is the case purely, because of
| *public static *EObject load(IFile file, ResourceSet resourceSet) *throws *IOException {
EObject result = *null*;
*final *Map<String, String> options = *new *HashMap<String, String>();
options.put(XMLResource.OPTION_ENCODING, System.getProperty(ENCODING_PROPERTY));
// First tries to load the IFile assuming it is in the workspace
Resource modelResource = createResource(URI.createPlatformResourceURI(
file.getFullPath().toOSString(), *true*), resourceSet);
*try *{
modelResource.load(options);
} *catch *(IOException e) {
// If it failed, load the file assuming it is in the plugins
resourceSet.getResources().remove(modelResource);
URI.createPlatformPluginURI(file.getFullPath().toOSString(), *true*), resourceSet);
*try *{
} *catch *(IOException ee) {
// If it fails anew, throws the first IOException
*throw *e;
// Returns the first root of the loaded model
*if *(modelResource.getContents().size() > 0)
result = modelResource.getContents().get(0);
*return *result;
I'm not sure I understand how the |createPlatformPluginURI|. A resource
might fail to load because some reference within it is wrong, and this
code will make it throw away that almost correct result and try
something that's almost bound to be completely meaningless. It seems a
bit unfortunate to introduce a hard IResource dependency for a utility
like this. Note also that the OPTION_ENCODING is a save option so has no
impact on loading. Maybe you should get rid of it. At worst, I suppose
you could make IResource an optional dependency; it might be necessary
to move the body of the method to a static nested class to avoid eager
class loading... You'd have to test that it works standalone without
loading that class when you call some other utility method...
jason henriksen wrote:
> Hi All,
> an eclipse point of view I'm running headless, but really I'm up
> inside of a servlet container using XML that comes in from a network
> connection.
> and all this. It seems like EMF compare shouldn't have those kinds of
> really want all the eclipse meta-file-system stuff sitting around
> inside my servlet container.
> understand yet?
> Jason
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Guys,<br>
<br>
I notice this is the case purely, because of <br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff">&nbsp;&nbsp;</font><font
color="#7f0055"><b>public&nbsp;static&nbsp;</b></font ><font color="#000000">EObject&nbsp;load</font><font
color="#000000">(</font><font color="#000000"> IFile&nbsp;file,&nbsp;ResourceSet&nbsp;resourceS et </font><font
color="#000000">)&nbsp;</font><font color="#7f0055"><b>throws&nbsp;</b></font><font
color="#000000">IOException&nbsp;</font><font color="#000000">{</font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#000000">EObject&nbsp;result&nbsp;=&nbsp; </font><font
color="#7f0055"><b>null</b></font><font color="#000000">;</font><br>
<font color="#ffffff"></font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#7f0055"><b>final&nbsp;</b></font><font
color="#000000"> Map&lt;String,&nbsp;String&gt;&nbsp;options& amp;nbsp;=&nbsp; </font><font
color="#7f0055"><b>new&nbsp;</b></font><font color="#000000">HashMap&lt;String,&nbsp;String&gt; </font><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#000000">options.put</font><font
color="#000000">(</font><font color="#000000">XMLResource.OPTION_ENCODING,&nbsp;System.getProperty </font><font
color="#000000">(</font><font color="#000000">ENCODING_PROPERTY</font><font
color="#000000">))</font><font color="#000000">;</font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#3f7f5f"> //&nbsp;First&nbsp;tries&nbsp;to&nbsp;load&a mp;nbsp;the&nbsp;IFile&nbsp;assuming&nbsp;it& ;nbsp;is&nbsp;in&nbsp;the&nbsp;workspace </font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#000000"> Resource&nbsp;modelResource&nbsp;=&nbsp;createRe source </font><font
color="#000000">(</font><font color="#000000">URI.createPlatformResourceURI</font><font
color="#000000">(</font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; </font><font color="#000000">file.getFullPath</font><font
color="#000000">()</font><font color="#000000">.toOSString</font><font
color="#000000">()</font><font color="#000000">,&nbsp;</font><font
color="#7f0055"><b>true</b></font><font color="#000000">)</font><font
color="#000000">,&nbsp;resourceSet</font><font color="#000000">)</font><font
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#7f0055"><b>try&nbsp;</b></font><font
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">modelResource.load</font><font
color="#000000">(</font><font color="#000000">options</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#000000">}&nbsp;</font><font
color="#7f0055"><b>catch&nbsp;</b></font><font color="#000000">(</font><font
