Cheat Sheet [message #474092] |
Tue, 24 June 2008 04:27  |
Originally posted by: bucher_jenny.web.de
I would like to have cheat sheets in my application.
What I have done so far:
I add a cheatsheet,
and following plugins:
org.apache.lucene
org.apache.lucene.analysis
org.eclipse.help.base
org.eclipse.help.ui
org.eclipse.ui.cheatsheets
org.eclipse.ui.forms
But it also adds menu actions like Search and Run. But I would like to
have only my cheat sheet.
Do sb know why this menu actions are added and how I can get rid of them
and the eclipse standart cheat sheets?
Re: Cheat Sheet [message #474123 is a reply to message #474122] |
Thu, 03 July 2008 04:22  |
Hey, thats cool, thank you.
But I cant get the org.eclipse.jdt out. Its in the run configuration and I
need it there. Is there another way to get this cheatsheet out?
Sry for this noob questions, but I cant find a solution...
Cheers
Chris Goldthorpe wrote:
> I can give you a short answer and a longer answer.
> The short answer is org.eclipse.jdt is contributing these cheat sheets.
> The longer answer is that to find out where any cheat sheet comes from
> open the Plug-in Registry view and look under org.eclipse.ui.cheatsheets
> at the extension point org.eclipse.ui.cheatsheets.cheatSheetContent. You
> will see a list of cheat sheets and can see which plugin contributed them.
> Jenni wrote:
>> You're right.
>> But I still have a little problem ;)
>> If I open the Cheat Sheet Selection there is a category called Java
>> Development. Do somebody know how I can get this out?
>> Cheers
>>> I think the standard cheat sheets as well as the menu items are
>>> probably coming from org.eclipse.ui.platform. If you see the cheat
>>> sheet "Check out a CVS project" then that is coming from the platform,
>>> and the solution would be to not include that project in your
>>> application.
>>> Jenni wrote:
>>>> Hi,
>>>> I add a cheatsheet,
>>>> org.apache.lucene
>>>> org.eclipse.help.ui
>>>> to have only my cheat sheet.
>>>> them and the eclipse standart cheat sheets?
Re: Cheat Sheet [message #617656 is a reply to message #474092] |
Wed, 25 June 2008 13:55  |
I think the standard cheat sheets as well as the menu items are probably
coming from org.eclipse.ui.platform. If you see the cheat sheet "Check
out a CVS project" then that is coming from the platform, and the
solution would be to not include that project in your application.
Jenni wrote:
> I add a cheatsheet,
> org.apache.lucene
> org.eclipse.help.ui
Re: Cheat Sheet [message #618941 is a reply to message #474108] |
Wed, 02 July 2008 09:56  |
You're right.
Cheers
> Jenni wrote:
>> Hi,
>> I add a cheatsheet,
>> org.apache.lucene
>> org.eclipse.help.ui
Re: Cheat Sheet [message #618951 is a reply to message #474119] |
Wed, 02 July 2008 17:23  |
Jenni wrote:
> You're right.
> Cheers
>> application.
>> Jenni wrote:
>>> Hi,
>>> I add a cheatsheet,
>>> org.apache.lucene
>>> org.eclipse.help.ui
Re: Cheat Sheet [message #618953 is a reply to message #474122] |
Cheers
> Jenni wrote:
>> You're right.
>> Cheers
>>> application.
>>> Jenni wrote:
>>>> Hi,
>>>> I add a cheatsheet,
>>>> org.apache.lucene
>>>> org.eclipse.help.ui
FUDForum. Page generated in 0.25463 seconds
