Home » Modeling » UML2 Tools » Use Case Diagrams in M4?
Use Case Diagrams in M4? [message #472263] Mon, 14 January 2008 22:01 Go to next message
Good day,
I'm new to EMF, GEF, GMF and UMLTools. I'm a university student doing my
honours project which involves in part the visualization of a domain
model and use case model read from a custom XML file (perhaps even a
standard XMI file). Have use case diagrams actually been implemented in
M4 (bug #199725)? If so, what would I need to get started. I've manually
installed UMLTools 0.8.0 and all its dependencies listed on
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools
There seems to be lot to learn. Any recommendations on where to start
and how to proceed? I plan to go through the four part GMF tutorial
(http://wiki.eclipse.org/index.php/GMF_Tutorial).
Thank you.
Sam Sabra
Re: Use Case Diagrams in M4? [message #472265 is a reply to message #472263] Tue, 15 January 2008 07:52 Go to previous messageGo to next message
Hello Sam,
Welcome to UML2Tools newsgroup.
Yes, UseCase diagram editor is a part of UML2Tools now.
It would be helpfull to get familiar with GMF. Moreover, we have our little
wiki page - http://wiki.eclipse.org/MDT-UML2Tools. There is some usefull
infomation on it.
To realize which elements are already supported and how do they look like
in UML2Tools I recommend to look through diagram examples. They are figures
from UML 2 specification made with UML2Tools. You can check them out from
our CVS:
cvs -d pserver:dev.eclipse.org:/cvsroot/modeling co org.eclipse.mdt/org.eclipse.uml2tools/examples/
'org.eclipse.uml2.diagram.examples.clazz' project, 'diagram/07-02-03/16 Use
Cases' folder
God luck,
Tatiana.
> Good day,
> my
> in M4 (bug #199725)? If so, what would I need to get started. I've
> manually installed UMLTools 0.8.0 and all its dependencies listed on
> Thank you.
> Regards,
> Sam Sabra
Re: Use Case Diagrams in M4? [message #472344 is a reply to message #472265] Wed, 16 January 2008 02:09 Go to previous messageGo to next message
Thank you Tatiana, I will look into the wiki and examples.
Kind Regards,
Sam
Tatiana Fesenko wrote:
> Hello Sam,
> little wiki page - http://wiki.eclipse.org/MDT-UML2Tools. There is some
> usefull infomation on it.
> like in UML2Tools I recommend to look through diagram examples. They are
> figures from UML 2 specification made with UML2Tools. You can check them
> out from our CVS: cvs -d pserver:dev.eclipse.org:/cvsroot/modeling co
> Use Cases' folder
> God luck,
> Tatiana.
>> Good day,
>> my
>> Thank you.
>> Regards,
>> Sam Sabra
Re: Use Case Diagrams in M4? [message #472348 is a reply to message #472265] Wed, 16 January 2008 03:33 Go to previous messageGo to next message
I don't understand what is the sence to use GMF. The Eclipse Europa has a
plug-in called UML2 diagram. Can one use it instead of GMF?
Re: Use Case Diagrams in M4? [message #472366 is a reply to message #472348] Wed, 16 January 2008 15:32 Go to previous message
Hello thomas2004,
Please specify what exactly plugin are you talking about. Do you mean org.eclipse.uml2.diagram?
Good news is that we not only use it, we develope it! It's our branding plugin.
BTW, we have a wiki-page - http://wiki.eclipse.org/MDT-UML2Tools. There are
a lot of usefull links to pages of the technologies we use =) They are really
interesting.
Tatiana.
> has a plug-in called UML2 diagram. Can one use it instead of GMF?
Re: Use Case Diagrams in M4? [message #615764 is a reply to message #472263] Tue, 15 January 2008 07:52 Go to previous message
Hello Sam,
wiki page - http://wiki.eclipse.org/MDT-UML2Tools There is some usefull
infomation on it.
our CVS:
Cases' folder
God luck,
Tatiana.
> Good day,
> my
> Thank you.
> Regards,
> Sam Sabra
Re: Use Case Diagrams in M4? [message #615778 is a reply to message #472265] Wed, 16 January 2008 02:09 Go to previous message
Kind Regards,
Sam
> Hello Sam,
> little wiki page - http://wiki.eclipse.org/MDT-UML2Tools There is some
> Use Cases' folder
> God luck,
> Tatiana.
>> Good day,
>> my
>> Thank you.
>> Regards,
>> Sam Sabra
Re: Use Case Diagrams in M4? [message #615782 is a reply to message #472265] Wed, 16 January 2008 03:33 Go to previous message
Re: Use Case Diagrams in M4? [message #616732 is a reply to message #472348] Wed, 16 January 2008 15:32 Go to previous message
Hello thomas2004,
BTW, we have a wiki-page - http://wiki.eclipse.org/MDT-UML2Tools There are
interesting.
Tatiana.
Previous Topic:Graphical Editor using UMLProfile
Next Topic:Error in Drawing Position
Current Time: Fri Jul 25 21:29:17 EDT 2025
Powered by FUDForum. Page generated in 0.04923 seconds