color="#000000">IOException&nbsp;e</font><font color="#000000">)&nbsp;{</font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#3f7f5f"> //&nbsp;If&nbsp;it&nbsp;failed,&nbsp;load&am p;nbsp;the&nbsp;file&nbsp;assuming&nbsp;it&n bsp;is&nbsp;in&nbsp;the&nbsp;plugins </font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">resourceSet.getResources</font><font
color="#000000">()</font><font color="#000000">.remove</font><font
color="#000000">(</font><font color="#000000">modelResource</font><font
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">modelResource&nbsp;=&nbsp;createResource </font><font
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">URI.createPlatformPluginURI</font><font
color="#000000">(</font><font color="#000000">file.getFullPath</font><font
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#7f0055"><b>try&nbsp;</b></font><font
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; </font><font color="#000000">modelResource.load</font><font
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">}&nbsp;</font><font
color="#000000">IOException&nbsp;ee</font><font color="#000000">)&nbsp;{</font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; </font><font color="#3f7f5f"> //&nbsp;If&nbsp;it&nbsp;fails&nbsp;anew,& ;nbsp;throws&nbsp;the&nbsp;first&nbsp;IOExceptio n </font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; </font><font color="#7f0055"><b>throw&nbsp;</b></font><font
color="#000000">e;</font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">}</font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#000000">}</font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#3f7f5f"> //&nbsp;Returns&nbsp;the&nbsp;first&nbsp;roo t&nbsp;of&nbsp;the&nbsp;loaded&nbsp;model </font><br>
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#7f0055"><b>if&nbsp;</b></font><font
color="#000000">(</font><font color="#000000">modelResource.getContents</font><font
color="#000000">()</font><font color="#000000">.size</font><font
color="#000000">()&nbsp;</font><font color="#000000">&gt;&nbsp;</font><font
color="#990000">0</font><font color="#000000">)</font><br>
<font color="#ffffff"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </font><font color="#000000">result&nbsp;=&nbsp;modelResource.getContents </font><font
color="#000000">()</font><font color="#000000">.get</font><font
color="#000000">(</font><font color="#990000">0</font><font
<font color="#ffffff">&nbsp;&nbsp;&nbsp;&nbsp;</font ><font color="#7f0055"><b>return&nbsp;</b></font><font
color="#000000">result;</font><br>
<font color="#ffffff">&nbsp;&nbsp;</font><font color="#000000">}</font></code>
</td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<!-- ======================================================== --><br>
<br>
I'm not sure I understand how the <code><font color="#000000">createPlatformPluginURI</font></code>.&nbsp;
A resource might fail to load because some reference within it is
wrong, and this code will make it throw away that almost correct result
and try something that's almost bound to be completely meaningless.&nbsp; It
seems a bit unfortunate to introduce a hard IResource dependency for a
utility like this. Note also that the OPTION_ENCODING is a save option
so has no impact on loading.&nbsp; Maybe you should get rid of it.&nbsp; At
worst, I suppose you could make IResource an optional dependency; it
might be necessary to move the body of the method to a static nested
class to avoid eager class loading...&nbsp; You'd have to test that it works
standalone without loading that class when you call some other utility
method...<br>
<br>
<br>
<blockquote cite="mid:g1hht2$4l5$1@build.eclipse.org" type="cite">Hi
All,
<br>
<br>
I'm using EMF inside of a server to process XML (SOAP messages)&nbsp; From
an &nbsp;eclipse point of view I'm running headless, but really I'm up
connection.
<br>
<br>
all this.&nbsp; It seems like EMF compare shouldn't have those kinds of
dependencies.&nbsp; I'm not using it inside eclipse at all, so I don't
<br>
<br>
What are your thoughts on that?&nbsp; Are those classes just used for
understand yet?
<br>
<br>
&nbsp;Thanks,
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; Jason
<br>
</blockquote>
<br>
</body>
</html>
--------------040701050007030404000502--
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123256 is a reply to message #123032] Wed, 28 May 2008 05:48 Go to previous messageGo to next message
--------------030404060205060708010605
Ed, Jason,
We do have an example launching EMF Compare stand-alone, and this works
without any of the org.eclipse.core.* jars. The only required
dependencies to launch EMF Compare standalone are :
- org.eclipse.emf.common 2.3 or higher
- org.eclipse.emf.ecore 2.3 or higher
- org.eclipse.emf.ecore.xmi 2.3 or higher
- org.eclipse.emf.compare 0.8 or higher
- org.eclipse.emf.compare.diff 0.8 or higher
- org.eclipse.emf.compare.match 0.8 or higher
The utility method Ed is pointing to is something that can obviously not
be used in a standalone app, it shouldn't even be called when using EMF
Compare via the MatchService and DiffService Classes.
