Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » comparison of *.xmi via EMF Compare not possible
comparison of *.xmi via EMF Compare not possible [message #122616] Sat, 17 May 2008 05:03 Go to next message
Originally posted by: mam05eux.studserv.uni-leipzig.de
I need to compare some Models with the ending .xmi using EMF Compare.
The point is that I theoretically know how to enable the comparison via
EMF Compar to these extensions (Window/Preferences/General/Content
Types/Model Files...)
Now my problem:
There is no entry Model Files! instead of this there is an entry called
EMF Compare. OK, I opened it and saw that there already was an extension
called *.xmi!!! But it doesn?t work.
Ok for testing the content-type-bindings I added the extension
*.genmodel and was able to compare the models via EMF Compare!
So can anyone help me going ahead?
Re: comparison of *.xmi via EMF Compare not possible [message #122825 is a reply to message #122616] Thu, 22 May 2008 05:17 Go to previous message
--------------080000010900080101020602
Stanley,
Sorry for the late answer. This problem means that another of your
plugins already provides a binding to *.xmi (most probably WTP),
preventing ours to be used in finding the comparator as per bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=220457 .
This is something we can't help as of now ... If you happen to know
which content type is defining the binding to *.xmi we should be able to
work around it as we did for org.eclipse.emf.ecore (causing bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=217986 ).
Laurent Goubet
Obeo
Stanley Hillner a
Re: comparison of *.xmi via EMF Compare not possible [message #618119 is a reply to message #122616] Thu, 22 May 2008 05:17 Go to previous message
Stanley,
Laurent Goubet
Obeo
Stanley Hillner a
Previous Topic:[CDO 0.8.0] EMap
Next Topic:Teneo Build Announcement Thread
Current Time: Fri Jul 18 19:59:57 EDT 2025
Powered by FUDForum. Page generated in 0.05096 seconds
