Home » Archived » GMT (Generative Modeling Technologies) » [EVL] Possible Bug with collection comparison
[EVL] Possible Bug with collection comparison [message #615803] Tue, 29 April 2008 10:40
I may have discovered a bug which occurs when comparing collections. I
first ran the following validation file...
context SimpleClass!Entity {
constraint CheckingParentExists {
check : self.Child = true implies self.parent-> size = 1
message : 'There is no parent for ' + self.classname
constraint CheckChildOperations {
guard: self.Child = true
check : false
message : self.parent.operations->collect(s| s.name) + 'does not have the
correct operations' + self.operations->collect(b|b.name)
...which as you would expect returned: " first collection" does not have the
correct operations "second collection"
However when I add in a third constraint which should compare the two
collections (as can be seen below) there is no validation output not even to
the constraint where the check is set to false. Is this a bug or am I doing
something incorrectly? [This used to work correctly]
check : false
check : self->collect(b|b.operations).includesAll( self.parent->collect(s|
s.operations ))
message : self.classname + 'does not have the correct operations'
Previous Topic:[EVL] Printing collections
Next Topic:[EVL] Possible Bug with collection comparison
Current Time: Sat Jul 19 19:19:12 EDT 2025
Powered by FUDForum. Page generated in 0.84372 seconds