Of course, I might very well have broken something in the last builds...
Can you confirm your use case doesn't work with only the 6 jars above
and create a bugzilla if so?
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123269 is a reply to message #123256] Wed, 28 May 2008 05:52 Go to previous messageGo to next message
--------------000503020502060507000706
As a side note, Ed : thanks for pointing out that the OPTION_ENCODING is
a save option, I will get rid of those since I used it everywhere for
loading :D.
laurent Goubet a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123310 is a reply to message #123256] Wed, 28 May 2008 07:18 Go to previous messageGo to next message
Laurent,
Perhaps you should consider making the plugin dependency on core
resources optional. That way someone could use this in an RCP
application without the resources plugin; that's what we did in
org.eclipse.emf.ecore... It's good to test that you can call another
utility method in that class without causing the IFile class to be
loaded to be sure that only clients that use that one utility method
will actually need core.resources.
laurent Goubet wrote:
> Ed, Jason,
> works without any of the org.eclipse.core.* jars. The only required
> not be used in a standalone app, it shouldn't even be called when
> using EMF Compare via the MatchService and DiffService Classes.
> builds... Can you confirm your use case doesn't work with only the 6
> jars above and create a bugzilla if so?
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Guys,
>> String>();
>> *try *{
>> resourceSet);
>> *try *{
>> *throw *e;
>> *return *result;
>> result and try something that's almost bound to be completely
>> meaningless. It seems a bit unfortunate to introduce a hard
>> IResource dependency for a utility like this. Note also that the
>> OPTION_ENCODING is a save option so has no impact on loading. Maybe
>> you should get rid of it. At worst, I suppose you could make
>> IResource an optional dependency; it might be necessary to move the
>> body of the method to a static nested class to avoid eager class
>>> Hi All,
>>> From an eclipse point of view I'm running headless, but really I'm
>>> up inside of a servlet container using XML that comes in from a
>>> network connection.
>>> of dependencies. I'm not using it inside eclipse at all, so I don't
>>> understand yet?
>>> Thanks,
>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123324 is a reply to message #123310] Wed, 28 May 2008 07:31 Go to previous messageGo to next message
--------------070301050600090705080606
Ed,
I didn't know there was a way to set "optional" dependencies, just
commited this change on our plugins (Jason : we're currently building
for RC2, this change will appear in that build).
Yet I wonder : what exactly does setting a dependency "optional"
changes? As I mentionned earlier, we could already use EMF Compare stand
alone (no eclipse headless or whatnot, directly via java -jar on a
builded jar of a simple "main" class launching a comparison), and that
worked fine without having org.eclipse.core.* jars in the classpath.
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123336 is a reply to message #123324] Wed, 28 May 2008 08:01 Go to previous messageGo to next message
Laurent,
Comments below.
> Ed,
When you learn something new, it's a good day. :-P
> Yet I wonder : what exactly does setting a dependency "optional" changes?
If something is a normal dependency you are declaring that the plugin
will only work if the plugins on which it depends are actually present.
An optional dependency specifies that your plugin will make use of the
dependency if present, but will continue to function well even when the
dependency is not present. So for Ecore we've designed it such that it
can exploit IResources (for things like handling platform:/resource
URIs) but will also work fine if you don't make use of IResources.
> As I mentionned earlier, we could already use EMF Compare stand alone
> (no eclipse headless or whatnot, directly via java -jar on a builded
> jar of a simple "main" class launching a comparison), and that worked
Yes, I was just wondering if that test used any of the other methods in
the utility class. Sometimes Java's class loader is a bit eager and in
those cases, moving the code to a separate class (like our EclipseUtil
classes) helps to defer to loading...
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>>> Ed, Jason,
>>> Laurent Goubet
>>> Obeo
>>> Ed Merks a écrit :
>>>> Guys,
>>>> String>();
>>>> *try *{
>>>> *try *{
>>>> *throw *e;
>>>> *return *result;
>>>> Maybe you should get rid of it. At worst, I suppose you could make
>>>>> Hi All,
>>>>> I'm up inside of a servlet container using XML that comes in from
>>>>> IResource and all this. It seems like EMF compare shouldn't have
>>>>> those kinds of dependencies. I'm not using it inside eclipse at
>>>>> all, so I don't really want all the eclipse meta-file-system stuff
>>>>> sitting around inside my servlet container.
