Home » Modeling » Modeling (top-level project) » cdo - unimplemented methods and missing repositories
cdo - unimplemented methods and missing repositories [message #385161] Mon, 27 July 2009 14:07 Go to next message
Originally posted by: hamak.email.cz
Hi.
For the past couple of days I've been trying to learn cdo and to get it
to work with hibernate and mysql but unsuccessfully. I use Eclipse
Galileo on linux and I have followed these guides:
http://wiki.eclipse.org/CDO_Source_Installation and
http://wiki.eclipse.org/Getting_started_with_CDO_Galileo.
The first problem I have is that there is an error in CDOIDHibernateImpl
because methods isExternal(), isNull() etc. are not implemented. These
methods are commented out in its primitive class AbstractCDOID. Is it right
to uncomment them or is there another way to solve it?
The second problem concerns repositories. When I run CDO server(it
starts without any errors) and try
to connect to it in the CDO Sessions view I get an error that says
Repository /repo1 not found
org.eclipse.emf.cdo.util.ServerException: Repository /repo1 not found
at
org.eclipse.emf.internal.cdo.net4j.protocol.OpenSessionReque st.confirming(OpenSessionRequest.java:79)
at
org.eclipse.emf.internal.cdo.net4j.protocol.OpenSessionReque st.confirming(OpenSessionRequest.java:1)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientRequest .confirming(CDOClientRequest.java:77)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:123)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:103)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:423)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doSend(Requ estWithConfirmation.java:87)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.send(CDOClientProtocol.java:286)
at
org.eclipse.emf.internal.cdo.net4j.protocol.CDOClientProtoco l.openSession(CDOClientProtocol.java:78)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl$Delegati ngSessionProtocol.openSession(CDOSessionImpl.java:1572)
at
org.eclipse.emf.internal.cdo.session.CDOSessionImpl.doActiva te(CDOSessionImpl.java:716)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:65)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:94)
at
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:84)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:285)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:265)
at
org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:67)
at
org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:185)
and the console of the CDO sever says:
[ERROR] Factory not found: org.eclipse.emf.cdo.server.repositories[default]
org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not
at
org.eclipse.net4j.util.container.ManagedContainer.getFactory (ManagedContainer.java:193)
at
org.eclipse.net4j.util.container.ManagedContainer.createElem ent(ManagedContainer.java:490)
at
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:281)
at
at
org.eclipse.emf.cdo.spi.server.RepositoryFactory.get(Reposit oryFactory.java:43)
at
org.eclipse.emf.cdo.spi.server.ContainerRepositoryProvider.g etRepository(ContainerRepositoryProvider.java:41)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.OpenSessi onIndication.responding(OpenSessionIndication.java:85)
at
org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServer Indication.responding(CDOServerIndication.java:112)
at
org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOu tput(IndicationWithResponse.java:96)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:282)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:65)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Thanks for your help
Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #385162 is a reply to message #385161] Mon, 27 July 2009 17:11 Go to previous messageGo to next message
Hi Ondrej!
I cannot help with the first problem but maybe the second.
Skip the leading '/' in '/repo1' and try 'repo1' only. It worked for me!
Mario
"Ondrej Hamak" <hamak@email.cz> schrieb im Newsbeitrag
news:h4kqdf$g21$1@build.eclipse.org...
> Hi.
> right
> The second problem concerns repositories. When I run CDO server(it starts
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #385163 is a reply to message #385161] Mon, 27 July 2009 23:46 Go to previous messageGo to next message
Hi Ondrej,
To add some info. We did a fairly complete rework of the hibernatestore in CDO 3.0 (which is the current CVS HEAD),
after Galileo. The current cvs HEAD version passes all testcases and seems to be pretty complete (although not tested in
production...). This version also adds HQL query support.
My plan is to backport the CDO 3.0 hibernatestore to CDO 2.0.1 but it will be a few weeks before I have done that I am
afraid.... Also for the backport I am not sure that I can backport everything because of api constraints.
With this I would advice to either use CDO 3.0 from cvs, or wait for the CDO 3.0 build or wait for a CDO 2.0.1 build
with my backport...
I am not sure though when the next build of CDO (3.0) will be (which includes the changes I mention above).
gr. Martin
Ondrej Hamak wrote:
> Hi.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: cdo - unimplemented methods and missing repositories [message #385164 is a reply to message #385161] Tue, 28 July 2009 05:10 Go to previous messageGo to next message
Ondrej,
Comments below...
Ondrej Hamak schrieb:
> Hi.
> right
As Martin said, we completely reworked the HibernateStore. Now the
org.eclipse.emf.cdo.server.hibernate.id bundle is no longer needed (in
HEAD!). Please just delete it from your workspace. I've also removed it
from the PSF files now.
I also bet that the leading slash must be removed.
And I think that latest HEAD now throws a RepositoryNotFoundException
instead of just a FactoryNotFoundException if the named repository can
not be found in the managed container (and no factory is present to
create it).
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #385165 is a reply to message #385161] Tue, 28 July 2009 05:18 Go to previous message
Ondrej,
Please do not cross-post the same question to multiple newsgroups. CDO
is supported in the EMF newsgroup.
Cheers
/Eike
> Hi.
> right
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #617533 is a reply to message #385161] Mon, 27 July 2009 17:11 Go to previous message
Hi Ondrej!
Mario
> Hi.
> right
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #617535 is a reply to message #385161] Mon, 27 July 2009 23:46 Go to previous message
Hi Ondrej,
with my backport...
gr. Martin
Ondrej Hamak wrote:
> Hi.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
The Netherlands
Re: cdo - unimplemented methods and missing repositories [message #617538 is a reply to message #385161] Tue, 28 July 2009 05:10 Go to previous message
Ondrej,
Comments below...
> Hi.
> right
create it).
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Re: cdo - unimplemented methods and missing repositories [message #617541 is a reply to message #385161] Tue, 28 July 2009 05:18 Go to previous message
Ondrej,
Cheers
/Eike
> Hi.
> right
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ondrej Hamak
Previous Topic:cdo - unimplemented methods and missing repositories
Next Topic:Help: Advice on GUI Designer to choose?
Current Time: Sun Jul 27 13:01:58 EDT 2025
Powered by FUDForum. Page generated in 0.05437 seconds
