Home » Archived » GMT (Generative Modeling Technologies) » OAW - Type Casting with XTend
OAW - Type Casting with XTend [message #383890] Mon, 16 June 2008 08:25 Go to next message
Originally posted by: any.swc.rwth-aachen.de
I have specified the following in my Extension:
cached int getConnectorCount(uml::ConnectorEnd e) :
uml::MultiplicityElement.isInstance(e.role) ?
e.getPartWithPortMultiplicity() * e.upper() *
((uml::MultiplicityElement)e.role).upper()
: e.getPartWithPortMultiplicity() * e.upper()
The cast of e.role into MultiplicityElemenet is acknowledged by the OAW
environement with the error "cannot cast from uml::ConnectableElement into
uml::MultiplicityElement". The dynamic type of e.role may however by a
MultiplicityElement. What am I doing wrong?
Re: OAW - Type Casting with XTend [message #383899 is a reply to message #383890] Tue, 24 June 2008 07:13 Go to previous messageGo to next message
Hi Alexander,
you get this error because those types are not in a type hierarchy and
cannot be casted therefore.
The type hierarchy is as follows:
Element <- NamedElement <- TypedElement <- ConnectableElement
Element <- MultiplicityElement
You may consult the UML2 superstructure. Seems that the
ConnactableElement's role is not an MultiplicityElement.
~Karsten
> into uml::MultiplicityElement". The dynamic type of e.role may however
> by a MultiplicityElement. What am I doing wrong?
Re: OAW - Type Casting with XTend [message #383900 is a reply to message #383899] Tue, 24 June 2008 08:52 Go to previous messageGo to next message
Yes of course they are not in the same hierarchy, that's why I indeed need
the cast!
Just assume e.role is a Property, which is a ConnectableElement as well as
Best Regards
Alexander Nyßen
"Karsten Thoms" <karsten.thoms@itemis.de> schrieb im Newsbeitrag
news:g3qkt1$njg$1@build.eclipse.org...
> Hi Alexander,
> ~Karsten
>> into uml::MultiplicityElement". The dynamic type of e.role may however by
Re: OAW - Type Casting with XTend [message #383902 is a reply to message #383900] Wed, 25 June 2008 09:31 Go to previous messageGo to next message
You could override your upper() function, assuming a default for non
MultiplicityElements, then upper() will also be recognized for
ConnectableElement and if it is at runtime a MultiplicityElement the
appropriate function will be called.
int upper (MultiplicityElement this) : upper;
int upper (Element this) : 1;
(e.role.upper()
> need the cast!
> as MultiplicityElement.
> Best Regards
> Alexander Nyßen
>> Hi Alexander,
>> ~Karsten
>>> OAW environement with the error "cannot cast from
>>> uml::ConnectableElement into uml::MultiplicityElement". The dynamic
>>> type of e.role may however by a MultiplicityElement. What am I doing
>>> wrong?
Re: OAW - Type Casting with XTend [message #384381 is a reply to message #383900] Tue, 29 July 2008 02:16 Go to previous message
> need the cast!
strange multiple inheritance ;-)
Then you should cast it down to (Property) or use the approach Karsten
mentioned.
Sven
Re: OAW - Type Casting with XTend [message #618088 is a reply to message #383890] Tue, 24 June 2008 07:13 Go to previous message
Hi Alexander,
~Karsten
Re: OAW - Type Casting with XTend [message #618090 is a reply to message #383899] Tue, 24 June 2008 08:52 Go to previous message
the cast!
Best Regards
Alexander Nyßen
> Hi Alexander,
> ~Karsten
Re: OAW - Type Casting with XTend [message #618093 is a reply to message #383900] Wed, 25 June 2008 09:31 Go to previous message
(e.role.upper()
> need the cast!
> Best Regards
> Alexander Nyßen
>> Hi Alexander,
>> ~Karsten
>>> wrong?
Re: OAW - Type Casting with XTend [message #618621 is a reply to message #383900] Tue, 29 July 2008 02:16 Go to previous message
> need the cast!
mentioned.
Sven
Previous Topic:OAW xpt and counters
Next Topic:[Epsilon] Problem with HUTN and sqlmodel
Current Time: Fri Jul 25 19:08:52 EDT 2025
Powered by FUDForum. Page generated in 0.05854 seconds