>>>>> understand yet?
>>>>> Thanks,
>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123349 is a reply to message #123336] Wed, 28 May 2008 08:13 Go to previous messageGo to next message
--------------090502070802040104090103
Ed,
Thanks for the clarification, I guess this "optional" resolution for
dependencies is only set to give this information to clients but isn't
actually used by either compiler or builder then.
As for your latter question, we use methods from this utility class
throughout the code of EMF Compare, and the example is no exception... I
might very well be lucky with the class loader (for once).
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123362 is a reply to message #123349] Wed, 28 May 2008 08:23 Go to previous messageGo to next message
Laurent,
Comments below.
> Ed,
Exactly. It's also useful for clients building a minimal runtime
configuration (in the Run configurations dialogs) since optional
dependencies won't be included.
> I might very well be lucky with the class loader (for once).
Class loaders do generally try to be very lazy.
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>> Comments below.
>>> Ed,
>>> building for RC2, this change will appear in that build).
>>> changes?
>> present. An optional dependency specifies that your plugin will make
>> use of the dependency if present, but will continue to function well
>> even when the dependency is not present. So for Ecore we've designed
>> it such that it can exploit IResources (for things like handling
>> platform:/resource URIs) but will also work fine if you don't make
>> use of IResources.
>>> that worked fine without having org.eclipse.core.* jars in the
>>> classpath.
>> in the utility class. Sometimes Java's class loader is a bit eager
>> and in those cases, moving the code to a separate class (like our
>> EclipseUtil classes) helps to defer to loading...
>>> Laurent Goubet
>>> Obeo
>>> Ed Merks a écrit :
>>>> Laurent,
>>>> another utility method in that class without causing the IFile
>>>> class to be loaded to be sure that only clients that use that one
>>>> utility method will actually need core.resources.
>>>>> Ed, Jason,
>>>>> required dependencies to launch EMF Compare standalone are :
>>>>> obviously not be used in a standalone app, it shouldn't even be
>>>>> called when using EMF Compare via the MatchService and DiffService
>>>>> Classes.
>>>>> 6 jars above and create a bugzilla if so?
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Ed Merks a écrit :
>>>>>> Guys,
>>>>>> String>();
>>>>>> *try *{
>>>>>> *try *{
>>>>>> *throw *e;
>>>>>> *return *result;
>>>>>> make IResource an optional dependency; it might be necessary to
>>>>>> eager class loading... You'd have to test that it works
>>>>>> utility method...
>>>>>>> Hi All,
>>>>>>> EMF Compare is requiring me to add the jars to hold IFile and
>>>>>>> have those kinds of dependencies. I'm not using it inside
>>>>>>> eclipse at all, so I don't really want all the eclipse
>>>>>>> meta-file-system stuff sitting around inside my servlet container.
>>>>>>> understand yet?
>>>>>>> Thanks,
>>>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123531 is a reply to message #123362] Thu, 29 May 2008 04:02 Go to previous messageGo to next message
--------------030700020205080009060605
Jason,
A little update; I indeed found a problem with this
org.eclipse.core.runtime dependency when calling some of ModelUtils'
utility methods (seems I _was_ lucky with the class loader after all).
As Ed suggested, I will move the offending methods to another utility
class (probably EclipseModelUtils) in order to get rid of these direct
dependencies to org.eclipse.core.runtime.* as per bug 234544
https://bugs.eclipse.org/bugs/show_bug.cgi?id=234544 .
Thank you for your feedback.
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123741 is a reply to message #123531] Thu, 29 May 2008 12:57 Go to previous messageGo to next message
You guys are fantastic. Thanks!
Jason
> Jason,
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>> Comments below.
>>> Ed,
>>> isn't actually used by either compiler or builder then.
>>> exception... I might very well be lucky with the class loader (for
>>> once).
>>> Laurent Goubet
>>> Obeo
>>> Ed Merks a écrit :
>>>> Laurent,
>>>> Comments below.
>>>>> Ed,
>>>>> changes?
>>>> plugin will only work if the plugins on which it depends are
>>>> actually present. An optional dependency specifies that your plugin
>>>> will make use of the dependency if present, but will continue to
>>>> function well even when the dependency is not present. So for Ecore
>>>> we've designed it such that it can exploit IResources (for things
>>>> like handling platform:/resource URIs) but will also work fine if
>>>>> classpath.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Ed Merks a écrit :
>>>>>> Laurent,
>>>>>>> Ed, Jason,
>>>>>>> the 6 jars above and create a bugzilla if so?
