Home » Language IDEs » AspectJ » Which version for Websphere WSAD
Which version for Websphere WSAD [message #61535] Wed, 01 February 2006 05:07 Go to next message
Originally posted by: naeger.gmx.de
our project uses Websphere Studio Application Developer (WSAD) V5.1.2 and
we would like to introduce AspectJ in our project.
As far as I understand, I have to use AJDT 1.1.4 as WSAD is based on
Eclipse 2.
Is this correct?
AJDT 1.1.4 includes an older version of AspectJ (which version by the
way?).
I am not sure if it is possible to use AJDT 1.1.4 with a newer version of
AspectJ. Is this possible?
If not, what are the major differences to the current version. Is it
advicable to use the old version?
If anyone elaborated on my options for using AspectJ with WSAD5.1.2 I
would be very grateful.
Regards, Chris
Re: Which version for Websphere WSAD [message #61590 is a reply to message #61535] Wed, 01 February 2006 07:17 Go to previous messageGo to next message
> and we would like to introduce AspectJ in our project.
> Eclipse 2.
> Is this correct?
Yes.
(well to be more precise, it's based on Eclipse 2.1)
> way?).
I believe it's AspectJ 1.1.1.
> of AspectJ. Is this possible?
No, not in the general case, as a newer version of AspectJ would come with
a newer version of the integration layer between the two, which would then
most likely to be incompatible with AJDT 1.1.4.
AJDT 1.1.4 and AspectJ 1.1.1 are nearly two and a half years old, and the
differences between those and the current releases of AJDT 1.3 and AspectJ
1.5 are huge, and therefore hard to summarise - essentially there have
been improvements across the board and many many new features.
Your options are unfortunately fairly limited - either stick with the old
versions, or possibly use a more recent AspectJ and use an Ant build to
compile your projects instead of AJDT. You will of course lose all the
support AJDT gives you - maybe you could do some prototyping using the
latest AJDT in a separate environment (using say Eclipse 3.1.1) and then
import it into your WSAD environment.
Finally, this probably doesn't help you right now, but we have at least
made improvements since then to reduce subsequent issues like this. For
example when we released AJDT 1.3 for Eclipse 3.1, we were also able to
release AJDT 1.2.1 for Eclipse 3.0 (and therefore Rational
Application Developer 6) containing the same release of AspectJ 5, and
also almost all of the functionality from AJDT 1.3.
Matt.
Re: Which version for Websphere WSAD [message #61800 is a reply to message #61590] Thu, 09 February 2006 04:26 Go to previous message
Thanks a lot for the clarification. We will go with the latest AspectJ and
the ant build.
Greetings, Chris
Re: Which version for Websphere WSAD [message #592068 is a reply to message #61535] Wed, 01 February 2006 07:17 Go to previous message
> Eclipse 2.
> Is this correct?
Yes.
> way?).
Matt.
Re: Which version for Websphere WSAD [message #592166 is a reply to message #61590] Thu, 09 February 2006 04:26 Go to previous message
the ant build.
Greetings, Chris
Previous Topic:compiler not copying .xml file to output folder
Next Topic:confused on how to setup projects
Current Time: Wed Jul 23 21:37:09 EDT 2025
Powered by FUDForum. Page generated in 0.26714 seconds
