Home » Modeling » GMF (Graphical Modeling Framework) » SWT property editor
SWT property editor [message #61561] Thu, 12 October 2006 09:29 Go to next message
Hey,
I want to set up my editor so when you double click an element a SWT
dialogue box will pop up to allow for the elements properties to be edited.
There has been some discussion on this already:
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03693.html
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg01050.html
From these threads I see that I first need to extend the OpenEditPolicy
(below), this will allow for a double-click on an element to work? Where
is the OpenEditPolicy located? Where should this code go?
public class OpenEditorEditPolicy extends OpenEditPolicy {
protected Command getOpenCommand(Request request) {
EditPart targetEditPart = getTargetEditPart(request);
if (targetEditPart instanceof IGraphicalEditPart) {
IGraphicalEditPart editPart =
(IGraphicalEditPart)targetEditPart;
View view = editPart.getNotationView();
if (view !=null){
EObject element =
ViewUtil.resolveSemanticElement(view);
if (element instanceof Diagram) {
return new ICommandProxy(
new
OpenEditorCommand(element));
return null;
Re: SWT property editor [message #61725 is a reply to message #61561] Thu, 12 October 2006 10:20 Go to previous messageGo to next message
Gaff,
You don't need to extend the OpenEditPolicy, you just want to override
its behavior by installing your own editpolicy on the OPEN_ROLE that
handles the request RequestConstants.REQ_OPEN.
To get an understanding of how editpolicies work, take a look at:
- The GEF Programmer's Guide
- GraphicalEditPart.createDefaultEditPolicies()
- The "Diagram Services Layer - How-to Guide" EditPolicy provider example.
Cherie
Gaff wrote:
> Hey,
> EditPart targetEditPart = getTargetEditPart(request); if
> IGraphicalEditPart editPart = (IGraphicalEditPart)targetEditPart;
> if (view !=null){
> EObject element = ViewUtil.resolveSemanticElement(view);
> new
> OpenEditorCommand(element)); }
> } } return null;
Re: SWT property editor [message #61845 is a reply to message #61725] Thu, 12 October 2006 12:15 Go to previous messageGo to next message
Gaff,
Actually it does make sense to also extend the OpenEditPolicy as this
will provide you with the knowledge of the request type and all you need
to do is implement the abstract method getOpenCommand().
- Cherie
Cherie Revells wrote:
> Gaff,
> Regards,
> Cherie
> Gaff wrote:
>> Hey,
>> edited.
>> OpenEditPolicy (below), this will allow for a double-click on an
>> element to work? Where is the OpenEditPolicy located? Where should
>> this code go?
>> { IGraphicalEditPart editPart =
>> (IGraphicalEditPart)targetEditPart; View view =
>> editPart.getNotationView(); if (view
>> !=null){ EObject element =
>> new
>> } } return null;
Re: SWT property editor [message #62218 is a reply to message #61725] Fri, 13 October 2006 10:55 Go to previous messageGo to next message
But what is the file location of the OpenEditPolicy class. Can't seem to
find it anywhere.
Gaff
Re: SWT property editor [message #62241 is a reply to message #62218] Fri, 13 October 2006 11:20 Go to previous messageGo to next message
Gaff wrote:
Open edit policy is inside the package :
org.eclipse.gmf.runtime.diagram.ui.editpolicies
in the plugin :
> Cheers,
> find it anywhere.
> Gaff
Re: SWT property editor [message #63729 is a reply to message #62241] Tue, 17 October 2006 06:29 Go to previous messageGo to next message
I've found the file but there's no source as it's a plug-in (thought I
could just extend it form there). When I right click the package and try
to add a new class (to do the extension) it opens a new package within the
source above, the package is the right name but the code I paste in
doesn't work...
code from:
http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03725.html
The first error I get is:
"The type OpenEditorEditPolicy must implement the inherited abstract
method
OpenEditPolicy.getOpenCommand(Request)"
And the rest are type cannot be resolved errors.
What am i misssing to extend this class?
Thanks.
Re: SWT property editor [message #63977 is a reply to message #63729] Tue, 17 October 2006 07:46 Go to previous message
GMF newsgroup is not the right place to ask general Eclipse/Java development
questions.
You can find sources for the plug-in in our downloads.
Artem
"Gaff" <conorgaff@hotmail.com> wrote in message
news:50545073bf8c1f0bdbfb5bd37a4d1721$1@www.eclipse.org...
> doesn't work...
> code from:
> method OpenEditPolicy.getOpenCommand(Request)"
> Thanks.
Previous Topic:Transparent SVG file as a figure
Next Topic:Filter out properties from EMF section
Current Time: Mon Nov 17 06:51:16 EST 2025
Powered by FUDForum. Page generated in 0.08345 seconds