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>> Ed Merks a écrit :
>>>>>>>> Guys,
>>>>>>>> String>();
>>>>>>>> workspace
>>>>>>>> *try *{
>>>>>>>> *try *{
>>>>>>>> *throw *e;
>>>>>>>> *return *result;
>>>>>>>> utility method...
>>>>>>>>> Hi All,
>>>>>>>>> messages) From an eclipse point of view I'm running headless,
>>>>>>>>> but really I'm up inside of a servlet container using XML that
>>>>>>>>> for convenience or is this indicative of a deeper need that I
>>>>>>>>> don't understand yet?
>>>>>>>>> Thanks,
>>>>>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #123802 is a reply to message #123741] Thu, 29 May 2008 13:30 Go to previous message
Jason,
Yes, we've got quite the excellent group here! :-)
> Jason
>> Jason,
>> direct dependencies to org.eclipse.core.runtime.* as per bug 234544
>> Laurent Goubet
>> Obeo
>> Ed Merks a écrit :
>>> Laurent,
>>> Comments below.
>>>> Ed,
>>>> for dependencies is only set to give this information to clients
>>>> but isn't actually used by either compiler or builder then.
>>>> once).
>>>> Laurent Goubet
>>>> Obeo
>>>> Ed Merks a écrit :
>>>>> Laurent,
>>>>> Comments below.
>>>>>> Ed,
>>>>>> just commited this change on our plugins (Jason : we're currently
>>>>>> changes?
>>>>> plugin will make use of the dependency if present, but will
>>>>> continue to function well even when the dependency is not
>>>>> present. So for Ecore we've designed it such that it can exploit
>>>>> IResources (for things like handling platform:/resource URIs) but
>>>>>> a builded jar of a simple "main" class launching a comparison),
>>>>>> and that worked fine without having org.eclipse.core.* jars in
>>>>>> the classpath.
>>>>> methods in the utility class. Sometimes Java's class loader is a
>>>>> bit eager and in those cases, moving the code to a separate class
>>>>> (like our EclipseUtil classes) helps to defer to loading...
>>>>>> Laurent Goubet
>>>>>> Obeo
>>>>>> Ed Merks a écrit :
>>>>>>> Laurent,
>>>>>>> one utility method will actually need core.resources.
>>>>>>>> Ed, Jason,
>>>>>>>> this works without any of the org.eclipse.core.* jars. The only
>>>>>>>> Laurent Goubet
>>>>>>>> Obeo
>>>>>>>> Ed Merks a écrit :
>>>>>>>>> Guys,
>>>>>>>>> workspace
>>>>>>>>> *try *{
>>>>>>>>> plugins
>>>>>>>>> *try *{
>>>>>>>>> *throw *e;
>>>>>>>>> *return *result;
>>>>>>>>> is wrong, and this code will make it throw away that almost
>>>>>>>>> correct result and try something that's almost bound to be
>>>>>>>>> completely meaningless. It seems a bit unfortunate to
>>>>>>>>> introduce a hard IResource dependency for a utility like this.
>>>>>>>>> nested class to avoid eager class loading... You'd have to
>>>>>>>>> test that it works standalone without loading that class when
>>>>>>>>>> Hi All,
>>>>>>>>>> headless, but really I'm up inside of a servlet container
>>>>>>>>>> container.
>>>>>>>>>> Thanks,
>>>>>>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #618989 is a reply to message #123020] Tue, 27 May 2008 15:15 Go to previous message
Guys,
*try *{
*try *{
*throw *e;
*return *result;
> Hi All,
> connection.
> understand yet?
> Jason
<html>
<head>
</head>
Guys,<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
</td>
</tbody>
</table>
</div>
<br>
method...<br>
<br>
<br>
All,
<br>
<br>
connection.
<br>
<br>
<br>
<br>
understand yet?
<br>
<br>
&nbsp;Thanks,
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619006 is a reply to message #123032] Wed, 28 May 2008 05:48 Go to previous message
Ed, Jason,
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619009 is a reply to message #123256] Wed, 28 May 2008 05:52 Go to previous message
loading :D.
laurent Goubet a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619015 is a reply to message #123256] Wed, 28 May 2008 07:18 Go to previous message
Laurent,
> Ed, Jason,
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Guys,
>> String>();
>> *try *{
>> resourceSet);
>> *try *{
>> *throw *e;
>> *return *result;
>>> Hi All,
>>> network connection.
