Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo resources and the EMF Validation framework do not properly work together
Teneo resources and the EMF Validation framework do not properly work together [message #116142] |
Thu, 27 March 2008 10:57  |
Hi!
I'm trying to use the EMF Validation framework (not to be confused with the
EValidator API) together with an EMF editor based on JPOXResource. The
editor works fine, I can run the validation and I even get results in the
form of a popup window. Problem marker generation (with
EclipseResourcesUtil used by ValidateAction) however, is broken because
calls to IFile EditUIMarkerHelper::getFile(Object datum) return null for
JPOXResource objects. The getFile method propagates to
MarkerHelper::getFile(URI uri)) which checks if the URI is a platform URI
and returns null if it is not.
Are there any workarounds known for this problem?
Florian
Florian Hackenberger
Re: Teneo resources and the EMF Validation framework do not properly work together [message #116260 is a reply to message #116195] |
Thu, 27 March 2008 15:39   |
Yes as Ed says I have not done anything with EFS. I found this article which gives a nice overview
of what is required to implement an efs:
http://www.eclipsezone.com/articles/efs/
It is an interesting topic although I wonder how the efs can be mapped to a relational db (and vice
versa). Florian, can you enter a bugzilla for this?
As my time is limited it can take a while before this is done. Contributions regarding this topic
are ofcourse more then welcome!
btw, afaics adding efs support to Teneo does not solve the fact that the uri is not a platform uri
and that MarkerHelper returns null.
gr. Martin
Ed Merks wrote:
> Florian,
> It's certainly potentially possible that the URI scheme Teneo uses for
> accessing resources could be registered with Eclipse's EFS
> (EclipseFileSystem) so that the resources could be surfaced as
> IResources in the workspace. But I don't think Martin has done anything
> like that.
> The EMF newsgroup is definitely still accessible since I'm answering
> your question from that newsgroup.
> <news://news.eclipse.org/eclipse.tools.emf>
> DI Florian Hackenberger wrote:
>> Martin Taal wrote:
>>> With me (Eclipse 3.4) the MarkerHelper.getFile method is like this:
>> <snipped/>
>>> what type is the datum object?
>> The method which is called is getFile(URI), getFile(Object) is overridden by
>> EditUIMarkerHelper. After digging a bit deeper, it became clear that the
>> Eclipse Marker support is based on IResource objects. Which leads me to the
>> question: Is there an adapter (or something else) available mapping
>> JPOXResource / StoreResource to IResource?
>> I have found a references here:
>> http://dev.eclipse.org/newslists/news.eclipse.platform/msg57 934.html
>> but unfortunately it does not provide a solution. The original thread on the
>> eclipse.tools.emf newsgroup is unfortunately not accessible anymore:
>> http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.tools. emf/2006/Aug/index.php
>> Cheers,
>> Florian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo resources and the EMF Validation framework do not properly work together [message #116313 is a reply to message #116308] |
Fri, 28 March 2008 06:09  |
Yes it would be great if you can write up a small page with the problem description and the solution
and then send it to me. I will then add it to the docs.
Thanks!
gr. Martin
>> uri is not a platform uri and that MarkerHelper returns null.
> I just found a workaround using the ejdo resource. I simply create a project
> in the workspace, calculate the file url for the ejdo file I want to use
> (it's stored in a plugin) using FileLocator, create a new file link to the
> ejdo file within the new project and use the project url of the file link
> to open the editor. Problem solved. shall I document the workaround
> somewhere?
> Cheers,
> Florian
The Netherlands
Re: Teneo resources and the EMF Validation framework do not properly work together [message #616012 is a reply to message #116142] |
Thu, 27 March 2008 11:32  |
Hi Florian,
protected IFile getFile(Object datum)
if (datum instanceof IFileEditorInput)
return ((IFileEditorInput)datum).getFile();
else if (datum instanceof IFile)
return (IFile)datum;
else if (datum instanceof Diagnostic)
return getFile((Diagnostic)datum);
return null;
For the rest I do not know that much about the validation framework. Questions regarding validation
are answered on the EMF newsgroup which I added to this post.
btw, I had the same type of issues while integrating teneo and gmf. To solve that I had to change
part of the gmf logic. With gmf this was easy as I could do this in the generated code.
gr. Martin
> Hi!
> Cheers,
> Florian
The Netherlands
Re: Teneo resources and the EMF Validation framework do not properly work together [message #616014 is a reply to message #116182] |
Thu, 27 March 2008 13:13  |
--------------050707060007060809050305
Florian,
like that.
> <snipped/>
> Cheers,
> Florian
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Florian,<br>
<br>
anything like that. <br>
<br>
your question from that newsgroup.<a
href="news://news.eclipse.org/eclipse.tools.emf"><br>
</a>
<blockquote><a href="news://news.eclipse.org/eclipse.tools.emf">news://news.eclipse.org/eclipse.tools.emf</a><br>
</blockquote>
<br>
<blockquote cite="mid:fsgffk$qh1$1@build.eclipse.org" type="cite">
<pre wrap="">Martin Taal wrote:
</pre>
<blockquote type="cite">
<pre wrap="">With me (Eclipse 3.4) the MarkerHelper.getFile method is like this:
</pre>
</blockquote>
<pre wrap=""><!----><snipped/>
</pre>
<pre wrap="">what type is the datum object?
</pre>
</blockquote>
<pre wrap=""><!---->The method which is called is getFile(URI), getFile(Object) is overridden by
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/newslists/news.eclipse.platform/msg57 934.html"> http://dev.eclipse.org/newslists/news.eclipse.platform/msg57 934.html</a>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.tools. emf/2006/Aug/index.php"> http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.tools. emf/2006/Aug/index.php</a>
Florian
</pre>
</blockquote>
<br>
</body>
</html>
--------------050707060007060809050305--
Re: Teneo resources and the EMF Validation framework do not properly work together [message #616019 is a reply to message #116195] |
gr. Martin
Ed Merks wrote:
> Florian,
> like that.
>> <snipped/>
>> Cheers,
>> Florian
The Netherlands
Re: Teneo resources and the EMF Validation framework do not properly work together [message #616024 is a reply to message #116260] |
Fri, 28 March 2008 05:55  |
somewhere?
Florian
Re: Teneo resources and the EMF Validation framework do not properly work together [message #616025 is a reply to message #116308] |
Thanks!
gr. Martin
> somewhere?
> Cheers,
> Florian
The Netherlands
Current Time: Fri Jul 25 08:31:56 EDT 2025
Powered by FUDForum. Page generated in 0.06349 seconds
