ECF and Google for domains [message #618827] |
Wed, 11 July 2007 20:13  |
Originally posted by: atoulme.intalio.com
Hi guys,
first, congratulations, this is a nice piece of work.
I face a problem when trying to set up my gmail for domain account.
I am able to set up my account in kopete by setting the server as
talk.google.com, while my username remains atoulme@intalio.com.
However I am unable to do that in ECF, unless there is a secret
handshake I didn't catch.
Please tell me if I missed something, I'll be happy to file a bug
regarding this issue if necessary.
Antoine
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: ECF and Google for domains [message #618833 is a reply to message #618832] |
Fri, 13 July 2007 16:56   |
Alex Blewitt wrote:
> The xxx@gmail@googletalk" target="_blank">>@googletalk doesn't work. Oh well ...
Yes, I tried that too.
> I attached a patch to <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=196298">bug 196298</a> that should allow different domains. Does the google domain thing use the same talk.google.com server, just with a different ID? If so, once this patch is applied you'll be able to run eclipse -Decf.xmpp.google.override=yourdomain.com, and then it will treat anything@yourdomain.com as being a reference for talk.google.com instead. I don't have a google domain to test it with, but I did simulate one with my own domain and it seemed to fall back to the talk.google.com domain.
> You'll even be able to test it out ... I've just written a post on <a href="http://www.eclipsezone.com/eclipse/forums/t98711.html">checking out plug-ins from the plug-ins view</a> that makes it trivial to check out a plug-in; in this case, the org.eclipse.ecf.provider.xmpp one. You can test run that for me, as well as the fix ;-)
I will certainly do that. However, I haven't been able to connect to
Google Talk through Kopete yersterday (last time I tried was about one
year ago, and it worked fine), so I am wondering if there is an outage
of this service if you are not a paying Google customer.
I will let you know the results of my search.
Thanks a lot for looking into it!
> Alex.
Re: ECF and Google for domains [message #618878 is a reply to message #618855] |
Tue, 24 July 2007 17:48  |
Hi Antoine,
I assume from your note that the latest is working with your gt
accounts/google domains? Could you let me know so that I can properly
address the disposition of this bug
Scott
Antoine Toulme wrote:
> To follow up on this:
> apparently the full fix will be available in ECF 1.0.2.
> I was happy to help, and look forward to use Google Talk directly with
> my Eclipse install.
> Cheers,
> Antoine
> Scott Lewis wrote:
>> Hi Antoine,
>> This fix (in addition to others) is available in ECF 1.0.1.
>> See 'ECF 1.0.1 Now Available' posting.
>> Scott
FUDForum. Page generated in 0.53879 seconds