>>> understand yet?
>>> Thanks,
>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619017 is a reply to message #123310] Wed, 28 May 2008 07:31 Go to previous message
Ed,
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619020 is a reply to message #123324] Wed, 28 May 2008 08:01 Go to previous message
Laurent,
Comments below.
> Ed,
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>>> Ed, Jason,
>>> Laurent Goubet
>>> Obeo
>>> Ed Merks a écrit :
>>>> Guys,
>>>> String>();
>>>> *try *{
>>>> *try *{
>>>> *throw *e;
>>>> *return *result;
>>>>> Hi All,
>>>>> understand yet?
>>>>> Thanks,
>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619024 is a reply to message #123336] Wed, 28 May 2008 08:13 Go to previous message
Ed,
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619028 is a reply to message #123349] Wed, 28 May 2008 08:23 Go to previous message
Laurent,
Comments below.
> Ed,
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>> Comments below.
>>> Ed,
>>> changes?
>> use of IResources.
>>> classpath.
>>> Laurent Goubet
>>> Obeo
>>> Ed Merks a écrit :
>>>> Laurent,
>>>>> Ed, Jason,
>>>>> Classes.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Ed Merks a écrit :
>>>>>> Guys,
>>>>>> String>();
>>>>>> *try *{
>>>>>> *try *{
>>>>>> *throw *e;
>>>>>> *return *result;
>>>>>> utility method...
>>>>>>> Hi All,
>>>>>>> understand yet?
>>>>>>> Thanks,
>>>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619058 is a reply to message #123362] Thu, 29 May 2008 04:02 Go to previous message
Jason,
Laurent Goubet
Obeo
Ed Merks a
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619073 is a reply to message #123531] Thu, 29 May 2008 12:57 Go to previous message
Jason
> Jason,
> Laurent Goubet
> Obeo
> Ed Merks a écrit :
>> Laurent,
>> Comments below.
>>> Ed,
>>> once).
>>> Laurent Goubet
>>> Obeo
>>> Ed Merks a écrit :
>>>> Laurent,
>>>> Comments below.
>>>>> Ed,
>>>>> changes?
>>>>> classpath.
>>>>> Laurent Goubet
>>>>> Obeo
>>>>> Ed Merks a écrit :
>>>>>> Laurent,
>>>>>>> Ed, Jason,
>>>>>>> Laurent Goubet
>>>>>>> Obeo
>>>>>>> Ed Merks a écrit :
>>>>>>>> Guys,
>>>>>>>> String>();
>>>>>>>> workspace
>>>>>>>> *try *{
>>>>>>>> *try *{
>>>>>>>> *throw *e;
>>>>>>>> *return *result;
>>>>>>>> utility method...
>>>>>>>>> Hi All,
>>>>>>>>> Thanks,
>>>>>>>>> Jason
Re: [EMF Compare] Does EMF Compare really need to know about IFile and so on? [message #619077 is a reply to message #123741] Thu, 29 May 2008 13:30 Go to previous message
Jason,
> Jason
>> Jason,
>> Laurent Goubet
>> Obeo
>> Ed Merks a écrit :
>>> Laurent,
>>> Comments below.
>>>> Ed,
>>>> once).
>>>> Laurent Goubet
>>>> Obeo
>>>> Ed Merks a écrit :
>>>>> Laurent,
>>>>> Comments below.
>>>>>> Ed,
>>>>>> changes?
>>>>>> the classpath.
>>>>>> Laurent Goubet
>>>>>> Obeo
>>>>>> Ed Merks a écrit :
>>>>>>> Laurent,
>>>>>>>> Ed, Jason,
>>>>>>>> Laurent Goubet
>>>>>>>> Obeo
>>>>>>>> Ed Merks a écrit :
>>>>>>>>> Guys,
>>>>>>>>> workspace
>>>>>>>>> *try *{
>>>>>>>>> plugins
>>>>>>>>> *try *{
>>>>>>>>> *throw *e;
>>>>>>>>> *return *result;
>>>>>>>>>> Hi All,
>>>>>>>>>> container.
>>>>>>>>>> Thanks,
>>>>>>>>>> Jason
Previous Topic:[EMF Compare] Innacuracies while comparing lists of very similar elements
Next Topic:[Compare] is it possible for the diff to hold the old values?
Current Time: Wed Oct 08 15:58:55 EDT 2025
Powered by FUDForum. Page generated in 0.06240 seconds
